Which 38-Tooth Chainring Should I Get? Aluminum or Stainless Steel?
Quoted: 40 Post(s)
Liked 9 Times
I'm looking to get a new pair of 130mm BCD chainrings.
The outer ring will be a Shimano 105 5703 50-tooth chainring.
Shimano doesn't make a 38-tooth 130mm BCD inner chainring and so I'm looking at two possibilities: a Dimension aluminum ring or a Surly stainless steel ring.
Any opinion on which one I should get?
I don't know what kind of aluminum alloy is in the Dimension ring but I would have to guess that it's something low-end since it would otherwise be indicated.
The warning I've read for the Surly ring is that a 9- or 10-speed chain will have tight fit and require a break-in period.
The current bike setup is a 9-speed with friction shifters that I may upgrade to 10-speed.
Thanks in advance
Thanks in advance
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
38T is large enough that I would use aluminum. Sugino makes a good plain aluminum ring, but prices have crept up on those.
32T or smaller is where I'd start to consider steel, especially if you plan to spend a lot of time in that ring. My wife's new bike came with a 46/30 crank, and I discovered that the 30T was magnetic after getting it home. Good choice on their part.
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 253 Times
Now I buy only TA rings, they are like jewelry. You can get them easily from Chain Reaction or from Peter White.
Good luck!
Likes For BCDrums:
Quoted: 2026 Post(s)
Liked 1,096 Times
Small chainrings that are used routinely will last far longer in steel than in aluminum. I have aluminum 26T and 30T granny chainrings on my road triple cranks but those chainrings are only used very sparingly. If I used them with regularity, they would be steel.
Likes For HillRider:
Liked 2,571 Times
^ Exactly what @HillRider said. Especially if a newer rider (not casting aspersions) might find themself using the small ring a lot.
Liked 2,571 Times
But I'm sure it would be fine for the job.
Quoted: 1952 Post(s)
Liked 2,191 Times
My own rule of thumb is if you need to pull the crank to change the chainring, and you use that ring a lot, get one that will last the longest.
I’ve read mixed opinions on larger steel chainrings, granny gears are fine.
John
John
