Bike recomendation
Quoted: 26 Post(s)
Bike recomendation
Hey all,
I currently ride a 2014 Crossrip (specs below). I commute to work on it 2-3 times a week; the round trip is about 16 miles (I drive half way to work to keep the bike ride reasonable). I also ride our local greenways / park trails about 1-2 times. These trails vary from nice pavement, terrible pavement, wide hard packed dirt / paver mix and a little gravel here and there.
I am looking to upgrade and wanted to hear other folks opinions. My requirements are:
- Better braking. Between my Crossrip's cantilever brakes with inline brake levers I cannot stop from the hoods when people pull out in front of me while commuting. To get enough stopping power, I have to shift my hand position to the inline brake levers to be ready for danger spots on my commute.
- Must have rear rack mounts for my commute.
- Upgrade in components from Claris to around 105; I don't care about this as much but I wanted to try gearing with less jumps in teeth
I started at my LBS and was shown the Specialized Sequoia and Specialized Diverge Comp. Both had hydraulic disc brakes and I could stop from the hoods with ease. Both also had holes drilled for a rear rack mount and I think I'd need a special collar on the seat post. The Sequoia rode super smooth but felt slow. I absolutely LOVED the Diverge Comp. It rode a lot smoother than my Crossrip but also felt really fast.
I plan on checking out other bike shops around here to see what other brands have to offer and get more opinions but I wanted to hear what folks on here thought.
Thanks!
Trek Crossrip 2014:
Shifters: Shimano Claris STI, 8 speed
Front derailleur / rear defailleur: Shimano Claris
Crank: FSA Vero, 50/39/30 (triple)
Cassette: SRAM PG-830 11-32, 8 speed
Brakeset: Tektro Oryx 992A cantilever brakes w/Tektro alloy bar-top levers
Tires: 700x35
Thanks!
Trek Crossrip 2014:
Tires: 700x35
Bikes: Two Independent Fabrications, a Niner RLT, and a Trek Domane
Quoted: 10 Post(s)
Liked 16 Times
I commute on a Niner RLT. I was able to mount a rack for rear panniers to the single bolt mount on the brace. It has held up for several week long bike packing trips as well as several years now of commuting. Hydro disc brakes are awesome.
Quoted: 26 Post(s)
The Niner RLT looks interesting. I'd never even heard of the brand but there are a lot of LBS nearby that carry them. What model do you have (I like the simple 2, 3, 4 star system)?
That Diverge Comp is around a three grand bike? May as well throw the 2018 Jamis Renegade Expert in the mix.
Quoted: 26 Post(s)
The Specialized Diverge Comp is $3000.
The Jamis Renegede Expert looks to be in my house with hyrdaulic brakes, 105 groupset and a bigger focus on the rack / fender mounts.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
What is your budget? We'll do a great job spending all of your discretionary income, if you let us.
Quoted: 26 Post(s)
$3000 is about as much as I want to spend on the bike. I already have all the other studf I need: paniers and rack, garmin, cadence and speed sensors, roof rack, helmet, etc.
Noob
Bikes: Gravel: 2018 Specialized Diverge Expert. Road: Trek 2013 Domane Di2, 2006 Specialized Roubaix Pro (retired), MTB: 2014 Trek Fuel EX8 29er, Folder: Dahon Mu P24
Quoted: 12 Post(s)
The Diverge is a great bike. I've had the 2018 'expert' $4k version for a little over a month with several hundred gravel/dirt/pavement miles. Smooth and capable with those 38 tires over some rocky trails as well. I can feel the future shock soak up a lot of bumps and after 78 miles and 5k climb on mixed surface yesterday, not too terribly beat up.
The Comp is also nicely equipped, but went with the SRAM 'expert' for better off-road experience with positive (no side to side lever action) braking and also prefer the bigger shift steps of 1x crank for dirt trails.
Quoted: 26 Post(s)
Noob
Quoted: 12 Post(s)
As for 1x (no crank shifter) vs 2x... For trails, my speed varies quickly and a regular 2x setup would almost always require a lot of double shifts to get the right gear. Not to mention occasional front shifts to prevent cross chaining.
For the road, a 2x with smaller steps is great, and I have that on the road bike, but my Diverge sees at least 50% gravel and dirt for a given ride and that 1x setup with bigger steps is perfect.
I also swapped out the 42t for a 38t front chainring for better climbing and gave up little on the fast end.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
This would be a significant purchase but you are not getting a cheap bike.
This is something you will have for years, ride the heck out of and can upgrade as needed.
-Tim-
Quoted: 10 Post(s)
Liked 16 Times
I have a Niner RLT with Sram Force. It was the first round of bike and came with cable disc brakes due to SRAMs recall. I upgraded to hydro after a couple of years and a couple of thousand miles. It is similar to the two star version now.
Quoted: 26 Post(s)
On the Diverge Expert with SRAM double tap, both levers only move front to back and not side to side like Shimano shifters. When you want solid braking in tricky undulating terrain, the confidence of single axis movement is nice.
I think I will ride more paved trails and road so the 2x makes more sense to me.
Quoted: 26 Post(s)
Hit the Trek LBS today and they put a Domane SL 5 gravel disc in front of me. It was carbon, 105 groupset, hydro brakes. It was fun to ride but sadly, no rack mounts.
They ended up suggesting I get another Crossrip (the level 3) with a carbon fork, 105 groupset and hydro brakes. They did not have any on the floor but I guess I should check it out.
Noob
Quoted: 12 Post(s)
I like my Trek Domane road bike, and sadly, when I asked trek about their gravel bikes at the local trek store, the tire clearances were nothing like the specialized diverge carbon, so I went with the Diverge. Maybe next year they will increase clearance like specialized did with the Diverge for 2018.
Bikes: 1972 Raleigh Professional, 1980 Raleigh Gran Sport (frame only), 1989 Diamondback Apex, 1997 LeMond Zurich, 2018 Specialized Diverge running R8020 Ultegra.
Quoted: 46 Post(s)
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I finally came to the conclusion if I am doing a lot of road miles and group rides I need 2x (both for the speed range, and for the tight gear jumps).
If I am using it as a dedicated gravel (or even CX) bike that doesn't need the top end or the tight gearing - 1x is fine for me.
1x was designed for mountain bikes where the derailer interfered with the dual suspension and constrained the seat tube design. None of that matters to a gravel/CX bike, but it has become the current fashion.
FYI - Niner is well known in the mountain bike world. They make great stuff.
I saw a good video on them. Guy bought a RLT (Steel), and didn't particuarly like it, then bought an RLT RDO (carbon) and fell in love. There is a big weight difference between the two.
Noob
Quoted: 12 Post(s)
So I'm planning on getting the Diverge Sport Carbon and was wondering about the best $$$ value/cost trade-off on initial upgrades. That OEM Wheel-set has to go as they're boat-anchors. Also I'm unsure of the group set; FD, RD, shifters and cable Disc calipers. I'm thinking get a nice ~1500-1600 gram wheel-set and see how the rest works out. Maybe even add a COBL GOBL-R (cobble gobbler) seat-post. Ultimately I'd like to go Ultegra, but that might have to wait until further down the road.
The CGR post was compared against other posts and actually did not do all that great, might have seen it on a web page or youtube, complete with graphs and measurements. fyi...
Noob
Quoted: 12 Post(s)
Noob
Quoted: 12 Post(s)
I agonized over 1x vs 2x for a while.
Yeah, that would be this guy Clint: https://www.youtube.com/user/clintg37 I've followed him for a bit as well.
Quoted: 46 Post(s)
My plans for the Diverge are to ride (70/30)% road/gravel and I did a 25 mile test ride on the Diverge Comp and really liked that bike, but wished they offered an Ultegra version. Then I thought that maybe I'd buy the Sport model and upgrade the wheel-set and swap out the Shimano stuff to Ultegra. I'm thinking I could end up 1/2 between the Comp and Expert price wise and have a nice Ultegra 2x based road/gravel machine. I wish they just offered the Expert in either a 1x or 2x version...
Seeing the first pic, it just looks like a Domane with wider tyres.
Quoted: 46 Post(s)
I noticed that you're in North SD County, are you familiar with the GravelStoke Group on FB?
