How many patches before you trash the tube?
Old 07-23-19, 09:20 AM
davester
davester's Avatar
Bikes: 1981 Ron Cooper, 1974 Cinelli Super Corsa, 2000 Gary Fisher Sugar 1, 1986 Miyata 710, 1983 Nishiki Cresta
Quoted: 423 Post(s)
Liked 28 Times in 23 Posts
I just threw out a couple of tubes that had a rather embarrassing number of patches on them (about five each). I'm a bit of a hoarder and my mother taught me to never waste anything (she grew up during rationing in WWII England) so I tend not to throw out stuff that still has life remaining. I've always been of the opinion that a tube repaired with a vulcanizing patch is close to as punctureproof as the original tube. That has certainly worked for me over the years...I don't remember ever having a patch later fail as long as the original repair was good. On the other hand I know people who consider a patched tube to be fatally flawed and will immediately remove and trash such a tube upon getting home from a ride. What's your policy? Are you a pristine tube kind of person, or are your tubes more than 50% patches?
davester is offline
Old 07-23-19, 09:30 AM
SamSpade1941
SamSpade1941's Avatar
Quoted: 385 Post(s)
Liked 18 Times in 15 Posts
If I have to use a patch out on the road (rarely happens I carry spare tubes). I will usually replace the whole tube when I get home . Tubes are dirt cheap and I like the small bit of peace of mind I get from having tubes with no patches in them
SamSpade1941 is offline
Old 07-23-19, 09:36 AM
due ruote
due ruote's Avatar
Quoted: 531 Post(s)
Liked 34 Times in 24 Posts
I am lucky in that I donít get a lot of flats (maybe a dangerous statement) but like the OP I am fine with riding on patched tubes. Once I give up on them they get put into service tying up hoses or extension cords, wrapping/clamping odd shaped pieces in the wood shop, or tying boards on the roof rack.
due ruote is offline
Old 07-23-19, 09:37 AM
hazetguy
Custom User Title
hazetguy's Avatar
Quoted: 709 Post(s)
Liked 118 Times in 87 Posts
hazetguy is offline
Old 07-23-19, 09:58 AM
Pcampeau
Quoted: 45 Post(s)
Liked 11 Times in 9 Posts
If Iím out on the road and near a bike shop when I get a flat, Iíll buy a new tube just to save myself from the hassle of having to find the hole and patch it. If Iím at home, Iíll patch. Some of my bikes have tubes with up to 4 or 5 patches. In the moment when you get a flat itís cheap to just replace the tube, but when you add the savings valve of all those patches it adds up fast. At $7.99-$8.99 per tube, it doesnít take long for me to notice. There is so much glass and debris around here that I had 11 flats last year. This year so far, 4.
Pcampeau is offline
Old 07-23-19, 10:19 AM
davester
davester's Avatar
Quoted: 423 Post(s)
What are the chances of that happening? For me, it's close to zero. Throw in Murphy's Law and the chances of getting a flat near a bike shop are negative zero.
Let me just add that I usually have a tube or two with me, but since my typical weekend rides are 50 to 100 miles, the chances of occasionally getting two or more flats on a ride are moderately high (in my experience, flats come in threes). My normal procedure is to use my spare tube and then when I get home patch the punctured tube so that I'll have a spare for the next ride. Rinse, repeat. I usually only get around to ordering new tubes when I order new tires.
davester is offline
Old 07-23-19, 10:22 AM
SpeedofLite
SpeedofLite's Avatar
Bikes: Litespeed (8); Slingshot (6); Specialized (2); Kestrel (2); Softride (2); Cervelo (1); FELT (1); Cannondale (1); Fuji (1); Centurion (1); Schwinn (1)
Quoted: 133 Post(s)
Liked 37 Times in 28 Posts
</= 1. New (i.e. never flatted) tubes to begin rides. Patched tubes (once only) for spares.
If I flat on a new tube, I strip it out and stuff it away for it to be patched after the ride. I then use a patched tube (generally) to replace the flatted tube in mid-ride.
When I get home, I replace the patched tube in the wheel with a new one, and the patched tube goes back in the spare bin.
If a patched tube flats, it goes in the garbage though I admire every one of you who recycles it in some way.
WTB: Bicycling! Issues Oct 1969 and Jan 1973.
WTB: ZIPP 500 front wheel (650c clincher)
SpeedofLite is offline
Old 07-23-19, 10:28 AM
ridelikeaturtle
ridelikeaturtle's Avatar
Bikes: Bianchi Ti Megatube, M Alloy Pro, Sprint 76; Amp Research B4; Colnago Crystal; Klein Pulse; Litespeed Catalyst, Fondriest Squadra Corse
Quoted: 319 Post(s)
Liked 51 Times in 38 Posts
"Let's find out: one, two-hoo-hoo!, three!" --Wise Old Owl
ridelikeaturtle is offline
Old 07-23-19, 10:32 AM
Pcampeau
Quoted: 45 Post(s)
Here in Minneapolis were quite fortunate to have so many bike shops. I pass within a few blocks of 7 of them on my 5 mile commute. I agree with you about longer rides though, in which case I employ the same method you do. Bring a new one with me and patch when I get home.
Pcampeau is offline
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1743 Post(s)
Liked 141 Times in 103 Posts
I am on fixed income. Money spent on tubes could buy me something more permanent or better food or simply be kept in the bank. Tubes cost $5-6 each. Patches 25 cents each. A good patch job is permanent. Patches cannot be seen and weight very little so riding on them isn't an issue. So I see absolutely no reason not to keep patching tubes until they no longer work. I've tosses tubes from valve stem area failures and other un-patchable events with as many as 8 patches already. By my simple math, that is $38 I didn't spend. Or about 7 tubes I didn't put in the landfill.
79pmooney is online now
Old 07-23-19, 10:59 AM
BradH
Catching Smallmouth
BradH's Avatar
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 38 Post(s)
Liked 4 Times in 3 Posts
I've counted as many as 13 on the same tube.
BradH is offline
Old 07-23-19, 01:19 PM
SurferRosa
SurferRosa's Avatar
Quoted: 468 Post(s)
Liked 118 Times in 71 Posts
Ha ha. That's about two too many for me. I call it done at three.
The nice thing about flipping a few bikes each year is I can move stuff like a 3-patched tube over to those bikes heading out the door. So, on my own bikes, there isn't more than a patch on any. Most are free of any.
But this effort makes it a little difficult to remember ... "ok, which of you has a patch and which doesn't? Which of you was my last flat?"
my mother taught me to never waste anything (she grew up during rationing in WWII England)...
Same, pretty much. Mom's folks went through the great depression, owned a pharmacy, and they never threw out anything.
And a cult classic film, called The Gods Must Be Crazy, made a big impression on me. In it, a tribe finds a Coca-Cola glass bottle that falls from the sky (an airplane) and use it for all kinds of activities to better their lives. One of those things we toss everyday could be used as a valuable resource somewhere else...
That said, I always toss dork disks, reflectors, and kickstands. I can't do anything with 'em...
SurferRosa is offline
Old 07-23-19, 01:33 PM
conspiratemus1
Used to be Conspiratemus
Quoted: 113 Post(s)
Liked 57 Times in 36 Posts
I'm aghast that anyone, never mind a whole lot of people, would throw away a perfectly good tube just because it had an easily patchable (and patched) leak. Honestly, the patched tube is as good as new. It's just gratuitously wasteful to toss them. Eventually tubes will leak at the valve stem -- only then do they get repurposed for non-air-holding tasks (although I admit I don't have a lot of such uses so usually put them in the trash....but never tossed on the side of the road, right?)
conspiratemus1 is offline
Old 07-23-19, 02:03 PM
rustystrings61
Quoted: 297 Post(s)
Liked 80 Times in 54 Posts
I grew up 35 miles from the nearest bike shop. Patch kits are my friend. Short hops I'll have a lone spare tube and my frame pump, but longer rides or rides out into the boonies I'll take a virgin spare, a patched spare (or two) AND a patch kit. A Carradice Nelson encourages such things ...
rustystrings61 is offline
Old 07-23-19, 02:07 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Dead tubes have a lot of uses. I cut strips from them to wrap around handlebars for lights, computers, etc. (And forks and seat/chainstays for speed/cadence sensors.) They work better than bungee cord in a lot of places (and tie far more secure knots). I did a carbon fiber wrap of a broken frame, had the epoxy setting before I was ready and was struggling to get the fabric to stay down. Hastily cut innertube strips and wrapped the whole mess tightly. A lot of resin squeezed out. Next day I approached the mess with trepidation, figuring I had probably trashed the (sweet riding!) $20 frame. Unwrapped the inner tube and behold! the job looked professional like it had been vacuumed bagged. 8000 miles later I retired the frame because sooner or later it was going to break elsewhere. (It had been hit hard by an SUV.) That repair was the strong point of the bike.
I rode a charity ride where a young woman had made a rather stylish vest of interwoven innertubes.
Edit: patches do get in the way of many post-mortem uses. Fortunately I've bought enough lesser tubes to have good patch free lengths.
Ben
Likes For 79pmooney:
Old 07-23-19, 02:31 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 842 Post(s)
Works for me. If the patch holds, then the tube is equivalent to a new tube.
Install the patched tube in a wheel at home to make sure it holds for a day, before using it.
I take 2 spare tubes on rides, and patch the flat later at home.
FYI: http://www.bikeforums.net/forum-sugg...ad-please.html
Homebrew01 is offline
Old 07-23-19, 02:55 PM
canklecat
canklecat's Avatar
Quoted: 2910 Post(s)
Liked 243 Times in 185 Posts
I think I'm up to six on one of the errand bike's Schrader tubes. I'll keep patching until it's more patch than tube. But I haven't had any puncture flats since switching to Michelin Protek Cross Max tires. Bulletproof.
For my road bikes I use Lezyne self-sticking patches, which are nearly paper thin. They don't interfere with seating tires on tight fitting rims. I may have three patches on one tube.
canklecat is online now
Likes For canklecat:
Old 07-23-19, 03:34 PM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1567 Post(s)
Liked 21 Times in 19 Posts
If the valve fails, the tube gets tossed.
And sometimes the tube cannot be patched. If the puncture is too close to the valve, or another patch, the tube gets tossed. If the valve core is removable, I'll save that.
Some patches just don't hold air. If that happens, for whatever reason, I may try doing the patch over, though it is likely to tear when I pull the failed one off. If so, the tube gets tossed.
And then there's the blowout, a big star shaped gash. Tube gets tossed.
If none of the above, I don't care how many times it's been patched.
rhm is offline
Old 07-23-19, 03:48 PM
Salamandrine
Quoted: 1798 Post(s)
Liked 89 Times in 66 Posts
I usually limit it to 3 or so. Might vary from time to time. With a proper patch applied correctly, there's not really any reason why you couldn't patch many more times than that. I'm just being careful. Also, I always spring for genuine Rema patches. Never had one fail.
No patches at all on front tires/tubes. If they get patched they move to the back.
Salamandrine is offline
Old 07-23-19, 03:49 PM
miamijim
miamijim's Avatar
Quoted: 325 Post(s)
Liked 6 Times in 6 Posts
I donít patch tubes.
Way back in my shop days we had a customer with 36 patches. He was disappointed in having to buy a new tube.
miamijim is offline
Old 07-23-19, 05:20 PM
conspiratemus1
Quoted: 113 Post(s)
Originally Posted by miamijim View Post
I don’t patch tubes.
Miamijim! Great to hear from you.
Your customer must have been Scottish, like me. There is a joke about a sergeant-major from one of the Scottish regiments of the British Army who brought a used and battered condom into a shop in Aberdeen (a bike shop, I suppose, being latex and all) and asked if it could be repaired. The shop man, familiar with this sort of request, squinted at it and quickly itemized all the bits of work that would need to be done to make it serviceable again, then quoted him a price of 3 shillings 6 pence. The RSM nodded in tentative agreement but then fixed him with a flinty gaze: "Ver-r-ry well....but I'll have to fir-r-rst obtain author-r-r-ity from the r-r-regiment."
Old 07-23-19, 05:31 PM
tkamd73
Bikes: 1984 Schwinn Supersport, 1988 Trek 400t, 1977 Trek TX900, 1982 Bianchi Champione del Mondo, 1988 Trek 400 Elance, 1978 Raleigh Supercourse, 1991 PDG Paramount OS
Quoted: 165 Post(s)
Liked 20 Times in 20 Posts
I don’t patch tubes either, just install a new one. Less time consuming, and tubes are cheap.
Tim
tkamd73 is offline
Old 07-23-19, 05:49 PM
CyclingFool95
Bikes: 1987 Pinarello Montello, 1995 Litespeed Classic, 1996 Colnago Master Light, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP
Quoted: 55 Post(s)
Liked 14 Times in 12 Posts
$3 or less gets a Conti tube. I carry 2 spares on my rides, plus two CO2 cartridges, and a pump. I don't patch.
CyclingFool95 is offline
Old 07-23-19, 05:57 PM
miamijim
miamijim's Avatar
Quoted: 325 Post(s)
I searched his surname....either Southern Germany/Rhineland or North Yorkshire. That's close to Scotland!!
miamijim is offline
Old 07-23-19, 06:10 PM
wahoonc
Membership Not Required
wahoonc's Avatar
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 67 Post(s)
Depends...
My personal record was 11. I have no problem with patching a tube. With most of my bikes, it is easier to patch than replace the tube. So patch them I do. I am don't like the CO2 cartridges, I consider them wasteful, ditto just swapping out the tube for a new one. Must be my Scot's heritage.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"
_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"
_krazygluon
wahoonc is offline
