Single cogs for shimamo 7/8 speed freehubs?
Old 08-03-21, 01:44 PM
browndude3649
Quoted: 7 Post(s)
Liked 3 Times in 2 Posts
Where do you guys get ur cogs for a roadie singlespeed set up?
browndude3649 is offline
Old 08-03-21, 03:18 PM
browndude3649
Quoted: 7 Post(s)
FSA 53/39 tooth. What's the biggest rear recommended sprock if I used the 53T ?
Old 08-03-21, 04:27 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
How big of a gear do you want to push? A 53 X 20 will get you 70 gear inches, but I have no idea if that'll work for your terrain. Personally, I'd use the 39T and fine tune it with a 14, 15, 16, or even 17T cog, depending on how hilly your routes are. Plus, you'll get better chainring clearance, if that matters to you.
Rolla is offline
Old 08-03-21, 06:30 PM
Oakman
Bikes: Road, hybrid, and SS
Quoted: 60 Post(s)
Liked 98 Times in 37 Posts
Just put this on a road bike and it works fine. The included spacers were needed for a new conversion.
CyclingDeal Conversion Kit Fixie Bike Single Speed Compatible with Shimano Sram Cassette Freewheel Hub Adaptor - for Mountain and Road Bike Gear Cog Spacers 16 Teeth
BTW, I paired it with a 42.
Oakman is offline
Old 08-04-21, 11:00 PM
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
I just take apart a couple of cassettes for the spacers and the cogs. Then I just use whichever cog that coupled with the chairing I have to get the gear I want. A lot of times a bicycle shop will give me a couple of worn out cassettes for the spacers in them.
Oh, if it's a Uniglide cassette body, I've found that many times a bottom bracket lockring can be use to hold the spacers and cog in place. To me it looks a lot neater than a small screw on cog does on a single speed.
Cheers
Miele Man is offline
Likes For Miele Man:
Old 08-05-21, 03:05 AM
browndude3649
Quoted: 7 Post(s)
Anybody like the(25$) bombshell alum. Cog? Profile has diff cogs also.
Old 08-05-21, 03:07 AM
browndude3649
Quoted: 7 Post(s)
Cheers
I have a HG cassette I just never split the six cog block from each other. I'd like to use the big chainring up front with a big cog off the cassette but.....
Old 08-05-21, 07:18 AM
Miele Man
Take a close look at the freehub body. Some early Hyperglide ones were transitional ones and could be use with either Hyperglide or Uniglide cassettes. Those freehub bodies had threading on the outside for a small Uniglide cog as well as t he internal threading for the Hyperglide lock ring.
Cheers.
Old 08-05-21, 09:37 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
There are any number of cogs that would work, from 5-speed Uniglide, to 11-speed Hyperglide. It just needs to fit the splines on your freehub. The nicer cassettes had/have little bolts holding them together that you can undo with a 4mm wrench or pair of pliers. Cheaper cassettes will need a Dremel to grind out the rivet heads.
If you have horizontal dropouts, you could probably even use a worn cog that was starting to skip when you were running it with a derailleur.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 08-08-21, 08:03 PM
browndude3649
Quoted: 7 Post(s)
Took a ride to San rafael's bike kitchen (trips for kids). Found an old shimano cassette with the rivets drilled out and spacers included, acoupla no name cogs. Experiment time!
Likes For browndude3649:
Old 08-08-21, 08:50 PM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 646 Post(s)
Liked 1,044 Times in 667 Posts
I use the cheap Dimension splined SS cogs. I got mine over the years from a LBS for $6 each. Plain steel SS cogs for Shimano free hub. I’ve run mostly 42/16 or 42/17 on my 26er. They make them in a lot of sizes. I can’t speak to current availability through part suppliers.
Otto
ofajen is offline
Likes For ofajen:
