Hi
Old 07-05-19, 04:47 PM
Popeye2419
Hi
How do I remove a cross threaded locking nut on the crank safely and not damage the threads
Popeye2419 is offline
Old 07-05-19, 05:08 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1820 Post(s)
Liked 75 Times in 58 Posts
Which part is the "locking nut"? Also one could have a good argument in saying that some thread damage has already happened with the initial cross threading.
What materials are we dealing with? What access? Do you have access to Dremel or similar tooling? Andy
AndrewRStewart
Andrew R Stewart is offline
Old 07-05-19, 05:37 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 721 Post(s)
Liked 88 Times in 75 Posts
I think that horse is out of the stable. Cross-threading by definition has damaged the threads.
dsbrantjr is offline
Old 07-05-19, 05:58 PM
andrewclaus
Bikes: 2016 Fuji Tread
Quoted: 234 Post(s)
Liked 28 Times in 24 Posts
If it's a square tapered spindle in an old three-piece bottom bracket, the good news is the part is cheap. If there's a bike co-op in your area, they probably have a large bin full of them for a buck a piece. The bad news is you need special tools and some skill to remove and reassemble.
andrewclaus is offline
Old 07-05-19, 07:06 PM
AeroGut
Quoted: 44 Post(s)
Liked 18 Times in 15 Posts
Perhaps youíre talking about the lock ring on a one piece crank (non drive side)? If so, itís reverse threaded, so make sure youíre turning it the correct way. If itís really cross threaded, hit it with penetrating oil and use a big wrench. With luck, the damage will
mostly be to the threads on the nut rather than the crank, but even if itís the crank, itís not an expensive part.
AeroGut is offline
