Front axle support for Wahoo/Zwift
Quoted: 35 Post(s)
Liked 11 Times
I want to get my front tire off my trainer, I could use the space and really don't need it
is there anyone who has made or purchased a support for the front of my trainer bike,
maybe supporting the axle so I can get rid of the front wheel
I don't want to buy the climbing thing that wahoo sells,
Liked 2,981 Times
You could mount this on a wooden built structure to achieve the height desired...
https://www.amazon.com/CyclingDeal-B.../dp/B07BSFF86Y
Or do the same with this and some plywood support under it..
https://www.amazon.com/CyclingDeal-B.../dp/B07VQMJP71
-Oh Hey!
-Oh Hey!
Quoted: 35 Post(s)
Liked 11 Times
thanks for that
I ordered one of those brackets, will mount it into a post with a swivel on it, should clean up the pain cave and let me move around the
bike easier
I'm thinking a 6" diameter pipe with a base and cap plate then mounting the bracket to a piece of wood with a teflon pad under it
so it can swivel a bit.
maybe also a piece of pvc pipe, I have a big piece of 6" in the yard , use that as a spacer off the floor
