1954 Schwinn Hornet takes on water after a rain?
Old 05-01-19, 12:26 AM
Rollfast
What happened?
Rollfast's Avatar
Quoted: 1835 Post(s)
Liked 292 Times in 255 Posts
I've found this out after turning it over a couple times. Not something that happens with my other bikes that sit outside. Why?
I have to take it to the shop for BB bearings, might as well fix this too. She's 65 and has a double jointed kickstand as it is.
Rollfast is offline
Old 05-01-19, 05:44 AM
mixteup
mixteup's Avatar
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times in 27 Posts
It's getting in from somewhere - Seat tube, head tube, or bottom bracket.
Some folks use silicone caulking at the seat post exit, etc.
For the bottom bracket, about the best you can do is to grease it well with waterproof boat trailer grease.
mixteup is offline
Old 05-01-19, 06:40 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,834 Times in 2,293 Posts
During the BB work ask the shop to drill a shell drain hole.
Water gets into just about anything given time and motivation. We often see drips coming out of bikes during working on them. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 05-01-19, 07:12 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
Does it have an open top seatpost with a wrap-around saddle clamp? That could be the water's entry point.
HillRider is offline
Old 05-02-19, 12:11 AM
Rollfast
What happened?
Rollfast's Avatar
You tell me.
Rollfast is offline
Old 05-02-19, 12:12 AM
Rollfast
What happened?
Rollfast's Avatar
I really don't intend to drill a drain hole in this bike.
Rollfast is offline
Old 05-02-19, 05:47 AM
HillRider
Yes, it seems to have an open top seatpost and, if you are unwilling to drill a drain hole, expect water and rust, in that frame. It's lasted 65 years so far but the water will see to it it doesn't last another 65.
Old 05-02-19, 01:24 PM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 942 Post(s)
Liked 656 Times in 370 Posts
That's up to you, but I wouldn't hesitate to do it. If water is getting in, it's best if it has a way to get out.
Dan Burkhart is offline
Old 05-02-19, 03:29 PM
Rollfast
What happened?
Rollfast's Avatar
What do you mean by 'open top seat post'? It's no different than any other bike I have ever owned. I don't have any such problems with my Rollfasts...I think it's missing a seal in the head tube or something as it didn't start happening until the stem and fork separated earlier this year and I had it in for repairs. I've owned this bike for nearly two years.
Rollfast is offline
Old 05-03-19, 05:32 AM
hokiefyd
hokiefyd's Avatar
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times in 568 Posts
An open top seat post is essentially a hollow tube. Most modern seat posts are closed at the top, with the seat rail clamp integral to the seat post itself. By the design of your seat (wide, hangs low), it's probably not likely that water is entering here.
Headsets don't typically have "seals". Some of them do, but I don't think you Schwinn's would by design. That's not to say you couldn't put a little sillycone somewhere up there, if you knew where water was getting in.
I think you really have three choices, to keep this frame in the good shape it's in now:
  1. Store the bike inside, or covered.
  2. Drill a drain hole in the bottom bracket.
  3. Try to seal the point of entry (could be many places).
I don't think #3 will be very effective, at least not long term. #s 1 and 2 are probably your best best. #1 will save the rest of the bike as well (chrome, paint, etc) from the elements. #2 will at least let the water get out, after it's found its way in.
hokiefyd is offline
Old 05-03-19, 06:19 AM
bakerjw
Quoted: 169 Post(s)
Liked 84 Times in 62 Posts
One other thing that I would recommend is to treat the internal frame with some of the rust preventative treatments that are out there on the market. I treat all of my steel frames with them to ensure that they last as long as possible.
FWIW. I would never store a gem like that bike in the direct elements.
bakerjw is offline
Old 05-03-19, 07:57 AM
Rajflyboy
Rajflyboy's Avatar
Bikes: Orbea
Quoted: 917 Post(s)
Liked 205 Times in 170 Posts
Beautiful bicycle ��
Rajflyboy is offline
Old 05-04-19, 01:56 AM
Rollfast
What happened?
Rollfast's Avatar
My house is tiny and I have four others out there, soon to be seven others. My avatar has been outside for maybe 12 years now. I don't think the housing inspector would like me to keep 3 Schwinns, 3 Rollfasts, a Shelby and a J.C. Higgins in the house...and they are all daily drivers.
It's not crazy like the guru who had 92 Rolls Royces...too many enablers in togas for him, I build these to ride. If I could build a roof over them from the side of my shed I would but that's really not happening, and I doubt Darla was stored any different before me except for being in Arizona.
Rollfast is offline
Old 05-04-19, 02:20 AM
Rollfast
What happened?
Rollfast's Avatar
PS The question had nothing to do with draining the water, it was why it's there in the first place and that's a brand new one on me after 45 years.
Rollfast is offline
Old 05-04-19, 07:57 AM
Deal4Fuji
minimalist cyclist
Deal4Fuji's Avatar
Bikes: yes please
Quoted: 1119 Post(s)
Liked 1,638 Times in 943 Posts
I have a couple of older bikes with open seat posts like this Raleigh Olympian. I also like cut-out saddles so It's imperative I have some type of cover to keep water out when the bike is in the rain. A pretty simple method is to get a large headed plastic screw from Lowes or HD and glue it over the seat post hole.
Deal4Fuji is offline
Old 05-04-19, 01:42 PM
FiftySix
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times in 795 Posts
You tell me.
Is that bike supposed to have a washer above the top bearing race, but under the locknut on the headset?
I was looking at my bike with a threaded fork and if that washer would be missing, water would funnel in past the inner I.D. of the bearing race even with the locknut present.
Scroll down to mid-page in first link
https://custommotoredbicycles.com/stems_goose_neck_threadless_headsets_1inch1_18_inch
https://www.ebay.com/itm/1-Bicycle-H...-/110939208460
On second thought, I think all that would happen is the steer tube threads would get rusted.
FiftySix is offline
Old 05-05-19, 08:26 PM
Rollfast
What happened?
Rollfast's Avatar
Ah, somebody got it.
Rollfast is offline
Old 05-05-19, 08:28 PM
Rollfast
What happened?
Rollfast's Avatar
You're on the right track. It's in the shop now so money has been thrown, it will work out.
Rollfast is offline
Old 05-06-19, 12:21 PM
Delmarva
Delmarva's Avatar
Quoted: 10 Post(s)
Liked 5 Times in 4 Posts
If it's a collectible bike that you want to keep original then the solution would seem to be storing it inside.
Delmarva is offline
Old 05-09-19, 10:09 PM
Rollfast
What happened?
Rollfast's Avatar
If the next owner wants it that way after I die, that's up to them. The fenders were from a '48 and repainted, the rack is a repro from Bicyclebones and the tank I'm preparing had battery damage below the horn. I'm not a museum, and this small house is already chock full o' stuff. The housing authority won't stand for it either, and I have EIGHT bikes.
But thanks for all of your concerns. We've had rains all year and this was a new problem that surfaced after I had the stem and fork rejoined.
Rollfast is offline
Seizedpost
Bicycle Mechanics
35
08-26-16 09:23 AM
PatrickGSR94
Bicycle Mechanics
19
06-30-13 06:18 PM
RiverHills
Bicycle Mechanics
19
06-27-11 08:38 PM
I_like_cereal
Bicycle Mechanics
4
03-20-11 11:42 AM
Aquaman5K
Bicycle Mechanics
28
01-30-10 08:23 AM
