Addiction 2021.1
#9977
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
#9978
Should Be More Popular
Quoted: 22590 Post(s)
Liked 8,924 Times
Likes For datlas:
#9979
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Well, yes and no. The more vaccinees in the population, the fewer susceptible people there are for the virus to transmit to. With enough vaccinees, the rate of transmission will fall below 1 transmission per infected person and at that point the epidemic diminishes. Eventually, it could go away completely.
Unless....
Unless the people who insist on NOT getting vaccinated tend to live together or near each other. But even then, eventually it would burn out. The problem is, the larger the unvaccinated population and/or the slower the rate of vaccination, the more time the virus has to evolve. The goal should be to get as close to everyone in America vaccinated as fast as humanly possible, so the virus doesn't have time or opportunity to mutate into a resistant form
Unless....
#9980
Quoted: 8275 Post(s)
Liked 9,031 Times
And you kids should have some respect for your elders!
#9981
Bikes: Shmikes
Quoted: 10165 Post(s)
Liked 5,852 Times
#9982
Bikes: Shmikes
Liked 5,852 Times
#9983
Klaatu..Verata..Necktie?
Quoted: 10421 Post(s)
Liked 11,882 Times
Maybe. My suspicion is the virus infection rate will go UP not down over the next 2 months, because people are letting up their guard and the people who have been spreading the virus are NOT the ones getting vaccinated. Luckily the hospitalization/death rates should not go up much because the vulnerable are getting the vaccine and/or being careful.
How it plays out beyond the next 2 months is anyone's guess.
#9984
Liked 9,456 Times
That's almost exactly where my BP was when I went in last month. HR, too. Body weight is prolly a little different, though.
#9985
Liked 11,882 Times
Results indicate that the vaccines at the very least reduce the rate of infection among vaccinees, compared to the placebo group or the unvaccinated.
#9986
Liked 9,456 Times
I was able to squeeze out for a quick ride. It was WINNNDY. And, despite riding roughly in a circle, the wind only manifested as a tailwind for about 14 seconds. I'm not sure how that works.
Got in some good, heart-in-my-throat efforts, which was nice, but the stop-and-go in downtown was a drag on the workout.
Likes For WhyFi:
#9987
Liked 11,882 Times
Somewhere in Mom and Dad's house is my Grandfather's sphygmomanometer. (Hey! I spelled it right first time!)
#9988
Liked 9,031 Times
#9989
Liked 11,882 Times
Circuit Update: Loose Screws has the Black Rubber Nub. Ordered.
#9990
Liked 11,882 Times
That's a fair point. Funnily enough, though, the other end of at least one of Park's fixed cup wrenches is a pin spanner for the adjustable cup.
#9991
Liked 8,924 Times
#9992
Liked 9,031 Times
#9993
Quoted: 10236 Post(s)
Liked 5,183 Times
Likes For bampilot06:
#9994
So it is
Quoted: 11398 Post(s)
Liked 4,744 Times
Bike nerdery content. TL;DR at the bottom:
I've known for a while that the aftermarket fork I have on my 710 is shorter than the stock one and it's bugged me terribly ever since I installed it. I finally took the time to take the bike apart and get some actual measurements to figure out exactly how much of a difference there is.
Turns out my new fork axle-to-crown is 10mm shorter than the stock one. This results the front end lowering quite significantly, and steepening all the effective angles on the bike by a little over .5°. Not a huge issue on paper - the 63cm frame that I have was brazed at 73.5°/72.5° so the HTA/STA steepened up to 74°/73°. Still a reasonably shallow STA and that HTA is steep, but not overly so.
What bugged me is that with the front end 10mm lower there is a quite conspicuous downward slope to the top tube, which just looks so wrong on a classic lugged frame. It's been on my mind constantly and there has been handwringing upon handwringing with the different options to fix it:
I bought a needle bearing headset with a tall lower stack height, but that only gave me a few additional millimeters.
I could go back to the original fork but I never really liked how it rode (5cm trail with wide 650b tires just feels a little weird), plus I'd have to get canti posts brazed on and powdercoated. Handling gets even weirder with a handlebar bag.
I could have the original fork re-raked to lower the trail and get the handling I want, but that's another pretty big chunk of change and the front end would drop a bit anyways so I'm still in the same situation, just not as bad.
Custom forks are $$$ I'd rather use for something different.
I eventually stumbled upon someone on eBay that makes taller crown races for MTBs - I guess sometimes for fat bikes you need some extra room below the head tube so a suspension fork doesn't smack the downtube - but all he made were for forks with 1 1/8" or 1 1/2" steer tubes. I figured something like that would my best option - using a cartridge bearing headset with 36°/45° bearings all I had to do was reproduce the fairly simple geometry of the crown race that came with the headset I wanted to use and then add 10mm on the bottom!
Drew up something up real quick and shot it off to him since he does custom parts as well. $30 and a day later the part is on it's way to my house!
Fingers crossed I designed it correctly. Also got a nice little boost to the ego when he told me he'd do it for the same price as his stock spacers - "Very nice drawing will make it easy."
Although, now I'm going to have a bit of a challenge because I'm about 5mm shorter than ideal on steer tube length...
TL;DR - I'm getting a custom crown race spacer to make up for a 10mm too short axle to crown on one of my bikes.
Likes For LAJ:
#9995
Liked 8,924 Times
If it’s mercury it may be a collectors item. We have a few mercury ones at work but you can’t get them anymore and they are all gradually getting replaced.
#9996
Liked 11,882 Times
I have gotten as low as 39, even at work. Which is at home. So....
#9997
Liked 11,882 Times
I last saw it maybe 50 years ago. No less than 45 years. Lord knows where it is now.
#9998
So it is
Liked 4,744 Times
I still haven't been vaccinated. Was hoping the lung thing would clear up some first but it just keeps on truckin'. COPD, asthma, whatever it is. Some days, like Saturday, I feel pretty good and climb well enough. Then Tuesday 3 of us met up and my friend took us up a couple thousand feet of climbing at the start. I couldn't get my breathing going and they had to keep waiting and I was embarrassed at how crappy I rode. Later I started feeling better and yesterday I went climbing alone and felt good again. Trying not to use the Albuterol too much. Last time I was at the doctor she wanted to prescribe another drug but I decided to wait. I guess another appointment is in the cards.
Likes For LAJ:
#9999
Liked 9,456 Times
Yeah, my RHR is always a little high at the doctor's office. Maybe it's a touch of anxiety or maybe it's the 1.5 espresso drinks rushing through my veins by then, but I can rarely get it under 50, which is easy peasy otherwise.
Bikes: Shmikes
Liked 5,852 Times
Results from two unpublished studies say that asymptomatic infections are reduced in vaccinated individuals relative to community samples of unvaccinated people. I don't believe there are any such data yet from the clinical trials.
