Is White Lithium Grease really what should be used?
Old 01-03-19, 06:08 PM
Anonymous238
Quoted: 12 Post(s)
After consulting this forum about attaching new pedals to my bike, I read that white lithium grease would need to be applied to stop the pedal threads from ceasing. I did just that and a few months later discovered that one of my new bike pedals somehow came lose and ate away at the crankarm thread so badly that nothing would repair it (I had to ride it wobbling out since I was miles away from my destination). I waited a half a year for someone to sell the same crankarm on ebay because the crankset was practically brand new and I wasn't going to pay another 150 for a new one. I just attached the new crankarm with the grease a week ago and today I noticed my crankarm was wobbling off too! I'm tightening these parts as damn hard as I can and I can bench 200+ easily. What gives? Is it really just more tightening that's required or is the grease causing this (I use a lot btw - the white grease is visible around the threads)
Anonymous238 is offline
Old 01-04-19, 07:43 AM
DiegoFrogs
DiegoFrogs's Avatar
Bikes: '77 Centurion "Pro Tour"; '67 Carlton "The Flyer"; 1984 Ross MTB (stored at parents' house)
Quoted: 169 Post(s)
Liked 93 Times in 61 Posts
I usually use whatever grease I happen to have on hand, including white lithium, and with good, clean threads and reasonable quality pedals and cranks, have never had a problem.
DiegoFrogs is offline
Old 01-04-19, 08:17 AM
Deal4Fuji
minimalist cyclist
Deal4Fuji's Avatar
Bikes: yes please
Quoted: 1119 Post(s)
Liked 1,643 Times in 945 Posts
You are turning the left pedal counterclockwise to tighten right correct? That part of your statement above makes me think you may possibly be cross threading the non-traditional threaded left pedal. With grease on the threads it shouldn't be that hard. Another possibility could be the thread size, there are 1/2 and 9/16th sized pedals. I wouldn't think you could get a 9/16" pedal started in a 1/2" crank but if you're that strong
Deal4Fuji is offline
Old 01-04-19, 08:36 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 854 Post(s)
Liked 1,437 Times in 819 Posts
I surely do not know what the problem could be. Possibly what the above reply states. I have been using Liquid Wrench, spray can. for a long time for mounting pedals and lubing of all kinds of screws, bolt. nuts etc., including marine/saltwater applications, and have never had any kind of problem with it. It is also long lasting.
delbiker1 is offline
Old 01-04-19, 08:42 AM
Kedosto
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times in 190 Posts
FWIW, I use Permatex zinc anti-seize for parts I wanna get back apart easily in the future. Pedal threads, seatposts, quills, etc. It’s compatible with everything and lasts forever.
-Kedosto
Kedosto is offline
Old 01-04-19, 02:50 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,105 Times in 1,369 Posts
There are better options but the grease didn’t cause the problem.
the crank arm you bought may already have been ruined. Is it a hollow spindle type where the arm clamps on the spindle and the bottom bracket bearings screw into both sides of the shell? or is it a solid spindle type bottom bracket where it bolts to the spindle with a square peg or splines?
Darth Lefty is offline
Old 01-04-19, 03:01 PM
Hoopdriver
On Holiday
Hoopdriver's Avatar
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times in 12 Posts
Bummer that this happened to you. I use anti-seize usually but occasionally used whatever grease was on hand and have had no problem in over 50 years of cycling. Do you think you may have cross threaded the spindles when you installed.
BTW, you really didn't need a new crank arm. There are repair kits available for problems like the one you described. Most bike shops should be able to do this for you.
Hoopdriver is offline
Old 01-04-19, 03:12 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Could, not Should .. Decades ago the little tub you bought with <Campagnolo> on it , was a Lithium cream colored grease..
fietsbob is offline
Old 01-04-19, 04:03 PM
u235
u235's Avatar
Quoted: 437 Post(s)
Liked 133 Times in 86 Posts
I think that is your problem... Tightening too hard. That is the only thing that makes sense. Crank material (typically aluminum) is always softer than a pedal spindle (hardened steel), way softer, different league.. If one or the other is going to strip, stretch, or somehow get damaged from improper installation, it will be the crank. It depends on your specific cranks and pedals but ~ 30-40NM (25 ft/lbs) is a good start. A crank arm to BB pinch bolt torque varies but I believe Shimano Hollowtech are like 10 NM. Non pinch types (square/spline) are usually in the 30-40 range. Not much at all. If you are cranking any of these down, the crank will fail. Same applies to your seat, stem, handlebars and any other bolt.
u235 is offline
Old 01-04-19, 05:35 PM
fietsbob
Bikes: 8
(yes , but.. Not owning a torque wrench & proper bit to fit your pedal) maybe you need an experienced bike mechanic to show you how tight is tight enough..
I'd hate to be the next guy trying to remove a pedal you over-tightened so excessively..
sometimes it takes 2 people to work as a team to get off some pedals.. (on Bikes left for boxing and Shipping after riding from the east coast )
fietsbob is offline
Old 01-08-19, 09:56 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,585 Times in 2,344 Posts
would be nice to know how the OP used. brushing it on thick on all the threads inside & outside would be overkill. when ever I use that stuff I'm sure to use a tiny bit & even wipe it off. it spreads easily so just a dot somewhere in the middle of a thread is usually more than enough. having clean threads is important too. wonder if the OP is using a pedal wrench
rumrunn6 is offline
Old 01-08-19, 12:54 PM
bigbenaugust
always rides with luggage
bigbenaugust's Avatar
Bikes: 2007 Trek SU100, 2009 Fantom CX, 2012 Fantom Cross Uno, Bakfiets
Quoted: 273 Post(s)
Liked 20 Times in 17 Posts
I use Phil Wood grease on the pedal threads. Nice to know lithium works too, as I have a bunch for my trailer hitch ball.
--Ben
2006 Trek SU100, 2009 Motobecane Fantom CX, 2011 Motobecane Fantom Cross Uno, and a Bakfiets
Previously: 2000 Trek 4500 (2000-2003), 2003 Novara Randonee (2003-2006), 2003 Giant Rainier (2003-2008), 2005 Xootr Swift (2005-2007), 2007 Nashbar 1x9 (2007-2011), 2011 Windsor Shetland (2011-2014), 2008 Citizen Folder (2015)
Non-Bike hardware: MX Linux / BunsenLabs Linux / Raspbian / Mac OS 10.6 / Android 7
bigbenaugust is offline
Old 01-10-19, 09:45 PM
JanMM
rebmeM roineS
JanMM's Avatar
Quoted: 653 Post(s)
Liked 347 Times in 226 Posts
Guessing that the current problem is the crankarm loosening from a square taper spindle? Sounds like grease was used on the tapers, which may have contributed to the problem. I have never used lube for that. But, some folks do.
JanMM is offline
Old 01-11-19, 04:47 AM
acidfast7
Bikes: 2010 Cube Acid / 2013 Mango FGSS
Quoted: 1053 Post(s)
Liked 41 Times in 36 Posts
Gott nytt år!
acidfast7 is offline
acidfast7
It depends on how much WLG smells on the lubricant spectrum. A little or a lot?
Old 01-11-19, 05:51 AM
DiegoFrogs
DiegoFrogs's Avatar
Quoted: 169 Post(s)
Originally Posted by acidfast7
Gott nytt år!
Tack! Det samma!
Old 01-16-19, 02:46 PM
u235
u235's Avatar
Quoted: 437 Post(s)
That's not the issue. The grease is there to reduce the chance of the cranks from sticking through eventual galvantic corrosion with the spindle. It in no way contributes to them stripping, getting loose, or falling off provided they are torqued correctly. My last set of square tapered Shimano cranks had a grease glob in the spindle hole out of the box and I recently bought a pair of HT2 cranks and they were pre greased as well. Maybe not all cranks or vendors do that out of the box but the reason they do is logical and mechanically sound. Same reason you can do that on pedals
u235 is offline
Old 01-16-19, 02:53 PM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
Yeah to have two pedals fail on the same side under the same conditions is pretty suspicious. I'm thinking Deal4Fuji is onto something.
jadocs is offline
Old 01-30-19, 06:21 PM
zackzhrd
I use a bio-based grease by WPL (Whistler Performance Lubricants). It's great for everything from pedals and cranks to bearings, bushings, wheels, and headsets.
zackzhrd is offline
Old 01-30-19, 11:35 PM
Darth Lefty
Disco Infiltrator
OP’s been gone for a month, guys
rollingsound514
Bicycle Mechanics
4
04-28-16 07:01 AM
mshred
Bicycle Mechanics
6
06-03-13 07:02 PM
TBSN
Bicycle Mechanics
18
04-15-11 03:33 AM
chummdizzle
Bicycle Mechanics
4
04-17-10 07:04 AM
garethzbarker
Bicycle Mechanics
10
01-25-10 08:49 AM
