Cycling Gloves and Padding
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
I need to replace my cycling half gloves and I am looking to maximize the padding in the palms. The goal here is to minimize vibration and every little bit helps (I guess). Suggestions?
Thanks.
dave
Thanks.
dave
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
Quoted: 6196 Post(s)
Liked 4,811 Times
I like the way Specialized Dual Gel gloves fit. But for long rides padding isn't helpful to me. I still find myself grabbing the gloves with less padding for all but the shortest of my rides.
I minimize vibration by just not holding onto the bars tightly. And I try not to use any of the back half of my palm next to my wrist. When in the drops I just curl my fingers around the bar and my palm doesn't touch at all. For me that really helps eliminate the road vibrations and bumps from pounding into me.
Likes For Iride01:
Quoted: 2333 Post(s)
Liked 2,097 Times
What is wrong with a band aid?
Quoted: 967 Post(s)
Liked 1,631 Times
Try this...
https://www.bikeforums.net/22900854-post5.html
https://www.bikeforums.net/fifty-plu...l#post22900854
Quoted: 452 Post(s)
Liked 162 Times
dave
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,913 Times
One thing to be aware of is that greater padding does not necessarily equal greater comfort. You can end up gripping harder because you feel less secure, and end up no better off. So, whatever you end up with, consciously relaxing your grip on the bars may help quite a bit.
In your case (I perused your other thread), doing everything you can to lighten the weight you put on your hands, as well as the other steps to reduce vibration, may be worth the effort. Ideally, you should be able to lift your hands off the bars while pedalling without falling forward, and you shouldn't have to push off them, either.
One other thing about padding - I use unpadded gloves now but I went through a bunch of padded gloves in the past and what I found was that SOME of them exacerbated the Carpal Tunnel problems I had from years of pipetting. In fact, one of the worst pairs supposedly had a channel to alleviate the pressure on the median nerve! Good luck!
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,644 Times
You may also want to try adding gel pads under your bar tape or double wrapping your bars. There are also stems which have built in shock absorption which flex but not to the point of making it noticeable or unsafe.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
The way I got relief from shoulder and neck issues is by changing my on bike position, including riser type stems with shorter reach, and either shallow drop bars, like Ritchey Beacon bar. And/or, something like the Soma Porteur bar. The closest I have to more traditional drops is a Pro LT Gravel bar, 103 drop and 65 reach with only 5 degrees of flare. That is set up so the top of the bar is slightly above the saddle height. Those changes have also taken a lot of stress off my arthritic thumbs. I cannot do low and long any more. I prefer non-padded, long finger gloves, and tape with a bit of cushioning, not real thick. Too much padding causes numbness in my hands.
Likes For delbiker1:
Quoted: 4806 Post(s)
Liked 3,932 Times
[QUOTE=Iride01;22987362]I like the way Specialized Dual Gel gloves fit. But for long rides padding isn't helpful to me. I still find myself grabbing the gloves with less padding for all but the shortest of my rides.
I minimize vibration by just not holding onto the bars tightly. And I try not to use any of the back half of my palm next to my wrist. When in the drops I just curl my fingers around the bar and my palm doesn't touch at all. For me that really helps eliminate the road vibrations and bumps from pounding into me.[/QUOTE]
I don't do that second sentence consciously but I do ride in hand positions where my palms are facing each other and contact with the bars is on the outside of my palm's little finger side. Poor roads I spend a of of time in the drops.
A trick that was stressed by my early mentors when I started to race - firm grip on the bars but not an iron one. And keep my arms loose so there is no direct transmission of shock from bars to body.
I am another who chooses lightly padded (or no padding) gloves but I double wrap my handlebars to bring the diameter up a touch.
Quoted: 768 Post(s)
Liked 1,744 Times
This...Once I got my fit worked out, I found padded gloves were not needed
Likes For jaxgtr:
I agree with the original poster's point - padding in gloves can reduce the vibration feel in your hands.
The two suggestions that addressed that point - gel gloves and cushier bar tape - are what I did over the years, pretty much in that order. Then on a long ride I forgot to bring my gloves and found that the cushy bar tape had pretty much solved the problem, really didn't need to gel gloves. But, the back of the gloves is still a useful brow wiper and out of habit I still wear them. I've also bought into liking a high vis color on my hands for road riding.
My favorite (from a fit and durability point of view) have been Peal Izumi Elite Gel gloves.
I used to put on the cheapest bar tape and went to cork/gel bar tape - the added cost is almost as much over the life of the tape as a pair of gloves, but in any case: as a percentage of the cost of the bike, not a major investment!
Likes For jpescatore:
Quoted: 569 Post(s)
Liked 584 Times
When rheumatoid was joined by osteo in my hands I took on all of the good input mentioned above in addressing the issue. I believe addressing the bars as rsbob's suggested gave the the most relief of all I worked on.
well hello there
Quoted: 503 Post(s)
Liked 336 Times
I like a think handlebar tape (I'm using zipp service course cx) and a glove with lots of padding (I'm using performance terry).
I have severe arthritis in my left shoulder and the vibration seems to be a culprit in my shoulder discomfort while riding. I am simply doing anything that I can (particularly things that are inexpensive and easy) to reduce that (whether it will be effective or not). And yes I have been to my orthopedic doctor, yes I have had a MRI, yes I have been through the PT route, yes I have been properly fitted to my bike, and so on.
dave
dave
Quoted: 452 Post(s)
Liked 162 Times
dave
Quoted: 1461 Post(s)
Liked 1,486 Times
I'm another vote for checking the overall bike fit - rather than adding more padding.
I have pretty much stopped wearing gloves for summer road riding. I started going gloveless earlier this year and find that the padding in gloves doesn't seem to do anything. I don't have any problems gripping my bars or hoods with bare hands.
Quoted: 452 Post(s)
Liked 162 Times
dave
Liked 9,456 Times
FWIW, this is not a bike problem (or fit problem or even cycling problem). This is a well diagnosed shoulder problem and, from my perspective, is a "all hands on deck problem". If better padded gloves help (they literally saved my outdoor riding when I was having wrist issues a few years back) then better padded gloves it is. If a fit change helps - then I will go for it (within reason). Tires, wheels, etc., same thing. This is not going away and in the best conceivable case will simply not get worse (and that outcome is actually unlikely) and I will find some band aids that are helpful and keep me riding longer than otherwise. .
dave
dave
I know that you've said that you've been fit. Evidence suggests that the fit wasn't a very good one. I'd recommend revisiting fit -> adopting a less aggressive position -> and, if all else fails, looking at a 'bent (sorry ).
Likes For WhyFi:
Quoted: 452 Post(s)
Liked 162 Times
Your wrists and your elbow are between the bars and your problematic shoulder; none of those joints should be bearing much weight. If there's enough rigidity through your arms, such that jolts transmit through the two sets of buffer joints and still discomfort your shoulder, what hope is there that 2mm more padding on your palms will alleviate the problem?
Shoulder surgery (full shoulder replacement in my case) vs. a recumbent-type solution. Now there is an interesting decision.
dave
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 133 Post(s)
Liked 300 Times
Happen to like Pearl Izumi, who have various padding scheme options and a snug fit that doesn't fold to cause blisters. Sizing runs a little small, if ordering on line. Men's large are pretty tight on me, at least when they're new.
Good luck!
Good luck!
just another gosling
Quoted: 3889 Post(s)
Liked 1,939 Times
I mostly wear padded gloves of various manufacture, but for really long rides, I prefer unpadded gloves. I think that might be because they're not as sweaty? As has been said, hand comfort is all about position and the location of the bars and hoods. I find increasing reach by a few cm. can help decreasing the vibration's force on the hands, simply because the arms are more hinged, it that makes any sense to you. That's assuming that your position already takes the weight off your hands. If your hands are pushing down on the bars, vibration will be more noticeable. They should be light on the bars. Look at the photos in the Numb Hands post.
Results matter
Results matter
