Looking for a low-cost alternative to presta rim grommet
Quoted: 336 Post(s)
Liked 309 Times
Does anybody have a low-cost but safe alternative to presta rim grommets? Something that they have used successfully like a washer, o-ring, or something else that doesn’t cost a buck and a half per tube?
I’m looking for a replacement for these to use a presta tube when I have a rim drilled for schrader.
Quoted: 4201 Post(s)
Liked 3,857 Times
Try a "rubber" insulating grommet. grommets | McMaster-Carr They have been used for decades for this bike application. However you'll find then a sorry sub for the Wheels Al version. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Really Old Senior Member
$3/bike until you install Schraeder tubes.
Likes For Bill Kapaun:
Bikes: 1980's Royce Union "fixed wheel", 1995 Trek 370, 406 -wheeled " shopper/minivelo"for running errands, SS Raleigh M60
Quoted: 44 Post(s)
Liked 58 Times
I made my set of "wheel savers" because I had the materials and basic tooling BITD; a buck and a half is pretty inexpensive for something reusable, specialized (as it's only purpose), and seldom needed in this time and age, and If I were to need them again, I'd bite the bullet and buy them. Just like Andrew said, anything else will not last as long, or work as good; just my $0.02.
Likes For Juan el Boricua:
Quoted: 336 Post(s)
Liked 309 Times
Thanks all. It looks like the best options are not significantly cheaper. This is for refurb bikes where the bike already has presta tubes that are good, but are on 26 rims drilled for Schrader. I burned through my stock of 3 pairs last week refurbing bikes for the local non-profit.
I'll buy a handful of the grommets or pay more attention to the compatibility of what I pick up in the future from the co-op.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
How cheap is cheap enough for you? Those adapters can be found at any be shop for pocket change.
Bikes: State 4130 Custom, Giant Trance 29
Quoted: 422 Post(s)
Liked 182 Times
Wal Mart even has these for only 89 cents:
https://www.walmart.com/ip/Schrader-Presta-Rubber-Rim-Hole-and-Adaptor/
(never mind the $6 delivery fee)
Quoted: 336 Post(s)
Liked 309 Times
I have purchased lube, grease, 50m rolls of 4mm and 5mm housing, bottles of loose balls, cable tips, and ferrules. I don't mind donating the shop supplies, but replacement parts start to get expensive when you start adding cable inner wires, tubes, grips, bar tape, chains, etc. Grommets are cheaper than tubes, but more expensive than cable end caps.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Cheapest option of all... don't bother.
Works fine, lasts long time.
Likes For DiabloScott:
You could try just wrapping some tape around the lower part of the stem.
Or get a pack of rubber grommets (I’m not sure of the exact size).
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I also vote for the don't bother approach. Or use the Continental tubes that have a threaded stem and the reversible nut with the adapter built in, but that's more expensive unless you need the tubes anyway.
Quoted: 836 Post(s)
Liked 1,061 Times
+1 or 2? Check the tubes that you have as they may already have the reducer stem nut included. I'm pretty sure even Panaracer tubes include them and their tubes are on the less expensive side.
Quoted: 336 Post(s)
Liked 309 Times
If I choose the "Do nothing" option, at what pressures do I need to worry about herniation? I'm looking for someone who already has data points, I prefer to not do my own experiments here.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
I have plenty of "reducer" presta nuts. They help center the stem, but do not prevent tube herniation, which is the problem that I am trying to prevent. I worry that the recipients of these bikes will simply inflate to recommended sidewall pressures (~70 PSI for the commuter tires that we install).
Stuart Black
Stuart Black
Quoted: 336 Post(s)
Liked 309 Times
Would small tube movements in the tube rub a hole on the knurled edge of the presta nut? Am I overthinking it?
Likes For Bimmer69:
Quoted: 836 Post(s)
Liked 1,061 Times
It's MY mountain
Liked 2,980 Times
Quoted: 676 Post(s)
Liked 741 Times
My wife has had Presta stems in Shrader rims with 90+ psi inflation for almost two decades. Never an issue.
Likes For andrewclaus:
Liked 4,217 Times
Ah. Now this is a low cost solution. If a presta nut under the rim isn't a risk, then I will use that. I may also pick up a few 010 and 108 o-rings to see if either of those work.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 6193 Post(s)
Liked 4,808 Times
Is there a community college or vo-tech that teaches CNC machining? Check and see if they have a CNC lathe and will let a student run you some of those you pictured in the OP. Those are simple to make, will be good experience for the student. Material cost is very low. The big cost comes in tooling setup which is essentially time.
Back in the days of CRT displays, I used to take bad CRT's to the local community college that had an electronics repair course and got them fixed for just the cost of the transistor or capacitor they needed.
Quoted: 194 Post(s)
Liked 204 Times
I try to plan the bikes I purchase for resale along with the ones I accept in part exchange etc to minimise any outlays.
I am not sure how you arrange to get the bikes you work on, but for example I picked up three bikes recently where one was mostly good, one was so-so and the other rough, but by the time I had broken the rough one down to components I had most of what I needed for the good and so-so bikes. Anything left over that I don't think I will need gets sold on as parts. As you know, tires, tubes and cables soon get expensive, so I really look hard at the rough ones for good hubs and things to sell. Often they are rough only because they have been left to rust in a basement, while under that surface they are still a low mileage bike.
Quoted: 381 Post(s)
Liked 145 Times
The Panaracer Schrader-presta Valve Nut is sold in at least bags of 10 on ebay. It may be cheapest production thingy, but more practical may be nothing or wrap tape as others stated.
https://www.ebay.com/p/2255925853
