Ear Protection for the Cold
Quoted: 32 Post(s)
Good morning all.
I just finished a 22 mile ride with temp at 39 degrees. It was chilly out so I went with the baklava but as I got into the ride, it was too hot for the baklava but I needed something for my ears.
Any suggestions? I tried a hand band once but it was way to tight and ended up giving me a headache and hurting my ears.
Thanks
Thanks
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Good morning all.
Thanks
Thanks
It has a strap to close it under your chin.
https://www.discountsafetygear.com/ha...liner-ok1.html
Fred "The Real Fred"
Time to fabricate, with the help of a person with a sewing machine.
was a piece 'helmuffs' a little triangle of fleece and nylon and a strip of webbing
that stayed in place by the helmet straps and covered your ears .
think they were a short lived production.
there is also the traditional cool weather cycling cap,
added some stretch jersey to cover back of neck and top half~3/4 of the ears.
Quoted: 52 Post(s)
Liked 17 Times
Good morning all.
Thanks
Thanks
Upgrading my engine
Quoted: 125 Post(s)
I have a skull cap and although it's not really designed for cold weather, I find it to be perfect for the type of ride you're describing- cold but not too cold.
ride for a change
Bikes: Surly Cross-check & Moonlander, Pivot Mach 429, Ted Wojcik Sof-Trac, Ridley Orion. Santa Cruz Stigmata
this:
https://tinyurl.com/99f2y89
Craft windstopper beanie. It's really thin, wind proof is on the front. fits under a helmet.
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
Bikes: 1987 Schwinn LeTour; 1992 Schwinn Impact; 1990ish Trek 2100
I wear a pair of 180s; earmuffs that wrap around the back, not the top of the head. Not terribly comfortable- at least mine aren't- but tolerable and they work very well w/ a bike helmet.
I love my Endura headband https://www.endurasport.com/Product.a...109&prod_id=22
Just thick enough to keep the ears warm enough. Fits perfectly under a helm.
all-weather commuter
I just use a bandana. Costs about $2. Works down to about 35F. Then I use 2 bandanas. ($4, English majors) That works until it gets cold enough that I switch to my ski helmet.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
I found a Champion brand runner's beanie at Target for $12. It is polyester fleece and spandex and covers your ears, forehead, and further down the back of your head than a cycling cap but is thin enough to easily go under a helmet. I find that it is perfect for that gap when a cycling cap isn't enough and a balcava is too much.
This isn't the exact same one, but is very close.
If you are looking for lighter, less expensive balcavas, check out a motorcycle shop. They have helmet liners which are very similar to a balcava you might get at a bike shop or running store, but at about 1/2 the price.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
I have a thing I got from Nashbar that's basically a stretchy fabric tube. I can wear it just around my neck, I can pull it up over my mouth, I can pull the back up and over my head so my face is sticking out but it covers my hears and front of my neck (this is the way I usually wear it).
I don't know if they still sell it, I can't find it on their site.
Searching around, the closest matches I can find are for neck gaiters. Here's one:
https://www.idahomountaintouring.com/...aiter-1482.htm
the nashbar one was really cheap, < $10 IIRC, and a little more versatile (but probably a bit less warm) than that one. I've been wearing it for 5 years now.
Work: the 8 hours that separates bike rides.
Quoted: 143 Post(s)
Liked 23 Times
Cover your ears and impair your hearing when cycling? OMG, you might not not hear a pin drop! The horror, the horror.
Quoted: 7348 Post(s)
Liked 2,473 Times
Walz caps are good for on the bike and off.
I have this one in houndstooth. I get a lot of compliments.
https://walzcaps.com/caps_wool-earflap.html
Pearl izumi head band or thin polypro hat. For me , one size does not fit all. You can find some large/ x large out there.
Bikes: Specialized Sirrus Elite, Raleigh Revenio 3.0
May be a little expensive, but with the helmet on this unit came through big time last winter. Actually wore it yesterday on a 28 mile ride, the temps were in the low 50's and it performed perfectly.
https://www.campmor.com/the-north-fac...ci_kw={keyword**
One Man Fast Brick
Bikes: Specialized Langster, Bianchi San Jose, early 90s GT Karakoram, Yuba Mundo, Mercier Nano (mini velo), Nashbar Steel Commuter, KHS Tandemania Sport
Good morning all.
Thanks
Thanks
I use https://www.amazon.com/gp/product/B00...ls_o01_s00_i01 and I love it. It's a gaiter, like the previous poster mentioned. I can pull it above my ears and sort of tuck it under my helmet. Chin strap helps keep it up as well. Works great.
Quoted: 5224 Post(s)
Liked 3,584 Times
cycling specific headbands to start with ...
I have one of these it fits under my helmet it is a little tight but I do have a FAT head
https://bontrager.com/model/09255
