does cs-8000 replace cs-6800 ?
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 849 Times
End my pain, please. Based on searches here, looking at convoluted Shimano compatibility charts, etc etc etc... way too much time invested... Time to replace the CS-6800 11-28. Can I use the CS-8000 11-28, or do I need to "stay back" ? And, looks like if I want to go to 30, I need a GS. Ya? Nah ? Thanks in advance.
Optically Corrected
Yes, the CS-6800 11-28 and CS-R8000 11-28 are interchangeable.
If you wanted to go to a 30 tooth cassette you can probably use your current derailleur as Shimano is rather conservative on the spread of what their derailleurs can cover... testing is the only way to be 100% sure.
If you would like anything over a 30 tooth cog, on the back, you would need the R8000 11-speed rear derailleur GS.
Likes For KLiNCK:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Definitely compatible cassettes. The Di2 derailleur does seem to work w/ cassettes like the 30t you're considering even a bit better than the mechanical part.
