Garmin... thanks
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Garmin... thanks
My Garmin heart rate monitor has been flaky lately. It's been reading over 200 when I first put it on and other times really low, under 100 when i'm riding. I replaced the battery even though the old battery still showed 3v. I regularly clean the strap, wearing it into the shower.
So i called Garmin customer support to ask if I need to replace the strap. I explained that it was 5 years old and i used it with my 510. The service rep couldn't say if replacing the strap would fix the problem so he offered to send me a free replacement.
So today it arrived and he sent a complete unit, strap and HRM.
Now that's what I call service.
Bikes: 17 Spot Acme, 14 Lynskey Peleton
SuperGimp
I busted the little dog ears off my 800 and before embarking on a home made solution, I figured I'd call them - $29 and they sent me a refurb.
I replaced the battery myself when that died though.
Their policies look bad but the reality has been pretty good for me.
On Your Left
Liked 2,433 Times
Quoted: 45 Post(s)
Liked 6 Times
What issues with your 520? Mine is always flaking out mid ride. I've hard reset it twice.
Last ride I disabled BT on my phone, and was able to complete my ride without further incident.
Quoted: 18883 Post(s)
Liked 10,646 Times
So the thing with Garmin is that it takes about 2 years for the firmware to stabilize. Once that happens you're basically good. During the first ~18 mo, every other update with break something else. My 510 had some issues (always firmware related) but it's been like a rock ever since Garmin moved on to the 520 for development.
Quoted: 5 Post(s)
My first 520 worked flawlesly until one day it wouldn't turn on. The second one refused to connect with my cadence sensor. Yes I changed batteries and even a different sensor. The third one is still sitting in a box. Too nervous to try it out.
Liked 10 Times
I wonder if in the shower is a bit too much? i expect they are water resistant not water proof. and if the little gasket for the battery wears out or is damaged it will leak. cleaning it with a wet cloth or quick rinse of the elastic while keeping the computer dry might be better?
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Their newer toys seem to have gotten flakier. The howling from the tri geeks about all the issues with the 910XT was deafening.
Quoted: 5 Post(s)
Garmin has been pretending to work for three years now to get the Edge 810 turn by turn navigation to work problem free. After three years of failure on Garmin's part I have come around to thinking that they know what's wrong with the Edge 810 they just refuse to take the financial hit to fix or replace their customer's Edge 810's and are just running out the clock until no one cares.
On Your Left
Liked 2,433 Times
D'oh.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Bikes: 2013 Specialized Roubaix SL4 Expert Compact
Quoted: 23 Post(s)
I love good customer support stories, I also really like Garmin.
I have a Garmin 1000, Vector 2 pedals, vivofit (original), Fenix2 for running, Virb EX and I'm sure other Garmin things I forgot about. I love having all of my data in one pace.
Quoted: 686 Post(s)
Liked 5 Times
Hmm, I had one that just started doing something similar but had a backup monitor so didn't pay any attention and just tossed the old one in a drawer. Maybe I should call, having another backup wouldn't be a bad thing.
Bikes: Cervelo S2, Workswell 062, Banshee Spitfire
I've found that Garmin support is hit or miss depending on the rep you get. I've gotten warrantied on units where the warranty has expired and times where they did not want to give me anything short of sending my unit back and a 20% discount on a full MSRP 810.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
The tri-specific straps are new. Tri geeks have swum in all the Garmin straps back to the classic "hard" strap. I swam a ton in the original soft-strap, along with their classic original "HRM" unit before they added run dynamics and swimming and all that.
If that replacement doesn't work, check out the guru of electronics / biking gear: DC Rainmaker's web site. Great stuff. And he'll answer your question if it has wide appeal.
CanadianBiker32
5
11-29-16 01:50 AM
bobthib
Fifty Plus (50+)
12
12-07-11 05:59 PM
