20" Wheel Brompton Titanium Knockoff
Stardust
Palmer
Quoted: 1669 Post(s)
Liked 1,825 Times
Your screenshot image is postage stamp-sized on my monitor and goes to a blurry blob when zoomed.
The Burke 20 titanium folding bike follows the Andrew Ritche pattern and has been around for a while.
Screenshot is quite good on my tablet.
Here is the link for you
https://www.aliexpress.com/item/3300...toreId=1260811
Palmer
Liked 1,825 Times
Stardust
quoting 4th post link ..
"US $1,433.00 - 4,666.00" 1st frame only, 2nd whole bike, I assume..
IDKwhat the Yuan to Bz Real exchange rate is.. floating rates change fast..
55+ Club,...
Bikes: 9+,...
Quoted: 1115 Post(s)
Liked 849 Times
20" frame only: $1,433 USD
20" whole bike: $4,666 USD
EasyTi/2019-Titanium Brompton folding bike (M Type/S Type)3speed US $ 2,800
https://www.ebay.com/itm/EasyTi-2019...Kx3pVmMOitRJvQ
Palmer
Liked 1,825 Times
Very Big Edition
Bromptosaurus (Rex), genannt: Rostinante
They are however no knockoffs but both custom made to order and based on original Brompton frames that got extended. I've ridden both of them - a very grown-up ride, mainly due to the long wheel base. Both ride very different from a normal Brompton. They are slightly different - the rust one is the younger of the two and was made just a couple of month ago, the black one has been made two years ago. The rust one has a slightly shorter wheelbase than the black one but still very long. So a 20" Brompton is possible but the making was quite a job - countless hours went into them - so these are pretty expensive bikes.
Likes For berlinonaut:
Bromptosaurus does look like the BB is going to be 2" higher.. bumping from 16 to a 20" wheel ..
Ending the putting a foot down at stop signs, without getting off the saddle ,
which is a habit I had to develop with my Bike Friday pocket Llama,
which I also must put a foot on the raised curb to stop without shifting off the saddle to put a foot down..
(Now BiFri has redesigned their 20" wheel frames to both be lower BB ..)
Just to clarify the naming: The black one is called Bromptosaurus, the rusty one is called Bromptosaurus Rex (because of it's later date of birth and the motor). There is also an opposite bike by the same maker, a Brompton modified for persons of short stature. It is called Bromptolino and the modification is reversible:
