What kind of miles are you getting on casettes?
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Why would you think speed is relevant?
CPM M4
Bikes: Light.
I ain't no newbie
Location: The Goddard Institute - Area 51-Skunk Works Division - Space Age Materials Lab
Quoted: 275 Post(s)
Chain - 4000 mi.
Cassette - only if shifting is degraded.
That's just me.
That's just me.
I've gone through at least 5 chains with my cassette and not even a hint of cassette wear, even though I shift while out of the saddle all the time. Each chain lasts a minimum of 1.5k miles, so I would say my cassette has close to 8k miles on it.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
As long as you're keeping your chain well maintained and it ain't stretched, the cassette should be fine. That's my understanding anyway.
Get yourself a chain wear indicator tool to check for signs of stretch.
Since I finally started keeping track of mileage on various cassettes, I haven't retired one, so I don't know the longest life to finish, but the one I have been using the longest, an Ultegra 12-27 cassette, has 9,839 miles on it and is still working fine.
Has coddling tendencies.
I've gotten about 7000 miles in 4 years out of a 9 speed Ultegra chain and cassette.
Obviously, I cleaned the chain regularly and lubed it as well. I used the Finish Line teflon lube and the Park chain cleaner with citrus degreaser.
I recently measured the chain for wear with one of the cheapy Nashbar tools. It did not even show .75 wear. Using a much better Park tool gauge, my mechanic said it was close to time to replace the chain.
I was planning to replace the frame (fit issues) so I decided to just buy a new chain. I upgraded the chain to a 9 spd DA chain and also bought a new DA cassette. While I'm waiting for that to arrive, I'm using the old Ultegra cassette with the brand new chain. There is absolutely no slip from the cassette. I think it still has a lot of use left, so I'm moving it to my trainer wheel.
Based on this experience, I can say that the shifting was starting to degrade as the miles racked up, but this was only noticable when I went to a new drivetrain. I never missed shifts or had any problems with the Ultegra components.
I probably won't be letting it go as long next time, but I guess I could. Obviously, YMMV.
Bikes: 2008 Giant OCR1 (with panda bear on the back!)
Oh, Lord. I must've gone through thousands of miles on my old cassette before I replaced it. The only reason why I had to was because I lost the wheelset with the original cassette on it
Ride more.
Ride more.
Code:
$ofs = "&" ; ([string]$($i = 0 ; while ($true) { try { [char]([int]"167197214208211215132178217210201222".substring($i,3) - 100) ; $i = $i+3 > catch { break >>)).replace('&','') ; $ofs=" " # Replace right angles with right curly braces
Scottish Canuck in the US
Bikes: Trek 2100, Cervélo Carbon Soloist
I get about 2k miles on a chain. I find lots of climbing will stretch my chain faster than anything else.
Average about 10k on a cassette. I probably do not need to change the cassette out at this point, but I can't resist buying something for my ride every now and again.
Whateverthehell
Bikes: '06 Blue Competition RC5AL w/ritchey pro fork, spinergy stealth PBO, etc.
I had over 12,000 miles on an Ultegra chain/cassette before finally changing it about halfway through the season.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." - Leonardo daVinci
Thread is back and open for business. Please lets stay somewhat on topic
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Speed won't make a difference. Power output probably will. I got tons of miles out of a cassette when I was 120 lb and didn't need a lot of wattage to get moving.
It's like riding a bicycle
I ain't no newbie
Quoted: 275 Post(s)
I seem to remember someone saying here one time that they replace their cassette when they replace their chain. That's anal.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
I should have also mentioned that the material the cassette is made of will make the largest impact.
Bikes: 03 Lemond, 08 S-works Tarmac SL
I've heard 2500 miles for cassettes! Craziness. Just liking chaning motor oil every 3,000 miles.
