SwissCross gravel project
I’ve said it repeatedly, but I owned this version of the Swiss Cross for a long time. I know it backwards and forwards, and it’s a pretty quirky machine. It’s not a generic canti frame and you can’t assume it is.
Habitual User
Quoted: 5039 Post(s)
Liked 8,270 Times
EDIT: Oops. I see now. That stop is for the TT-routed rear shifter cable.
Quoted: 98 Post(s)
Liked 154 Times
Exciting day in the shop - Gravelkings arrived and have been mounted. The 43mm front went on without issue, using a compressor. The 38mm rear didn't want to seat until I turned the pressure up to shock it on. Then, no problem. Both fit with reasonable clearance to the frame. I'll have to wait until later this week to see how they play with the brakes.
Also in the pics - Crank Bros Candy 3 Pedals - got a deal on ebay. I've been using the eggbeaters on my roadbike and figured the slight platform of the Candy might be more gravel friendly.
I replaced the upper headset with a silver version that has no cable stop. To be thorough I replaced the lower as well. I removed the crown race using non-marring pry tools. To replace it I will get a length of PVC or similar.
Quoted: 98 Post(s)
Liked 154 Times
I am new to carbon forks and its been a very long time since I've worked with threadless. I have not ridden this bike yet but my gut is that I'll want the stem lower than the previous rider had it (see below).
Do folks usually cut the steerer to suit, eliminating shims or leave it long with shims on top of the stem....
A) to preserve flexibility for resale?
B) to preserve flexibility for rider comfort changes?
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
I used Gevenalle shifters on a gravel bike for 5 years. Actually 2 bikes- I chose to use them for a year on a new build too. Loved em.
They are quirky and the exposed cable is not the most convenient thing when combined with a handlebar bag, but yeah - I loved em.
The hood shape fit my hand well and my hands are large enough that I could shift from the hoods or in the drops. They are definitely quirky.
Habitual User
Liked 8,270 Times
Quoted: 1431 Post(s)
Liked 1,964 Times
complete set up and ride the bike for a bit before you cut the steerer
Quoted: 98 Post(s)
Liked 154 Times
Noted thanks.
My pretty blue Paul brakes arrived today and I test fit them. I've not used these before and want to confirm that the paul "brake pivot" sits proud of the step on the post, leaving the step exposed as I showed here...
BTW your frame will be happier on your shop stand by clamping on the seat post rather than the seat tube.
Quoted: 98 Post(s)
Liked 154 Times
Thanks. Perhaps I should have asked Paul before buying these but the neo retro on the back wants to strike the braking surface at the very top no matter how far down I adjust the pad. I wonder if this is a quirk of different frames or if different model cantilever brakes are naturally more suited to a certain frame or rim. I don’t believe there’s anything too unusual about the Pacenti Forza rims i am using.
I don't know.
Quoted: 324 Post(s)
Liked 872 Times
oo, those are nice. I might hafta get those to upgrade the Tektros on my Windsor Tourist.
Quoted: 98 Post(s)
Liked 154 Times
My business partner and good friend commutes (and carries his kid around) on a nicely patined RB1. its old dura ace rd just broke a spring and im gonna try and fix it for him.
Habitual User
Liked 8,270 Times
Those are cool-looking, for sure. I'm not sure my brain would tolerate the mix of canti and v-brakes, however.
Quoted: 98 Post(s)
Liked 154 Times
This project is all about trying new things; preferably with cool American manufacturers of CX/gravel related products. This brings us to these Gevenalle Audax. I like a lot about these. I think it’s clever that they are unabashed about hacking a commonly available lever. I’ve heard a lot of good things about the Dia comp ENE friction shifters. This is much discussed on another thread I started regarding friction shifting. These are the style which micro ratchet in one direction and are pure fiction in the other. I like that they are swappable, including for late model shimano sis.
I also like that they are silver. And the goats. I like the goats.
Likes For somebikeguy:
Habitual User
Liked 8,270 Times
Quoted: 98 Post(s)
Liked 154 Times
The trick to getting the pads to hit the brake surface at the rear was to flip the thick and thin concave washer so that the thinner one was on the inboard side. I also removed the 1 mm flat washer and put it on the outside
Quoted: 98 Post(s)
Liked 154 Times
do hex fasteners on bikes bother you all? So few multi tools have even an 8mm let alone the TWO 10mm one would need to adjust the straddle. This is where Paul’s pricey but cool Moon Unit is genius. They annoyingly only sell them in pairs and weirdos like me need just one. Anyone got one laying about?
https://www.paulcomp.com/shop/compon...ers/moon-unit/
Quoted: 98 Post(s)
Liked 154 Times
Got her on the road! I was almost there then found I'd marred the front wheel rim tape and she wouldn't hold air. I got some new Stan's tape today, installed more carefully and took a ride. So far: loving it. All the things that made this bike unique are really working for me so far: the Audax friction brifters, the Paul brakes (wow good feel and power) and the flared bars.
For the record the Panaracer Gravelking SS+ run pretty darn true to size. Here they are, probably inflated way past what I'll ride them at, measuring close to their 38/43 stated widths. 20mm rims.
Quoted: 98 Post(s)
Liked 154 Times
First ride was a lot of fun!
I left the cranks, front derailleur and cassette that came with the bike in place but think I am going to swap things up. I rode mixed terrain including some off road climbs using only the 38t chainring and Ultegra 9sp 12-27t cassette. I'm inclined to swap to an XTR 9sp 11-34 or 12-34 and run it 1x9. I'm trying to decide which way to go on the cranks, current thinking would be White Industry's square taper crank and single speed "tall short" chainring to give me some chain retention. I know it's not supposed to work by I'm using a Dura Ace 8 speed short cage on my Bottecchia road bike with an XTR 12-34 with friction shifters and its all good!
https://www.whiteind.com/product/squ...r-road-cranks/
https://www.whiteind.com/product/squ...sr-chainrings/
Quoted: 443 Post(s)
Liked 474 Times
Ok not quite slammed but you get the point
Quoted: 443 Post(s)
Liked 474 Times
