Tire installation: 2.25" vs 2.4" vs 2.6"
we be rollin'
I want to know if anyone here have tried installing different size tires. Is it true larger tires are harder to install? Is it because your hand can't get fully around the tire while installing?
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,539 Times
People try different size tires all the time.
The only issue you’ll run into is if your rims are too narrow to be running a 2.6. The tire will mount, and it will work, but it is not optimal. They are usually designed for a wider (like 30mm or more) rim.
How wide are your rims?
Likes For Kapusta:
we be rollin'
Actually, I was just wondering but I mean it would be more like adventure touring. I heard the Ryde Andra 40 is good but that's 25mm.
Advanced Slacker
Liked 2,539 Times
we be rollin'
