Help ID this frame?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1085 Post(s)
Liked 1,822 Times
Help ID this frame?
They were all excited thinking it was a DeRosa
Yes, there is a subtle heart like shape, cut out in the lugs, but more than one lug company produced that style
What’s really confusing me is the Gilco style tubing
ive seen it on Daccordi, and I know others have used it.
The top tube is bent. So the bike is destined for the scrap heap anyway. I’m just curious what it is
"Leave the gun. Take the Colnagos."
Liked 1,822 Times
Any thoughts??
again, top tube is bent. It will be scrapped.
just curious
just curious
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 977 Times
Likes For georges1:
Quoted: 1079 Post(s)
Liked 1,899 Times
Looks like a Detto Pietro Polare.
Hard to see from your photos, but I think the seat stay caps look a bit like this:
And the gigantic cable routing hole looks like this:
Same brake bridge:
That one was made by Tecnotrat.
This a different Detto Pietro with a heart shaped cutout:
Same brake bridge:
Likes For Robvolz:
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
I don't think that tubing is authentic Columbus Gilco, it's just "crimped".
But the "close match" Tecnotrat-made Detto Pietro has somebody's decal on the seat tube...what's that say?
Likes For P!N20:
Liked 1,899 Times
So here I am sitting here quite proud of myself that I'd managed to identify a frame.
Then I do a bit of Googling about the C-18 tubing...and find this:
Not only does it have the fluted C-18 tubing, it has the same brake bridge, chainstay bridge, seat stay caps and heart shaped cutouts that the subject frame has. Plus it has a pump peg, which was absent from the red DP example.
If CyclingFool95 can confirm the routing holes are the same then it's probably just a Tecnotrat frame that received various decals.
Pedal to the medal
Liked 1,064 Times
FWIW that big oval hole for intenal TT cable routing should have a plastic (or synthetic "rubber") insert grommet that were used by several Italian brands and made by...uh...some Italian company but I forget the name!
I'll update this if I find that info
Edit: possibly these "Cinelli" style plug/grommets might fit and they are also knocked off by other makers and can (sometimes) be found on eBay...I think even when Cinelli was the primary supplier they had counterfeiters in Italy knocking them off!
Quoted: 1641 Post(s)
Liked 831 Times
Be aware though that many bik3s that had those big oval holes on the top tube ended up with cracks starting at those holes.
Not sure why, but maybe some of them did not have those hole edges smoothened enough, so it presented possible stress risers at the hole edges...
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 33 Post(s)
Liked 125 Times
Robvolz , six ribs does it have? I concur with the Tecnotrat identification. These pop up in Australia from time to time as a lot of Tecnotrat frames were sold here. Usually the seller will have a misleading description that implies they're an unbranded Colnago, with an equally optomistic asking price
Likes For Seanaus:
Quoted: 1106 Post(s)
Liked 1,328 Times
- fluted seatposts
- bottom bracket cutouts
- crimped frame tubes
- curved frame tubes
- L-shaped cranks,
- lever-action drive
- etc etc
The manufacturers count on buyers
- not knowing basic physics
- having disposable income
- believing the pimply-faced youth who's trying to boost his commission
I could straighten that top tube on one headlight. I've straightened sailboat masts bent worse than that, same for a small sailboat dolly axle that hit a chunk of truck tread on the highway, was bent about a foot, to within 1/16" straightness, I was going to go closer but the guy who owned the trailer said that was close enough. Key is no dent and no kinks, just a gentle bend like your frame. I use a hydraulic press, a 4x4 at minimum on the bottom, at least the length of the bend, then 2x4s crosswise under the head tube and seat tube junctions, then put the top tube there convex side up, then a short 4x4 on top of the top tube, which the hydraulic ram pushes on. Take things slow. Bring the ram into contact, one pump on handle, release, all springs back. Then repeat, contact, 2 pumps, release, check if all springs back. Then repeat, contact, 3 pumps, release, check. Keep increasing number of pumps after contact until it doesn't spring back all the way, that means it's starting to yield. So for example, if 3 pumps and all springs back, and 4 pumps a bit of yield, you're gonna move it one pump at a time; 4 pumps, release, contact, 4 pumps again, etc. Partial pumps as you get close. Take your time. Or get a quote from a framebuilder or specialist in frame straightening.
Liked 1,822 Times
$100 it’s yours
you can straighten it.
you haven’t even seen the extent of the damage but everyone is chiming in on how it isn’t so bad.
I’ll post pics tomorrow.
Was at the LBS today, they had three frames out front, one looked old but nice, steel lugged frame by Georgina Terry, IIRC, they made frames proportioned better to female riders, some having a smaller front wheel. Free with any purchase over $5, and I bought some stuff. I have no room for such things, sadly, and I hope it goes to someone who can use it.
Liked 1,822 Times
you must live in Seattle
Liked 1,822 Times
It’s free.
Liked 1,822 Times
The paint is stunning. Like a multi orange, with a touch of fine metallic
It’s hard to make my camera see what I see. The bike is only good for turning left
Dent at the light reflection
Hole looks fine, maybe some pitting from previous rust
Liked 1,822 Times
New offer, I will pay you $20 to come and get it, but you have six months to straighten it and build it. At that point I’ll give you a nice bottle of Pinot Noir.
Likes For unworthy1:
Quoted: 792 Post(s)
Liked 1,780 Times
Yes that is a bent out of alignment frame normally you can't see alignment issues in pics but my bad eyes iffy judgment see 10mm plus so pretty bad.
