Shimano 6870 Di2 Shifters Controlling Garmin
Quoted: 7 Post(s)
Liked 5 Times
I asked this question last year, but I believe this had now become possible, do along again:
Searched the forum and the internet and not really getting a clear answer on this. Can you control a Garmin Edge 520 using 6870 shifters? I currently have the 1st Gen D-Fly, SM EWW01. What is the minimum I need to make this happen? My current setup uses full Synchro Shift and if possible, I'd like to use the forward buttons on the Di2 levers to control the Garmin. 6870 group set, with a SM EWW01 D-Fly and the battery has been upgraded to BT-DN110.
Quoted: 3230 Post(s)
Liked 2,079 Times
6870 is an Ultegra group. As I recall the BT buttons were introduced with the 8050 series, so, No you cannot do Garmin control with 6870 shift levers.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Are the buttons you want to use deprogrammed from shifter functions in e-tube?
Liked 2,079 Times
I assume if using Synchro shift you could configure to where you don’t use the left shift system at all and could then make it move Garmin screens. But as Marcus stated, you need to to figure e-tube to have a set of shift functions on a shifter do nothing. Not sure that can happen.
Quoted: 7 Post(s)
Liked 5 Times
That’s the rub, you can reprogram the standard shift levers/buttons to do something else, but you don’t get the top mount extra buttons.
Liked 406 Times
I do not currently have the option to change any of the buttons to the Garmin Channel options. I believe it is because the 1st Gen DFly I have is incompatible. I went into the configuration system and created a setup manually applying Garmin Channel 1 to left shifter X and Garmin Channel 2 to right shifter X, saved it as a file and tried to apply the configuration. ETube discarded the changes saying the Garmin buttons could not be applied. I have the new Bluetooth/ANT+ EW-WU111 on order. I found a YouTube video from a gentleman using that configuration and he is able to use his 6870 shifters to control his Garmin headunit:
Does the Garmin itself have a button setup menu you can use?
Quoted: 7 Post(s)
Liked 5 Times
I believe I have seen that option, but I don't have any buttons on the shifters assigned to any of the Garmin Channels. When configuring the shifters I only have the option of assigning front and rear derailleur up and down shifts. I'm pretty confident that changing it the DFly unit to the newer version will make this option available.
Liked 2,079 Times
Yes it does. I just had to factory reset my 1000 and as per the setup and when connecting my Di2 system the Garmin screen had a number of options as to how the the 8050 buttons functioned, - L Single Press, L Press and Hold, etc...
Quoted: 7 Post(s)
Liked 5 Times
Can now confirm that 6870 Di2 Shifters can control a Garmin head unit (Edge 520) with the newer DFly, EW-WU111. As soon as I swapped it for the first gen DFly, there were new options that were previously not available in the E-Tube desktop version. Programmed buttons and just confirmed everything is working as it should.
