Anyone Using A 50/34 Compact Double
Old 05-11-19, 02:35 PM
  #76
CyclingFool95
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times in 73 Posts
At 45 I was still climbing everything in my area on 42/53 with 8-speed 12-21 and 12-23 cassettes. 7 years later, all my bikes are 50/34, although I'm thinking of switching to 36/52 because the 34 is just too small, even with an 11, and the 16 tooth jump in the front can be jarring.
CyclingFool95 is offline
Old 05-12-19, 06:20 AM
  #77
bruce19
bruce19's Avatar
Quoted: 1743 Post(s)
Liked 1,279 Times in 739 Posts
Maybe I'm missing something. Isn't it a 16 tooth jump with either compact or mid-compact?
bruce19 is offline
Old 05-12-19, 08:17 AM
  #78
CyclingFool95
Quoted: 148 Post(s)
Yes. I wasn't very clear with my thoughts. The problem I have is that with a 34x11, which is already prone to being noisy due to the chain angle, I fairly often find myself with too high a cadence, and the switch to 50x16 awkward. I figure with a 36 up front I should be okay on the flats and not need to jump to the 52 too often. The terrain around here is rolling enough that if I try to just run the big ring, I end up on the cross end of the rear cluster on the little climbs, which is just as bad. Thinking more, I might be happiest with a 39/53 up front and a 29 rear for the big climbs.
My cassettes are varied - I have 5, 3 with 25 or 27, one 12-29, and, I think, a 12-32 that came with the Centaur group. Haven't even taken it out of the box.
Old 05-12-19, 09:43 AM
  #79
bruce19
bruce19's Avatar
My new CAAD 12 has the 52/36 with an 11x30 cassette. The only issue I have is on short or shallow upgrades. I seem to want to be in the 52x30 and, of course, that's cross-chaining. I'm still experimenting.
bruce19 is offline
Old 05-12-19, 10:25 AM
  #80
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
I only up shifted at the crest of the hill that 16t jump 34->50, 36->52 ,
or the 24-> 40 from 3rd to middle on the triples I toured using.. 50t the outer in that case ..
fietsbob is offline
SolarRoller
Bicycle Mechanics
28
04-26-17 05:51 AM
rpeterson
Road Cycling
34
06-18-14 12:33 PM
Clipped_in
Road Cycling
21
06-17-13 11:15 PM
ovoleg
Road Cycling
36
06-06-13 11:56 AM
s4one
Road Cycling
53
12-13-12 11:04 AM
