Chain Waxing??? How and What Brand/Type?
Old 05-01-19, 07:34 AM
allout1
allout1's Avatar
Quoted: 57 Post(s)
I'm thinking that a chain in wax is a substitute for a chain in oil. If it lasts a month, and it's not as filthy an ordeal as the conventional lube job, it can't be bad.
So what's the deal? Just buy some cheap candles, melt 'em down, dip, run on 'em.
allout1 is offline
Old 05-01-19, 07:36 AM
Quoted: 9066 Post(s)
Liked 688 Times in 425 Posts
Scented candles FTW.
Old 05-01-19, 07:40 AM
Skipjacks
Skipjacks's Avatar
Quoted: 975 Post(s)
Liked 186 Times in 123 Posts
No way, man.
Crayola.
Give your chain a spot of color to liven up the ride!
In all seriousness....waxing is a cleaner option for dry conditions. It will not suck up the road grit and dirt like a wet oil does. In fact, it will actually repel dirt as the dirt will literally fall off the drivetrain components while spinning. But it doesn't last nearly as long as oil.
For off the shelf wax in a bottle you'll need to reapply every 50-200 miles (depending on the wax and how wet the bike got in that time). For a serious waxing where you dip the chain in melted wax on the stove it'll last much longer, and be better for the whole system. But I've never done it so I can't tell you anything more specific.
Skipjacks is offline
Old 05-01-19, 07:43 AM
Originally Posted by Skipjacks View Post
No way, man.
There is nothing serious about the OP.
Likes For indyfabz:
Old 05-01-19, 08:08 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 630, '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 626 Post(s)
Liked 132 Times in 80 Posts
https://www.bikeforums.net/commuting...hot-wax-4.html
https://www.bikeforums.net/fifty-plu...in-lubing.html
https://www.bikeforums.net/bicycle-m...xperiment.html
https://www.bikeforums.net/commuting...be-chains.html
https://www.bikeforums.net/bicycle-m...-lube-why.html
https://www.bikeforums.net/classic-v...fin-users.html
These should get you started. Your employer must highly value your resourcefulness. :wink:
/thread
Phil_gretz is offline
Likes For Phil_gretz:
Old 05-01-19, 08:14 AM
ldmataya
ldmataya's Avatar
Quoted: 63 Post(s)
Liked 5 Times in 4 Posts
Been doing it for years. My recipe is 3-1 ratio of household paraffin (Gulf Wax) to beeswax which I get from Amazon. Beeswax adds some viscosity. I use a crock pot; warm up the pot, remove chain, dip it and articulate it for a few minutes, then remove. One batch of wax in the crock pot lasts all summer because the chains aren't that dirty. This is for roughly 4 bikes in the rotation (road, road, TT, MTB). But I have to change it more frequently in the fall and winter with wet cyclocross and gravel chains.
Waxed chains just never get as dirty, but even if you ride a bike in just dry conditions, it will have to be re-dipped at about 500-800km intervals. I have multiple bikes I ride, so my less used bikes typically make it an entire season on one dip. I will drip lube on in cold cyclocross conditions because a freshly waxed chain is pretty stiff below freezing. But a winter or MTB bike is fine with wax - doesn't hold any moisture to speak of.
ldmataya is offline
Old 05-01-19, 08:21 AM
badger1
badger1's Avatar
Quoted: 1001 Post(s)
Liked 52 Times in 34 Posts
The op should really consult a waxing expert.
badger1 is offline
Old 05-01-19, 08:24 AM
Phil_gretz
Phil_gretz's Avatar
Quoted: 626 Post(s)
I went past a Bikini Wax place recently and thought, "Wow, what a world? I can bring my bike chains in to be waxed by girls in bikinis." I wonder if they'd throw me out...
Old 05-01-19, 08:38 AM
I-Like-To-Bike
Been Around Awhile
I-Like-To-Bike's Avatar
Bikes: Vaterland and Ragazzi
Quoted: 11 Post(s)
Liked 106 Times in 72 Posts
I-Like-To-Bike is offline
Old 05-01-19, 08:42 AM
Likes For indyfabz:
Old 05-05-19, 12:13 PM
allout1
allout1's Avatar
Quoted: 57 Post(s)
And Daniel San said, "It not as easy as one looks." Hmmmmmmm We shall see.
Okay, lots of good tips here. I'm going to try it out, and go from there.
My chain right now is sporting some healthy (filthy) chainsaw bar oil, so it obviously needs a clean. I assume turpentine or mineral spirits does the trick, eh??? Then after this cleaning, I assume every month when I re-dip the chain, I don't need to re-clean it like this again, or do I?
Thanks a rack load
allout1 is offline
Old 05-05-19, 12:50 PM
Teamprovicycle
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
Liked 3 Times in 3 Posts
You can start with finishline clean rude or ceramic wax by finishline , just clean apply and keep applying every few rides . A single drip and rotation of the chain system , yes not good for wet , but you can just put wet lube over the wax , and wash it all down after the rains pass ..
Teamprovicycle is offline
Old 05-05-19, 12:57 PM
woodcraft
woodcraft's Avatar
Quoted: 1073 Post(s)
Liked 64 Times in 39 Posts
Originally Posted by allout1 View Post
and daniel san said, "it not as easy as one looks." hmmmmmmm We shall see.
My chain right now is sporting some healthy (filthy) chainsaw bar oil, so it obviously needs a clean. I assume turpentine or mineral spirits does the trick, eh??? Then after this cleaning, i assume every week when i re-dip the chain, i don't need to re-clean it like this again, or do i?
Thanks a rack load
fify
woodcraft is offline
Old 05-05-19, 01:01 PM
wgscott
Occam's Rotor
wgscott's Avatar
Quoted: 2366 Post(s)
Liked 230 Times in 144 Posts
1. Clean chain in an organic solvent to remove the lubricant and dirt. (Do this even with a new chain.)
2. Melt paraffin (canning wax) in a crock pot or something safe.
3. Immerse chain.
4. Swirl it around with a utensil.
5. Remove chain and hang it somewhere to let it drip and cool.
6. Put chain on bike.
I do this about once every 300 - 500 miles. A quick-link can make the process easier. Also, if you have two or three chains in rotation, it is much more efficient.
Chainsaw bar oil is very adhesive with respect to dust, sawdust, sand, grit, etc. Wax is pretty much the opposite. Your drive train will last a lot longer. Personally, I'd toss the bar-oiled chain in the garbage and start with a new one.
wgscott is offline
Old 05-05-19, 02:06 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Bikes: Nekobasu, Pandicorn
Quoted: 3880 Post(s)
Liked 371 Times in 238 Posts
If anyone is at all serious about chain waxing, I recommend you just go all-in. It's really not that expensive.
Pick out your chain of choice and buy 2.
Get yourself an Elite Gourmet 1.5qt slow cookerabout $16 on Amazon.
Add to your cart a 3lb bag of paraffin wax beads, about $13. It's not the cheapest per pound, but for a one person doing 1-2 bikes, it's 5+ years of wax. That bag is the exact one I bought when I started hot waxing, and only depleted it after maintaining 4 bikes for over 2 years.
Fill the crock pot about halfway with wax beads and fire it up. I run mine on "keep warm," which is plenty hot enough.
Clean the chains thoroughly, my choice is white gas (because the state of California won't let us have mineral spirits) in a suitable container (32ox Gatorade bottle) for 10 minutes or so, then let the chain dry a bit.
Plop a chain in the pot, leave it in for 15-20 minutes, until the chain gets up to the temperature of the wax. It's not scientific. Put the chain in before lunch. Don't worry about it.
Remove the chain, let it sit for a few minutes, put it on the bike.
Now take the second chain, put it in the crock pot, and turn the crock pot off.
When the chain on the bike starts to get squeaky or otherwise noisy, turn on the crockpot, and after it's hot, swap the chains. Repeat for as long as a chain lasts you. I'm big and don't get a ton of miles out of a chain, but still get ~6,000 out of a pair.
Optional: I mix in about 1oz of Slick 50 Recharged each time the wax level in the pot gets low enough to no longer cover the chain, the same time I add more wax. It seems to make the wax adhere to the chain a little better than just the straight paraffin, and my rate of consumption is about 1/4oz a month, so a bottle will last... 5 years or so? Including the cost of equipment, hot waxing the chains for 4 bikes costs me about $1 a month.
DrIsotope is offline
Old 05-05-19, 02:15 PM
philbob57
Quoted: 288 Post(s)
Liked 50 Times in 37 Posts
The paraffin is pretty flammable, so temperature control is pretty important. I use a double boiler method.
philbob57 is offline
Old 05-05-19, 02:36 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Flash point is around 400°F, well above even the “high” setting on the crockpot. Open flame would be my only concern. I want a setting as close as I can get to 212°, because I still want the wax hot enough to get any moisture out of the chain.
Old 05-05-19, 02:41 PM
philbob57
Quoted: 288 Post(s)
I use a cobbled together double boiler because I melt the wax on my stove top. When I do it, I have waking nightmares of of the thing bursting into flame. If I had a crockpot....
Old 05-05-19, 02:56 PM
August West
August West's Avatar
Bikes: Trek Domane SL6
Quoted: 35 Post(s)
Liked 12 Times in 10 Posts
Or you can get the Crock-Pot® 2qt Slow Cooker - SCR200 from your local Target for $10-12 which is what I ended up with. Works great.
August West is offline
Old 05-05-19, 08:42 PM
sdmc530
Heft On Wheels
sdmc530's Avatar
Bikes: Specialized,Cannondale
Quoted: 571 Post(s)
Liked 104 Times in 78 Posts
Molten Sped Wax and a garage sale crock pot for $4 works great.
As already stated careful on the temps it a fire hazard. Do 3 chains at a time good for 1300-1800 miles depending on conditions. 400-600 per chain.
sdmc530 is offline
Old 05-05-19, 09:30 PM
canklecat
canklecat's Avatar
Quoted: 2911 Post(s)
Liked 244 Times in 186 Posts
Gulf wax bars in a Little Dipper crock pot. Usually rotate a pair of chains, swapping around every 2-4 weeks.
I may experiment with some leftover scented candle wax. There's always some left over after the wick burns out. Scented candle wax is usually softened with a little solvent. It's soft enough that I dig out some with a fingertip and apply it to squeaky spokes on my wheelset with black spokes -- squidge a little at every spoke crossing and it'll quiet the squeaking for a month or so. I'm curious to see whether the mix of Gulf wax and scented candle wax works well on chains.
Plenty of Google references to tests comparing how paraffin compares with other lubes. Tests show it's a good, maybe even superior lube. Even if it wasn't a better lube, I'd use it anyway because it's cleaner. My bikes are indoors. I want to avoid chain tattoos on the cats, my legs and the furniture. And it's easier to handle on the road for flat repairs or occasional chain drops.
I still use wet lube on my errand bike since that's what I ride on rainy days. Park CL-1 usually lasts for months between applications.
canklecat is offline
Old 05-05-19, 10:52 PM
12boy
12boy's Avatar
Bikes: brompton sl, surly steamroller, fuji track, gary fisher bmx minivelo etc
Quoted: 127 Post(s)
Liked 2 Times in 1 Post
Straight paraffin wax will flake off very easily. Mix oil, grease, or beeswax with the wax to increase adherence. Yellow wax toilet rings are very sticky...used to be beeswax but who knows nowexactly what they are. Works great for me, though. You can also add dry moly lube. Once you have waxed a chain, if it gets noisy, just pop off the chain, wipe the grit off, and drop it in the hot wax. If it's a new chain stick it in the wax directly, the grease will help the stickiness issue. An old geasy chain can be cleaned with detergent or gas/mineral spirits etc. You can buy a used crockpot for nothing at thrift stores or garage sales and keep it for this purpose only. Turn it on, wait an hour till the wax melts, put a bit of wire through the middle of chain, long enough to hang over the edge, and let it sit in there for half an hour or so. Pull it using the wire and let it drain and cool. Piece of cake.
12boy is offline
Old 05-06-19, 04:13 AM
Trevtassie
Quoted: 338 Post(s)
Liked 46 Times in 25 Posts
Putoline Chain Wax. Perfect combination of waxy enough to not attract too much dirt or wash off, but sticky enough to stay on. Buy an old electric skillet from a thrift store and melt it into that. Much more convenient than a crock pot, heats up much faster but you still have temperature control with the thermostat.
Trevtassie is offline
Old 05-06-19, 04:27 PM
philbob57
Quoted: 288 Post(s)
DrIsotope, August West, sdmc530, 12boy, Trevtassie - Thanks. Your ideas will make my life easier. All of your ideas are better than my jury-rigged double boiler *** chopsticks method.
Oh for crying out loud - those asterisks are Latin for 'with.'
Old 05-07-19, 09:51 AM
Don777
Bikes: Cannondale R600 and Beater MTB
I have attempted to add three photos of how I do the waxing. I have been using this method for at least 12 years, but probably closer to 15 years and at least two times a month. I use an electric stove top, burner on high until the wax is melted, swish it around for a minute or so, take it out to cool a bit, and put it back on the bike while the chain
is warm to the touch. In my opinion there is no danger in melting the wax on a stove top; I merely watch it until the wax is melted. Kindly - Don
Don777 is offline
