Shimano Exage side pull brake spring replacement?
Long time part timer
Greetings,
I am trying to find a replacement spring for an early 90's Shimano Exage BR-A350 side pull brake caliper but am not making too much progress.
First attempt at replacement was to just take one off of a scrapper bike but all I have are some older Dia-Compe models and those springs are too thick to "set" into the Exage caliper. Next attempt was to go to a couple of local LBS' to see if by chance they would have any suitable springs laying around. Neither one did and both recommended a whole new brake caliper. Online searches for replacement brake springs are coming up empty (I don't participate on ebay - I gave up there many years ago). Another idea I have is to contact a not-too-close-to-me bike co-op but have not done that yet. I suppose I could also post a BF ad in the appropriate section.
It seems silly to me to buy a whole new brake caliper and would like to believe there is someone or some source I could get a suitable spring from so I am asking for suggestions. Or, if my belief is delusional feel free to tell me that too.
Many thanks in advance!
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli, Merckx
Quoted: 430 Post(s)
Liked 476 Times
As much as this is a DIY fix it community, some bike parts just aren't worth the hassle.
What's wrong with the original spring?
Quoted: 430 Post(s)
Liked 476 Times
If your local bike kitchen or coop is open and will let you dig around in their parts bins, you might get lucky.
The Exage group wasn't terribly high end, which is why sourcing a new caliper might be easier. Complete Exage brake calipers are under $20 on the Bay.
Something else to consider is why or how the spring broke. Was it from corrosion or a crash? Are other parts of the caliper worn or soon-to-break as well?
Otherwise maybe try the FS/FT thread and see it anyone has one laying around.
I'll try a wanted post in the appropriate thread and cross my fingers. Still open to other suggestions. Thanks much!
Likes For HMJ:
Bikes: 1980's Royce Union "fixed wheel", 1995 Trek 370, 406 -wheeled " shopper/minivelo"for running errands, SS Raleigh M60
Quoted: 44 Post(s)
Liked 58 Times
Greetings,
I also have on my Trek a set of mid '90's BR-A250's with RSX brifters and, although not latest/high performance calipers, with Shimano/ Cool Stops pads are pretty good for my use; I'd try to maintain them in service also. Good luck.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
can you get a pic of the spring and some best measurements? i'll look and see if i have something in my stash that would work. yours free/you ship if it works out
Quoted: 4560 Post(s)
Liked 2,802 Times
If you get into a DIY mood, it's not too difficult to make springs from scratch using the right metal stock for flat or simple coil springs, and some old school techniques. I've done the necessary heat treatment in a garden burn pit when I lived in a rural area. Back then I got the metal stock from Brownell's, an old gunsmith supplier, and instructions from an old gunsmith's manual for the heat treatment, but nowadays there are probably more sources for suitable metal stock.
Here is the pic with measurements
Had to get over the 10 post minimum for this...apologies for a couple of other posts. I don't make the rules, I just follow 'em
Anyhow here is the still-in-tact spring. I had to make a minor adjustment when I put the caliper back together but you get the idea.
Many thanks!
Many thanks!
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
if i can't get to it this evening, i will tomorrow asap
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
dude ...haven't forgotten. work all weekend. i'll be back this evening with input
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
No worries thook - you are doing me the favor for even checking so I appreciate whatever you can do whenever you can. Cheers!
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
I will take a look, too but the best prospects are in my "bucket" that I would not visit until the weekend. Hope you can hold on that long cause I'm pretty confident I can find one there (but been wrong before!), if I do it will be a freebie (or at most for postage)
