Custom insole suggestions?
Time to replace my custom Footbalance insoles and the shop in my area don't carry them anymore, so I'm looking at other brands that do custom molded insoles.
Will probably have it done in Los Angeles.
Any recommendations on what other brands to consider?
I'm only considering custom/molded insoles.
Thanks!
Thanks!
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
How about going to a Podiatrist in your area, Las Vegas?
https://www.apma.org/Patients/FootHe...ItemNumber=988
Likes For Garfield Cat:
Im old .. I got Birkenstock (3/4) insoles , in the US, at my local store in Eugene ,
now you have to order them, direct, from Germany/.
Clark W. Griswold
Quoted: 4330 Post(s)
Liked 3,955 Times
Have you tried SuperFeet? Not custom at all but work really well for a lot of folks!
Quoted: 426 Post(s)
Liked 695 Times
I had plantar fasciitis a few years back. The foot doc recommended Powerstep ProTech Control insoles (got a cortisone shot also). After the cortisone shot, the foot problem is gone, still using those insoles in all of my shoes and boots and can really tell the difference if I put on a pair of shoes without them. You can go for the Pinnacle for a little less--the Pinnacle doesn't have the heel pad. Not custom, but made to fit your shoe size (no trimming), and they have great arch support. I've had mine for around 3 years, and they are still going strong-bought several for diff.shoes and boots. Link: https://www.powersteps.com/shop-prod...orthotics.html
I like the Fizik 3D Flex Moldable Cycling Insole. I have been using the arch support to relieve the pressure on my metatarsal arch. Molded in the oven and conformed to my high arch. Low volume for my cycling shoes.
I think too expensive for my simple needs. The consultation fee + insoles was around $300+ last time I checked.
I say 'simple' because the Footbalance insoles are nothing complicated, and they have worked really well for me.
@Squirrel. Those Fizik insoles look interesting. Going to research on those.
Thanks all!
I've had very good luck with Sole.
They are oven molded and have helped a lot.
Ive tried lots
Super feet, powerstep and several others and sole has worked by far best for me.
They have several models with different volumes for the best fit without the expense of truly custom products.
REI sells them but if you have no access to a store to try them then my recommendation is to order a few different models from a place with a good return policy so you can try them out before you bake them and really commit.
Foot problem are a nightmare
Best of luck...
https://yoursole.com/us
Ive tried lots
Best of luck...
Gravel Rocks
I've been very happy with my RETUL molded insoles which I got as part of a bike fit.
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
What brands or products are good for relieving pressure and pain around the base of the big toes ???
So, if you can't get those, in my other biking shoes I tried Superfeet (the BLACK variant, at the recommendation of Superfeet support) that REI had on sale. Those aren't custom molded, but they were less expensive and seem to feel just as good on my SPD type shoes on my touring/beater bike, compared to the Footbalance on my SPD-SL shoes on the road bike.
I'm currently using aetrex insoles. About 50 bucks a pair. They use a pressure mapping computerized pad you stand on to tell you which insoles you need. It's like the dr scholls set up, but actually works.
Powerstep Original Full Length Orthotic Shoe Insoles
I like these because they can make any shoe feel like you're walking on air. Support but with just the right amount of cushioning to make your feet the last thing on your mind. Even after a full day of standing or walking, they turned any shoe into clouds of joy. I even use them on my mediocre cleats, and they go right up to size 48 and beyond.
Just take caution they take up some space in the shoe, so you may need to choose a half size larger -- which is what I do -- depending on how snug you like your fit.
The only con is they can be pricey.
Quoted: 57 Post(s)
Liked 41 Times
You would need to go to a podiatrist that knows cycling. I went to multiple podiatrist for my daughter's soccer ailments and they hadn't a clue when I asked them about cycling with clipless pedals. They tried hard to explain their treatments but it was clear that they were trying to use running as a base for their counntermeasures.
After a lot of
self education, I purchased a foam molding kit from amazon and molded some plaster casts of my unloaded feet. Purchased a few types of heatmolded insoles. Among which were the "sole" insoles. My feet have never felt better. I wish that I could go to someone to get this type of service, but it would require multiple visits to someone who really knows the issues involved. All of which I don't have the funds to explore. I would encourage others to "self medicate"
Quoted: 478 Post(s)
Liked 87 Times
I'm thinking that the feet are one thing and maybe there's more to it. From what I understand, the body tends to compensate and tries to self-adjust for "weakness" on one area.
Several events: college cross country coach sent me to a podiatrist and I got the custom orthotics made of hard plastic with no give.
Then years later a orthopedic guy, famous for working on the L.A. Lakers, he showed me how my flat feet and knock knees will limit my long term sport of distance running.
Then twenty years later, the pro bike fitter asked me to walk up and down the hallway. That right leg is turning inwards, and a history of an injury.
Now in 2018, the Yoga guy says I'm way out of alignment and to get out of that "compensatory" status, go for stretching and posture correction. So now stretching and holding the pose.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 758 Post(s)
Liked 809 Times
I have a long history of using insoles, faux-custom insoles, real custom insoles(podiatrist made..), plantar fasciitis...
BTDT with the inexpensive (non-podiatrist) "custom moldable" insoles.. Frankly, not impressed..and went back to more conventional inserts like Superfeet, Sole(not molded, worn stock), Sof Sole, Spenco Total Max (hard plastic arch, not bendable foam Max version)...
With respect to the faux-custom insoles..If you think about it for a minute, the "put them in the oven and then wear them to make for a custom fit".. logic has a fatal flaw.
Thought (and actual) experiment:
1) buy into the marketeer's "put them in the oven and then wear them to make for a custom fit"
2) heat them up
3) take them out of the oven
4) apply a good amount of force to the arch..say, take the heel of your hand and press down on the arch
5) maintain force until the thermoplastic arch cools off and re-sets it's shape.
6) you now have what was formerly a good arch and you've got a flatten-out insole with minimal arch
7) hmm..that sucks as you no longer have the stiff arch support you need.
Same thing happens when to heat them up and insert them into a shoe and walk around. Your foot-arch flattens out (foot over-pronation) the warm-flexible insole arch, the insole becomes flatter from the force, the insole cools off and re-sets its shape, and you've ruined, or at least reduced, any support the insole might have offered. The arch is surely not going to rise up, or maintain its shape, to support your arch..why would it??
It might work for some folks, and it might not, but it certainly doesn't make any logical-mechanical sense. No doubt the marketeering claims of custom..and cheap..plays well in the marketplace though...as people love that sort of thing. And once they are sold, you've molded them, and they don't work you can't return them..so..it's all good for the seller.
Some good insoles have been mentioned. The key is a stiff, non-flexible arch (not just thick flexi-foam) that is high enough to fit your arch, support your weight and keep your arch-foot from over-pronation.
...it's your money..wasted or not, it supports the economy..
2) heat them up
Quoted: 478 Post(s)
Liked 87 Times
Its not just the feet. More like taking a look at the forest and then the trees.
All of them: cross country coach, podiatrist, orthopedic surgeon, pro bike fitter, the yogi. Separate but distinct, similar in many ways.
Lesson learned? cycling is fun and even habit forming to a high degree. Forget the "high" and go for the long term benefits.
