Will 10 speed go faster than 9
Old 08-13-07, 04:50 AM
brundle_fly
Will you be able to reach higher speeds on a 10 speed set up than a 9 because of the extra gear?
brundle_fly is offline
Old 08-13-07, 04:55 AM
dcvelo
Pretend Racer
dcvelo's Avatar
No
dcvelo is offline
Old 08-13-07, 04:57 AM
dpr
Insect magnet.
dpr's Avatar
Bikes: Trek 2008 Madone 5.5 Pro, Bianchi 2008 Axis
No. Only if the 9 speed cassette/freewheel has a smaller sized cog on it. But both a 9 and 10 speed might have the same 12 tooth cog.
The principle behind more gears being better is that it enables a more gradual transition between gears. This helps the rider keep the same smooth pedaling action.
dpr is offline
Old 08-13-07, 05:01 AM
dcvelo
Pretend Racer
dcvelo's Avatar
RIght...both my 9 speed and my 10 speed cassettes are 12-25....so the biggest and smallest gears are the same.
dcvelo is offline
Old 08-13-07, 06:30 AM
John H.
Bikes: LOOK 585, Colnago Masterlight, Gunnar Crosshairs
The volume on my stereo goes to eleven.
John H. is offline
Old 08-13-07, 06:40 AM
TCR
Riding Heavens Highway
TCR's Avatar
Bikes: '04 Giant TCR
Only if it's made out of carbon.
https://vvbc.us
TCR is offline
Old 08-13-07, 06:45 AM
Reynolds
Passista
Reynolds's Avatar
Quoted: 866 Post(s)
Liked 720 Times in 395 Posts
Right, and even if the 10 sp had an 11, probably you could use it only downhill, unless you were at a high training level.
Reynolds is offline
Old 08-13-07, 06:46 AM
Bantam
Bantam's Avatar
Bikes: Trek 1500
Helps to keep a smooth spinning action in the middle of the cassette.
Bantam is offline
Ryleeryno
Über Member
Ryleeryno's Avatar
Bikes: 2005 Trek 5000 (the last OCLV)
Yes because it will make your wallet lighter.
Felt F3c
Me
Ryleeryno is offline
Old 08-13-07, 10:09 AM
dcvelo
Pretend Racer
dcvelo's Avatar
Only valid if ride with wallet.
Hmm...will it make my car faster then....?
dcvelo is offline
Old 08-13-07, 10:11 AM
55/Rad
Former Hoarder
55/Rad's Avatar
Bikes: Seven Axiom, Felt Z1, Dave Moulton Fuso
Quoted: 16 Post(s)
Liked 7 Times in 7 Posts
Hmmm...my stereo only goes to 10 but starts to sound funny around 6.
55/Rad is offline
Old 08-13-07, 10:14 AM
fhall1
fhall1's Avatar
Bikes: Trek 1500
Spinal Tap was the first thing I thought of when I saw the thread title too!
fhall1 is offline
Old 08-13-07, 10:18 AM
haimtoeg
Magnesium Dogmatic
Bikes: Look 585 Ultra, Pinarello Dogma, Pegoretti Duende, Orbea, Cannondale Capo
Only if you upgrade the engine.
haimtoeg is offline
Old 08-13-07, 10:37 AM
AlanS
Source Of All Knowledge
AlanS's Avatar
Will 10 speed go faster than 9?
Yes, exactly 10 percent faster.
AlanS is offline
Old 08-13-07, 10:50 AM
boyze
Your average speed will go up because you can spin at the sweet spot longer. Try riding an undulating course in only one gear, and then with 2 gears and so on. You average speed will likely increase. Of course, each added gear has diminishing effects.
boyze is offline
Old 08-13-07, 10:52 AM
timmhaan
more ape than man
timmhaan's Avatar
Liked 2 Times in 1 Post
actually, quite a few riders of fixed gear bikes report exactly the opposite.
timmhaan is offline
Old 08-13-07, 11:38 AM
2WheelFury
Cat 6 Wheel-Sucker
2WheelFury's Avatar
Bikes: Pinarello, Cannondale, Peugeot
Sheldon Brown's site says it best:
"How many gears do I need?"
"Answer: One."
As long as your gearing is set up correctly for you, your cadence and the grade so you can make best power, that's the only gear you need. More gears on the cassette only give you more options (and a better chance of choosing the wrong one, IMO).
I currently only run six gears in the back of mine, FWIW. Maybe I'll add more, maybe not. Haven't decided, but I don't think it really hurts me either.
2WheelFury is offline
Old 08-13-07, 05:09 PM
kensuf
My idea of fun
kensuf's Avatar
Bikes: '06 Litespeed Tuscany, '02 Kona Lavadome, '07 Giant TCR Advanced, '07 Karate Monkey
Quoted: 41 Post(s)
Liked 59 Times in 36 Posts
No it won't because the extra cog will cause a venturi effect at your rear dropouts thus slowing you down an extra 1-2%. And if you have a carbon frame you run a risk of an implosion if you're down under (the venturi effect goes counter-clockwise down there, just like a toilet flushing).
kensuf is offline
Old 08-13-07, 05:13 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Yes, this is the Great Fixed Gear Paradox: you stop worrying about whether you're in the right gear or not because you're always in the wrong gear.
caloso is offline
Old 08-13-07, 07:40 PM
jamiewilson3
Bikes: Parlee Z4, Storck C1.1
No, the speed isnt in a percentage faster. It is 1 faster, just like amps are 1 louder.
jamiewilson3 is offline
Old 08-13-07, 08:09 PM
johnny99
Quoted: 104 Post(s)
Liked 5 Times in 5 Posts
More gears can be useful if you spend a lot of time in high speed pace lines. If you ride mostly by yourself, then you won't notice the difference.
johnny99 is offline
Old 08-13-07, 08:11 PM
Tappets
almost kosher
it really depends on how fast you pedal.
and if you put air in your tires. that helps too. i forget a lot.
Tappets is offline
Old 08-13-07, 08:13 PM
dirtypete
come on, it's just a marketing ploy to get us all spending more cash. i mean, there's not many things on a bike that can be improved, but wow, they always seem to do it! funny, that...
dirtypete is offline
Old 08-13-07, 08:31 PM
grahny
hobo
grahny's Avatar
So does my amp!
grahny is offline
Old 08-13-07, 09:05 PM
55/Rad
Former Hoarder
55/Rad's Avatar
Quoted: 16 Post(s)
Originally Posted by grahny
So does my amp!
I bet there are some tubes in there.
55/Rad is offline
