Does this gearing change make sense?
Hi All,
This is a continuation of a previous thread (https://www.bikeforums.net/touring/1...ents-tour.html) but a new topic so I am posting as such.
My current Surly LHT has a Deore 48-36-28 crankset at the front and a Shimano 8-speed 11-28 cassette (I don't remember which version) at the rear with an XT derailleur. I am switching to drop bars and in doing so moving to a 9-speed indexed shifter for the rear and a friction shifter for the front. Since I will be replacing the rear cassette it seems to make sense to take advantage of that to increase my lower gear range since I will likely be doing heavily loaded touring in areas that will have some steep climbs. I am thinking of getting a new 9-speed cassette that is 11-34. Does that sound okay/sensible? Would it also be straightforward to swap the smallest chainring from 28 to 24? Or would that be too wide a range for any reason? Presumably if I am using a friction shifter for the front it should not be a problem...? But I am really figuring this out as I go so would appreciate a thumbs up or down from any of you who know more about this.
Cheers
Cheers
Quoted: 18424 Post(s)
Liked 15,581 Times
My LHT has a 24x34 low gear. Just did a ride across PA with some double digit grades. Makes perfect sense. Want to go to a 22 up front, but that will require a new crank.
Likes For indyfabz:
Bikes: LHT disc, Cannondale CAAD8, Cannondale Super 6, Avanti Agressor MTB
Quoted: 26 Post(s)
Liked 16 Times
I put a 36 on the rear of mine. Just means you can't use the large frontring on the lowest 3 rear cogs... but why would you?
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Yep, I've had a 34t largest cog XT cassette for awhile, and just yesterday, I put on a 28t small chainring. I was upgrading the bottom bracket anyways, so the chainring was easy. Works great, but I have a lot more room for a smaller chainring, if I can find one that fits. 🙂
Might as well get as much advantage as possible, when you're climbing mountains with a heavy load. 👍
Quoted: 969 Post(s)
Liked 1,632 Times
Odd that of all the different bikes that have a very broad spectrum of gears in the back a 34T seems to be the most common largest gear. I saw some 36T and 38T and even a 40T rear cog on some mountain bikes but when I questioned if they were ever used they bikers said not really. 34T was just about as big as they ever used in the back. Also in the front it was 28-30 as the smallest crank gears.
I continue to use 11-34 in the back and 42-30 in the front for my Old Geezer rides.
Many of the touring bikes I have seen come through my area have about the same set up but run triples in the front.
Lately I have seen a fair amount of late model touring bikes with brifters converted to friction shifter set ups. I am not sure why...
11-34t is a common choice for touring bikes. I myself ran this setup for a long time.
In the future when your chainrings wear out and you need to replace them, I suggest going for a double chainring setup. Triple chainrings are unnecessary weight.
Quoted: 2604 Post(s)
Liked 1,933 Times
28x34 will give you one lower gear than what you've got now. It shouldn't be much of an issue to change the 28 chainring out for a 24, which gives you a lowest gear about 1.5 "gears" lower. That shouldn't require changing either derailer, though it may take some adjustment to get it tuned.
Just make sure, when you switch to your drop bars, to get a 9 speed triple shifter set.
honestly, i've never been out on a loaded tour and thought........................ "gosh, if only i had fewer gears!"
My thought process is that I top out at 18mph (29 km/h). I am incapable of riding faster than that on flat ground on a touring bike. Those panniers catch the wind like crazy and really hold you back. If I find myself going faster than 18mph, it means I'm on a downhill. At that point I'm coasting anyway. So why do I need the higher half of my gears? I got rid of all these gears and only kept the low half. With only a single chainring there is no front derailleur either. The weight savings and reduced maintenance are worth it.
On the 1x bike I have a 34 chainring with a 11-52 cassette. I'm thinking about changing to a 32 chainring. I find the 34-11 combination useless. It is too fast. By the time I need it I'm already coasting.
Great, thanks for the feedback 👍 I will carry on with that plan then.
Liked 15,581 Times
I spun out of my 44x12 on the High Line heading to Malta, MT. (RD was acting wonky and wouldn’t go into the 11.) Sustained 32.5 mph for several miles. Finally had to dial it back to 28. Helluva tailwind that morning.
Really, you haven't thought that? I have. I rode a triple, then moved to a double, and finally built a single chainring touring bike this summer.
put more emphasis on little gears to get up the big hills....15-90 inches should do.
don't just throw away all those gears, change the ratios to make them usable.
with 3 rings and 9 cogs you have the opportunity to have a nice assortment of well-spaced gears.
never a time when your gears are either too big or too small........you always have one that's just right.
nothing worse that a long day riding loaded, and you can't find the right gear.
that's worth a few ounces and "increased maintenance".
Liked 1,933 Times
I'm not sure where you find flat ground on a tour, and what about wind? Seems to me like most of my touring is climbing or descending. 5% downhill or steeper, yeah, I'm coasting. But I don't mind pedaling to go 25-30 mph (40-50 kph?) if I've got a slight, 1-3% downhill in my favor. Psychologically it makes up for hours climbing steeper stuff at 5-10 mph. And while it's rare, I want to go as far and as fast as possible when I catch the occasional tailwind.
your problem isn't too many gears, it's that you have the wrong gears.
Moving on to the high end next:
On the triple you have the faster 36 and 46 chainrings. On a double you only get the 36. On a 1x I have a 34. The fastest cog on the cassette is always 11. Or on a higher end 1x you are able to use a 10. So the only real difference between the three is whether you ever use a 46 chainring. Back when I had a triple bike I used it maybe five times a year.
Don't forget with a 1x drivetrain you have 12 speeds so the spacing is not too bad.
Liked 15,581 Times
Southern New Jersey and a lot of the Delmarva Peninsula.
I did this over two days last Easter weekend on the way to DE:
Dashboard · Ride with GPS
It actually has a couple of hills in the early miles. Still, there is only about 14.5' of climbing/mile, and the ruling grade for the entire route is just under 3%.
I wouldn't be okay with a setup where an accidental shift to three of the possible gears would break the rear derailleur or maybe even the RD hanger. You are suggesting that right?
Liked 1,933 Times
[Edited to add] And would you be willing to limit yourself to gearing that would have you spin out below 20 mph if the wind was at your back?
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
That a good idea in theory but in practice you don't get lower gears on a triple. Your lowest gear on a triple is 22 front 36 rear. On a triple you can't use a cassette bigger than 36. That's the same lowest gear as in a double. On a 1x, my lowest gear is 34 front 52 rear, which is not quite as low as the others, but very close. So there is not really any difference possible on the low end.
My 19x36 (19/34/42 triple) gives me about an 18% lower gear than your 34x52, if I did my math correctly. My cassette is a 9 speed 12-36. Did a fully loaded, 2800 mile tour this summer with that and I can assure you there were times when I wished I had either a lower low or higher high or an in between step. 1x, 2x, 3x - lots of personal preference going on here but facts are I can always get a higher or lower or both gear than you can with a 2x or 1x. Or, I can get the same range with closer steps. Maybe even higher, lower and closer steps (actually, I think my current set up compared to your 1x does this). I like to shift a lot and I love to customize my drive train to fit the use. Others may not. I can't argue with your personal preferences but I can state as fact that on my triple I can and do go smaller than 22 and that, for me, an 18% lower gear is significant (and I could choose to go even lower).
If I had to give up a chainring doing loaded touring, the big one would get the chop. It is easier to coast down a hill, than walk up it.
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times
My older xt derailleur barely has a long enough cage to pull up that much chain slack. As it is, I had to shorten my chain an extra link to pull the upper pulley off of my 32 tooth cassette. My bike is a little older FYI... (2006) so yours will probably work just fine - fyi...
You should be able to look up the amount of gear inches your derailleur is able to handle.
Liked 15,581 Times
My first touring bike came with a MTB front setup. 44 was the largest. 22 was the lowest. Can't remember what the middle ring was. 11x34 on the back. Never walked a hill in the U.S. with that. Walked a few sections in Andalucia when I encountered some steep grades. (I remember one street sign going into a town warning of 16%.)
This winter I will probably invest in a new crank that can take a 22 small ring. My 40th high school reunion in western Mass. is next June. For my 35th I rode there from northern Vermont and then continued home through the Berkshires, etc. Thinking about doing the same for my 40th.
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
Someayouse must not ever ride down mountains, lol. 😉 Trust me when I say, there are times when you NEED that largest chainring. Coasting downhill is my preference too, but if there's a truck coming up behind me, intending to turn off a busy road, at the same time as I'm crossing his turnoff, I need to either pedal the heck out of his way quickly, or slow down/stop till he gets past. I don't want to lose all my speed, and time, so I'm happy to shift up & pedal harder for a few minutes. 🙂
And don't forget critters. Suppose a bear started chasing you, for some reason. Do you really want to spin out, with no higher gear options, and become lunch? 🤔😁😉
You might hardly ever need the highest gears, but when adrenaline kicks in, you want your machine to back you up. 😎
Quoted: 346 Post(s)
Liked 175 Times
Liked 1,933 Times
Bear in school grounds euthanized at request of Arizona Game & Fish – Parker Live (parkerliveonline.com)
and
Bear Family Takes Over a North Carolina Elementary School's Playground Video (people.com)
