Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs Have a need for adaptive equipment to ride to compensate for a disability or loss of limb or function? This area is for discussion among those of us in the cycling world that are coming back from traumatic circumstances and tell the world, "No, you are not going to beat me down!"
What if....one handed brake fails
Old 10-04-18, 02:06 PM
McStumpy
As mentioned in my other thread today, I have a road bike adapted for one handed use. I use a problem solver cable doubler - a short cable runs from brifter to the doubler, with separate cables running to each brake. But I’m now thinking....what if the short cable snaps? While going down a hill? I’d be in trouble, yes?
anyone have / had the same concern and found a solution? Thanks
McStumpy is offline
Old 10-05-18, 03:28 PM
McStumpy
Or am I worrying about nothing?
McStumpy is offline
Old 10-06-18, 02:43 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Exclamation maintenance
You have a great incentive to replace the cables every year ,
to insure they don't fail, while riding, Correct?
fietsbob is offline
Likes For fietsbob:
Old 10-07-18, 03:43 AM
McStumpy
Yep!
McStumpy is offline
Old 12-01-18, 10:10 AM
Philphine
Quoted: 90 Post(s)
Liked 18 Times in 16 Posts
just thinking (writing?) out loud
maybe a cobbled up foot brake? maybe not for regular use but like an emergency back up. say if you were able to have rear disc brakes and rear calipers and one was hooked up to a brake lever maybe back near the rear axle, like have a bmx peg on one side with the brake set up to use like the rear brake on a motorcycle.
that all sounds too complicated now that i've written it down, but still doable with some thought on it. now i'm thinking about it as a back up brake idea for a gravity bike if i go back to work on it.
Philphine is offline
Old 12-01-18, 09:35 PM
McBTC
McBTC's Avatar
Bikes: 2015 22 Speed
Quoted: 1543 Post(s)
Liked 51 Times in 39 Posts
sounds better than a decorator brick tied to a rope. Fortunately, never heard of a brake cable breaking.
McBTC is offline
Old 01-22-19, 09:34 PM
Arthur Peabody
Quoted: 250 Post(s)
Liked 110 Times in 66 Posts
Would it be too clunky to put levers for both wheel's brakes on the same side? I use cables until they break. (I'm able.)
Arthur Peabody is offline
Old 01-31-19, 11:51 PM
StephenH
Uber Goober
StephenH's Avatar
Quoted: 190 Post(s)
Liked 41 Times in 32 Posts
A valid concern.
For reference, I've seen several shift cables fail, but haven't seen any brake cables fail.
And for another reference point, for years and years people rode all over creation with coaster brakes, where if one brake failed, or if they dropped or broke a chain, they didn't have any brakes.
StephenH is offline
Old 02-01-19, 12:04 AM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
I've broken brake cables. My winter/city bikes get used hard and see very little attention (and not a whole lot of daylight for 4 months of the year). The culprits are usually bends that are too tight or chafing where the cables enter and leave levers and stops. Aero levers with hidden cables under the bartape can be the hardest to notice.
I"ll second the every year cable replacement for a one handed rider. Maybe more often. I put this in the aluminum handlebar and stem category. Replacing too soon costs money to the tune $10-100. Replacing too late could well be thousands (medical expenses, etc). The time scales here are obviously quite different, but so are the replacement expenses.
Be a geek. Obsess on those cables. And keep coming back to the forum so you can share your rides!
Ben
79pmooney is offline
Old 02-04-19, 01:18 AM
McStumpy
Thank you, all, I appreciate the advice.
​​​​​​I'm all in on the annual cable replacement, better safe than sorry.
McStumpy is offline
Old 02-08-19, 07:34 AM
Tonyweiss
Quoted: 7 Post(s)
Liked 3 Times in 3 Posts
I agree, replace the cables.
Tonyweiss is offline
Likes For Tonyweiss:
Old 02-08-19, 07:55 AM
CliffordK
CliffordK's Avatar
Quoted: 18376 Post(s)
Liked 4,511 Times in 3,353 Posts
I think I've broken a couple of cables, but only with significant fraying.
Also worn out my old Universal brake levers.
Definitely avoid the vintage road bike brake levers with a split cable end (drilled is good, just not split).
If not going fast, I've stopped by just putting a foot down. Going fast??? Grind through the toes of your shoes to save your life.
You might be able to avoid some dangerous descents with mandatory stops at the bottom. But, the truth is, the only time you'll notice a brake failure is WHILE BRAKING.
For an IGH, the pedal brake is a good idea (Shimano Nexus, and a few other brands).
Fixie? 3-speed Fixed (Sturmey Archer SX3).
Typically you can't use a coaster brake with a rear derailleur. But, I suppose in an emergency, you could rip off the derailleur (maybe) to use the coaster brake if you could build a hub with a coaster brake and cassette.
Still, with good maintenance, the situation where all brakes fail would be exceptionally rare.
CliffordK is offline
Old 02-10-19, 08:02 PM
fietsbob
Bikes: 8
Recently looked at SA website... S3X is gone.. so all that will be made have been already..
fietsbob is offline
Old 04-05-19, 08:33 PM
John E
feros ferio
John E's Avatar
Quoted: 1393 Post(s)
Liked 1,325 Times in 837 Posts
... Fortunately, never heard of a brake cable breaking.
Been there ... done that ... twice. When I was an undergrad I collided gently with the back wall of my grandfather's garage after my front brake cable snapped. No real damage done, but it certainly got my attention.
The scarier event occurred last year, when I ended up going through an intersection instead of stopping as intended on the yellow light. No problem that time, but it could have been worse, of course.
Both times the cable broke at the lever end, not far from the ball of solder. I do inspect my cables and replace at the first sign of fraying, but I admittedly was not on top of this.
My escape plan in case of brake failure is to put my left foot on the chainstay and gently push my left heel against the tire. With a stiff-soled shoe and some caution, I should be able to avoid a total lockup skid.
John E is offline
Old 04-27-19, 05:00 PM
DucHuy
Safety braking is an extremely important thing or it will be very dangerous
DucHuy is offline
Old 05-13-19, 03:45 PM
beach_cycle
beach_cycle's Avatar
Bikes: 2021 Electra Townie 7D equipped; 2019 Monterey 26" Seven Speed Trike
Quoted: 16 Post(s)
Liked 20 Times in 14 Posts
Brake cable broke after 5 months
I had a stock Schwinn Meridian brake cable snap after 5 months (~2,200 miles). It was for the rear band brake, but the front caliper brake still operated. I replaced it ASAP; it was a first for me, but it can happen.
QUOTE: sounds better than a decorator brick tied to a rope. Fortunately, never heard of a brake cable breaking.
beach_cycle is offline
Old 05-13-19, 06:29 PM
DucHuy
follow me you go to the brake bar immediately
DucHuy is offline
Old 05-19-19, 12:51 PM
Wileyrat
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 337 Post(s)
Liked 228 Times in 138 Posts
When I was a kid, I'd jam my heel against the back tire, it worked.
Due to an unfortunate set of circumstances, I did that same thing accidentally a few yrs ago. My heel locked my back tire up, and I came skidding to a tombay stop, narrowly missing landing on a prickly pear cactus.
It shredded a Rubino Pro to the casing.
Wileyrat is offline
Old 07-08-19, 10:08 AM
eddy m
Quoted: 140 Post(s)
Liked 72 Times in 48 Posts
The cable doubler increases the probability of a cable failure, and only insures that you will skid your rear wheel under maximum braking. Get rid of it and use a standard front brake, with a second lever in a different but reachable position for a rear brake. You can use the rear brake on downhills to prevent front brake overheating, and you will have a redundant system. The front brake will stop you just as fast as two brakes, and without skidding the rear wheel.
em
eddy m is offline
Old 02-01-20, 07:07 PM
spinnanz
Quoted: 58 Post(s)
Liked 95 Times in 59 Posts
make a dead mans break, so if the cable fails, the brakes will be on, rather than off.
spinnanz is offline
Likes For spinnanz:
Old 06-22-20, 01:44 PM
motorthings
Quoted: 56 Post(s)
Liked 10 Times in 6 Posts
a cable breaking is not the only way a brake can fail.
​​​​​​​you may want to add an inspection of the braking system, to make sure the caliper, cable, and other bits are well secured as a mid-year routine.
motorthings is offline
Old 05-21-21, 06:18 AM
Viich
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 190 Times in 132 Posts
I agree with you on the risk assessment - if you're doing any kind of aggressive riding, the impact of not having brakes could be large (sorry for pun). And you're right - with the doubler, you have a couple different ways to lose both brakes at the same time, when a conventional two-handed setup is completely redundant.
That being said - people ride single speeds with a single brake alll the time. I wouldn't, but companies sell them that way.
If you're worried about it, you have a couple options - either try out the foot braking mentioned, or work out a way that you can't lose both brakes with a single breakage (sorry, I did it again). You could try to rig a second cable (with its own lever) to one of the brakes, or it should be possible to set up a backup brake of some kind - maybe a front wheel drum brake?
Viich is offline
Old 02-27-22, 03:54 AM
NightShift
I've used a nexus igh with coaster brake and would recommend it.
I've seen a tandem drag brake hooked to a thumb shifter and heard of adaptive bikes using a thumb shifter or bar end shifter for the brake lever. If you like your current setup you could consider adding a second front brake hooked to a (friction, not indexed) thumb or bar end shift lever (possibly with a problem solved to adjust the pull) as an emergency backup.
NightShift is offline
Old 02-27-22, 10:30 PM
soyabean
soyabean's Avatar
Quoted: 539 Post(s)
Liked 416 Times in 274 Posts
Shift cables get a lot more stretching when derailleurs are pulled to their limiter screws.
(Most MTB) brake cables are also thicker diameter than shift cables.
If the brake cable is always dry and entirely encased (lube optional), then I can't see it failing in anyone's lifetime.
soyabean is offline
Old 02-28-22, 02:36 AM
McStumpy
This is how my bike shop have now set me up….so independent brakes on one side.
McStumpy is offline
