WTB old (1.4 pull) Campagnolo rear mech
Quoted: 1106 Post(s)
Liked 1,328 Times
Have a set of Mirage 8s brake-and-shifter thingys to play with, net says I'll need a pre-2000 rear mech.
What's out there, I don't particularly care (or know if I should) about which model, would like a longer cage if there is/was one.
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
oneclick Four of my bikes are set up with Campagnolo 8-speed Ergos. A give away for the old (1.4 pull) Campagnolo rear derailleurs is the presence of a B-screw near the attachment/anchor bolt. The new (1.5 pull) rear units have B-tension screw at the upper jockey wheel/pulley. Rear derailleurs marked as 9-speed can be new or old style. For example, I have a long cage derailleur marked 9-speed with a B-screw at the attachment bolt......it works perfectly with the 8-speed Ergo shifters. 'Hope this helps.
Dean
Dean
Roll Me Up and Smoke Me When I Die
Quoted: 1609 Post(s)
Liked 2,216 Times
Well I learn something nearly every day! Good to know the pull difference.
I ran a DA 8 speed with Wheel Mfg spacers and a 9 speed Chorus RD. Worked as expected, perfect.
Campagnolo first installon Flickr
Edumacator
Quoted: 2441 Post(s)
Liked 3,135 Times
https://www.ebay.com/itm/12530430933...YAAOSwPbZieFCG
This is a decent deal for one with an offer option... Medium cage, perfect shape and these are rock-solid.
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
I have a Racing T rear derailleur (have the front and a triple crank too). I believe that's what you're looking for.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
I have a Veloce RD, can let that go for a lot less than $79, but I think this is a "short cage" unit and outer cage plate is alloy, but inner is steel. I think about same vintage as the "Racing T" above as the "B-screw" is on the mounting bolt.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Yeah, that's the one. The script logo is a good clue, but the B screw next to the hanger bolt is definitive.
My Bikes
My Bikes
