Heart Rate
Quoted: 942 Post(s)
Liked 526 Times
I don’t know. For me the auto calculated seems to be pretty close. I’m 52 (206lbs on a 19lb bike) and I have never seen above 168. I also use Training Peaks and it lets me know when I hit a new threshold which is currently 158 and the HR values auto calculate based on that. Here is a typical effort for myself.
Quoted: 6099 Post(s)
Liked 4,730 Times
Still what you don't tell us about the effort you posted is whether you were going all out and trying as hard as you possibly could.
I'm 61 and I can hit 180 briefly and stay in the low 170's for a short time.
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
As someone that a year ago was wary of a heart attack, I did something about it. I was 378 and worried about being around much longer. I decided on weight loss surgery, specifically gastric sleeve. 113 pounds down from my heaviest, 91 since surgery. Followed my cardiologists guidelines. And for me, closely follow the 220-age. I'm 56 now. Was a runner and cyclist in the past. Knee replacement, back injury, another failing knee, Achilles tendon repair on one ankle and the other severely injured, I gained weight. Exercise was difficult and painful. And now, with weight coming off I feel better, can move better. My cardiologist doesn't want to see me for a year. Coronary calcium scan was a perfect zero... And she cleared me to any heart rate I am comfortable with.
Above effort was 30 minutes on my trainer, bike is a 86 KHS upgraded to mostly Shimano 105 5600 level. Compact crankset. I would say for myself, the effort was hard. But not into difficult range yet, the mag trainer was on the 3rd level. Even so, far better than I could imagine year ago. My RHR is about 60. A year ago it was 105...
For now, the 220-age is sufficient. But as I get stronger, I will re-evaluate. With my cardiologist's approval of course... Damn. How did I get old enough to need a cardiologist?
Quoted: 942 Post(s)
Liked 526 Times
Just because it's correct for some doesn't make it correct for all. The reason it's touted is because someone was able to figure out a formula that fit a large percentage of the people in the group they based it on.
Quoted: 926 Post(s)
Liked 1,281 Times
It is not an average, and it doesn't apply to older people. It was based on some very rough observations of groups of younger people. Once the age number gets large it doesn't really work at all. Since this is the 50+ forum it probably applies to essentially nobody here. If you're going to use anything simplistic like this use instead the 208 - (0.7 x age) formula which represented a stab at making a formula that applied to both older and younger folks. That one still comes up short for older athletic folks but at least it represents an attempt to compensate for age.
Likes For davester:
feros ferio
Quoted: 1384 Post(s)
Liked 1,293 Times
From the Mayo Clinic (note the incorporation of resting heart rate in the calculation):
If you're aiming for a target heart rate in the vigorous range of 70% to 85%, you can use the heart rate reserve (HRR) method to calculate it like this:
Subtract your age from 220 to get your maximum heart rate.
- Calculate your resting heart rate by counting how many times your heart beats per minute when you are at rest, such as first thing in the morning. It's usually somewhere between 60 and 100 beats per minute for the average adult.
- Calculate your heart rate reserve (HRR) by subtracting your resting heart rate from your maximum heart rate.
- Multiply your HRR by 0.7 (70%). Add your resting heart rate to this number.
- Multiply your HRR by 0.85 (85%). Add your resting heart rate to this number.
- These two numbers are your average target heart rate zone for vigorous exercise intensity when using the HRR to calculate your heart rate. Your heart rate during vigorous exercise should generally be between these two numbers.
Quoted: 926 Post(s)
Liked 1,281 Times
Subtract your age from 220 to get your maximum heart rate...
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Even if 220-age was accurate or represented the average population, max heart rate is pretty much useless for training anyway.
Zones should be based off lactic threshold heart rate, not max.
https://www.trainingpeaks.com/blog/j...setting-zones/
-Tim-
-Tim-
Saying one system is wrong without supply a more viable and accurate alternative is useless In addition, the aforementioned test makes no sense whatsoever. Not to mention its written very poorly.
I recognized that the science of nutrition and health are relatively new, so I try to keep an open mind on such things. However, so far the only thing I'm convinced of at this point it that there's room for growth.
There are a varieties of updated MHR methods available but none as of yet have been universally accepted or supplanted the de facto 220 - age which despite its implied limitations, is still recognized and used everywhere.
Quoted: 942 Post(s)
Liked 526 Times
For me, I don't train by HR, I train using power. The HR shown above is the byproduct of that, which happens to fall in line with 220-age. Too many variables affect HR and HR is not constant, but power is.
Quoted: 2952 Post(s)
Liked 3,106 Times
Except that their method is totally flawed because it uses the bogus 220 - age formula to set the upper limit. This will result in most older people training at a HR that is not in the vigorous range as advertised. That's the whole problem with the bogus formula...it makes people think that they are at a higher training level than they actually are.
My predicted upper limit using this formula is still 23bpm below my observed LTHR. Which means that if I used that I would likely spend a lot time in the mushy middle: hard enough to cause fatigue but not hard enough to elicit much training response. So I won’t get any stronger, just tired.
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
I can still push my heart rate way up, 200 range easy enough. But I train for triathlon year around, swim 3-5 miles, cycle (indoor or out) 75 miles and run/elliptical 18 miles and two full weight workouts per week. Yesterday some road weenies flew by me and something about it ticked me off, so I passed them for about a mile or so and made them chase, good thing my turnoff came up . But, it takes longer to recover and I cannot sustain the output of my earlier years, nor the peak HR of course either, I go anaerobic much quicker too. I take my resting HR once a week when I wake up, Monday morning, it is less than 40 BPM.
Likes For Loose Chain:
feros ferio
Liked 1,293 Times
Seriously, this is probably the flaw in 220-age, which should at least be modified to reflect the fact that we all age differently, and some, like yourself, are outliers (a very commendable thing, in this case).
One of my friends was a dedicated runner and commuting cyclist who used to enjoy "throwing a 42 [bpm pulse]" to his doctor during physical exams. I always thought this was a good thing, and still do, but I was interested to see concerns over bradycardia, even among athletes, on some medical websites. One of my exercise goals remains to push my resting pulse rate back down below 45.
What I find really intriguing about your case is the combination of a low resting pulse rate and a high maximum pulse rate. I can't go much above 150 (coincidentally close to 220 - 68), but I am sure I can't deliver anywhere near the peak power you can.
Side note: When I was an undergrad I was cruising along with a couple of other young guys I had met when we were passed by a guy with a white goatee and a white Mercier. One of my new-found friends asked, "Are your going to let an old guy like that pass you up?" I replied, "Hell no," and took off after him. As I caught up with Ollie, he told me, "You keep up a good pace." Given that he was obviously more than twice my age, I replied, "That's MY line." He told me he was training for the upcoming Los Angeles Wheelmen Double Century, and encouraged me to start training with him. Had it not been for this chance encounter, I doubt I would ever have considered attempting a double, since a double metric (125 miles) with my cousin several months earlier had just about wiped me out. I always love it when an older guy passes some of the "kids."
My idea of fun
Bikes: '06 Litespeed Tuscany, '02 Kona Lavadome, '07 Giant TCR Advanced, '07 Karate Monkey
Quoted: 41 Post(s)
Liked 59 Times
Everyone's different. I'm 50 and my max HR is over 200. There are also so many things that can impact HR, drift from a long workout, dehydration, heat/cooling, caffeine, overtraining, etc.
As TmothyH said, training zones should be based on lactate.
Bikes: 2021 Trek Checkpoint SL (GRX Di2), 2020 Domane SLR 9 (very green), 2016 Trek Emonda SL, 2009 Bianchi 928, 1972 Atala Record Pro
Quoted: 85 Post(s)
Liked 143 Times
During a brief, extraordinarily painful effort to do high intensity, zone based "training" last year, I used numbers--lactic threshold, max heart rate, and ftp that had been lab tested and approved. My measured performance on the smart trainer always had the HR a zone or more higher than the power. The numbers or methodology might be bogus, but the pain was real. I just decided to forget about it and pedal on
