Chain losing tension
Old 07-19-19, 04:53 AM
smikeybikey
smikeybikey's Avatar
Hi guys-after a recent overhaul my chain looses tension when I stop pedalling or back pedal.Any ideas?I know its a question thats been asked many times but I thought it might do with some fresh input.Thanks
smikeybikey is offline
Old 07-19-19, 05:29 AM
CliffordK
CliffordK's Avatar
Quoted: 8908 Post(s)
Liked 136 Times in 113 Posts
A few thoughts.
I frequently experience a loss of tension when cross chained. It is much less common if I keep the right most rear sprockets with the large front ring, and left most rear sprockets with the small front ring. I'm not sure if there is an adjustment, but it is good to avoid.
Double check neither derailleur is rubbing, and the rear derailleur is indexed properly (shifting well both directions, and hitting the middle of the rear sprockets).
Tight freehub (cassette) or freewheel. Did you take the hub apart? I realize that will be a little subjective, unless it is really bad. You might be able to diagnose swapping known good parts.
CliffordK is online now
Old 07-19-19, 06:04 AM
Racing Dan
Racing Dan's Avatar
Quoted: 762 Post(s)
Liked 14 Times in 12 Posts
Im betting its the freehub not spinning freely. - Spin the wheel off the ground and it will pull the crank. It shouldn't do that.
Racing Dan is offline
Likes For Racing Dan:
Old 07-19-19, 06:49 AM
seedsbelize
necessary illusions
seedsbelize's Avatar
Quoted: 4863 Post(s)
Liked 61 Times in 46 Posts
Could also be a rear derailleur issue
seedsbelize is offline
Likes For seedsbelize:
Old 07-19-19, 07:46 AM
55murray
55murray's Avatar
Bikes: 1955 20" Murray modified cruiser, 2010 Nishiki Colorado MTB, 1980 Miyata 610, several other vintage coaster brake machines
Quoted: 162 Post(s)
Liked 15 Times in 13 Posts
Make sure you got the chain routed correctly through the rear derailleur... one of those old post-overhaul errors...
55murray is offline
Old 07-19-19, 10:46 AM
Iride01
Iride01's Avatar
Bikes: '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 880 Post(s)
Liked 32 Times in 28 Posts
What did you overhaul? But I agree with others you should check the freehub or freewheel or the chain routing through the DR cage.
Iride01 is offline
Old 07-19-19, 01:43 PM
shelbyfv
shelbyfv's Avatar
Quoted: 1201 Post(s)
Liked 201 Times in 133 Posts
What explanations were given before?
shelbyfv is offline
Old 07-19-19, 02:08 PM
ted_major
ted_major's Avatar
A friend had this issue recently. Turned out to be as simple as ta broken plastic spoke protector (aka ‘dork disk’) which had broken and was causing enough friction between the spokes and cassette to make the chain go slack when he coasted.
ted_major is offline
Old 07-20-19, 08:19 AM
smikeybikey
Thanks guys I can always trust this forum to cover all the bases.I actually swapped the freewheel so that must be the root of the trouble
Old 07-20-19, 07:33 PM
cpach
Bikes: Too many. Cannondale SuperSix, Trek Remedy 8, Trek Crossrip+ get the most ride time.
Quoted: 236 Post(s)
The pivot on the derailleur is also pretty easy to get contaminated. They are usually diassembleable and can be cleaned and regreased but I've seen more than a few that were too far gone.
cpach is offline
Old 07-31-19, 08:30 AM
smikeybikey
Is there any adjustment that can be made to the pivot on a derailleur?
Old 07-31-19, 06:10 PM
Nahuel_B58
CoasterBraker
Nahuel_B58's Avatar
Quoted: 9 Post(s)
Put some oil in the chain. Then in the sprocket and if you still have issues look for the derailleour.
Nahuel_B58 is offline
