1980 Semi-sloping Fork Crowns
Quoted: 112 Post(s)
Liked 8 Times
I am sticking to semi- sloping full crowns because open crowns, flat and full sloping ones have no appeal to me.
Ishiwata 555-Oval 28/20
There is also a 565 with a straighter line from fork blade to crown. Looks like a Cinelli MC.
Ishiwata Catalog pdf on the bottom of this post.
The Bocamas: VeloBase.com - View Single Frame Part the upper has 27.5/20mm sizes for forklegs and the lower has old 28.5/16.5mm sizes.
Cinelli MCA
Cinelli MR:145 grs 28.5/16.5
Cinelli MC:153grs 27/20
Everest
This is the Haden Europa I have on a custom build from 1980: 27/20 27.5/20 29/16
Zeus:the middle is 29/16 145 gr., on the right is 27.5/ 20 140 gr.
The 2 on the right are Davis
Columbus
Cinelli MCA
Everest
Columbus
Quoted: 3814 Post(s)
Liked 3,345 Times
Milremo (at least four patterns)
Takahashi
Agrati (at least six patterns)
Takahashi
Quoted: 112 Post(s)
Liked 8 Times
Agrati
Roto on the top right
The following 4 pics are for bike brands:
Vitus Continental Crown on the left middle.
Trek
Benotto
Before 1972, these Colnago Crowns have a C around the leaf, 1972 and after, no C.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Fork Crowns - Odds and Ends - Not All Semi-Sloping
@juvela and @jvhed
Milremo was a brand name for primarily private labeled bike components and accessories. The brand was shared by Cycles Andre Bertin in the French market and Ron Kitching in the UK.
They shared a lot of the private labeled items like pedals, hubs, rims, bars, stems and so on in both countries but had specialty products that were sold only in their respective markets.
Milremo made nothing. The name came from the Milan-San Remo early season Italian classic.
The fork crowns pictured above were made by several different manufacturers. The full sloping crown was probably made by Davis but several other manufactures in the UK made that style too. The crown in the upper right corner is probably an Ekla?
The Milremo dropouts were made by Mavic or at least made for them.
Ekla crowns and lugs were popular in the UK during the 40's and 50's. They appear to still have been available in the late 60's or early 70's.
Ekla 23 Bottom view - no idea what the top looks like.
Wagner crowns were available in a wide variety of styles and were popular in many European markets plus with US builders up into the early 1980's. The better quality crowns were made of forged steel. The cheap ones were stamped steel.
The ubiquitous DP+ chevron top model used on 1,000s of mid range Motobecanes and many others during the 70's.
Lest no forget Nervex crowns. They also made a variety of styles. The two most common ones in the 60's and 70's were the Professional and the Dubois models.
Nervex Profession crown.
Two versions of the Nervex Dubois crown. The chevron top was used on PX-10s for years.
Cinelli Twin Plate Crown. Masi used these on some frames in the early 70's.
This is a fake twin plate crown on a Masi.
Twin plate crowns were elegant but a lot of work to braze and finish.
Maxed out at 10 pictures. See my next post below for more fork crowns.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
verktyg
Liked 1,238 Times
More Crowns
Swiss made George Fischer crowns were used on top end Italian bikes like Masi, De Rosa and others.
From this crude casting came this sleek beauty. A lot of filing and sanding.
As mentioned above, Davis cast crowns were used on a lot of British bikes. There were several other small British companies that made cast or forged crowns that looked similar. Before picture.
Raleigh Pro with a Davis crown.
I spent a number of hours grinding, filing and sanding this Davis crown on the off road trekking frame that I built back in 1992.
Bocama (BCM) investment cast crowns.
French made aero design Arcor Microfusion investment cast crown. These were used on a lot of the top quality French bikes in the mid to late 80's.
Selection of cast crowns from various manufacturers sold by a frame building supplier in the US.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Quoted: 4722 Post(s)
Liked 3,039 Times
In addition to Ishiwata and Tange, Japan had several fork and frame fitting manufacturers including Eisho, Kobayashi, Miwa, Nikko. Otsuya, Sanya and Yamazaki. I imagine that most of them had a semi-sloping crown but the establishment of Ishiwata's and Tange's pre-built fork programs seem to have eliminated them or at least pushed them into obscurity by the 1980s.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
Who made this one (on a late '80s CIOCC and Cromor fork blades says the decals). Somebody thought "Cinelli" but I don't recall seeing a pic of it in any catalog nor on Velobase...seen it on other Italian marques, however.
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times
A really outstanding thread. Thank You Everyone!!!
: Mike
: Mike
Liked 3,345 Times
Agrati crown nr. 000.8048, part of Agrati lug ensemble "AM" nr. 000.8040/U.
Quoted: 112 Post(s)
Liked 8 Times
I have added a bit to my post #1 & #4
This post is for a couple of current ones:
Allotec 28/19 oval fork blades. 152gr
201124-2240 NOVA SEMI SLOPED ROAD CROWN FOR OVAL BLADES for 28.6 steerer
Likes For avhed:
Likes For Unersame:
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
One small correction to make:
That crown is made for Columbus C&C tandem oversize (32x22 mm) blades. I have made a couple forks with them, still have the blades and crowns in case I ever want to make more (probably won't though!) The Masi two-plate crown was a lot more svelte than that.
I don't know what C&C stands for, anyone?
Mark B
Mark B
Liked 12 Times
Fork crowns
I was searching for Ekla fork crowns and saw this thread, which started off looking at semi sloping, but later added flat top fork crowns.
I am still trying to identify my track frame, but now know the lugs used, and have just seen that the fork crown
is Ekla round - see earlier pictures of the six they made and the picture of my forks.
maym036
9
05-11-11 04:54 PM
JonRinehart
17
04-20-10 10:43 AM
