Sugino Cranks
Sugino Cranks
Posted this in the fixed gear thread by accident,so I'll ask the question here for a new thread and info:
Looking to see how the vintage Sugino cranks rank?
The ones I see commonly are Sugino RT, Sugino GT, & Sugino AT. Are there any more? If so, what were their uses (i.e., touring, racing) and how do they rank in terms of quality?
Phyllo-buster
Quoted: 2297 Post(s)
Liked 2,054 Times
Mighty, Maxy, Mighty Comp, Super Maxy,, Super Mighty Comp, Super tour, 75, VP, Aero, VT, GT, GP, GLP, and more.
Too many to simply rate. Super Mighty Comp with very much the equal of Campy Record Strata and Pista. Maxy were lower end swaged. Many others in between.
I don't know anyone who wouldn't use them. Great components.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Sugino Cranks
velobase.com is a good source for this kind of information.
This link will take you right to the Sugino section:
VeloBase.com - Component Listing
In the early 70's Sugino came into the world market for alloy cotterless cranks. Around 1972 Sugino was one of first Japanese manufacturers to break into the European cycling component market. During the bike boom of the early 70's the French component makers were overwhelmed and couldn't meet the demand for better quality products. This opened the door to Japanese companies like Sugino, SR Sakae Ringyo, DiaCompe, Suntour and others.
The Sugino Mighty Competition cranks were some of the first Campagnolo knockoffs. They used the same 144mm BCD size chain rings as Campy and all the parts while lower quality, interchanged with all the Campy pieces. The arms were forged like Campy's not cast.
They were available with British, French or Italian BBs and British or French pedal threads.
About the same time Sugino introduced their cheap model, the Sugino Maxi cotterless cranks with pressure cast arms ("melt forged" a Japanese euphemism for pressure casting). The large chain ring was swagged onto the DS arm. That was the main problem with those 1st generation cranks. Even a moderate sized westerner could spin the arm in the swagged on chainring.
They were designed for the slightly better than entry level bike market during the bike boom as a solution to cheap steel cottered cranks that always loosened up.
That's a start. Check out the velobase link for more info.
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
Sugino...sigh. Some fun items.
--The 75 series levers, pedals, levers, calipers, derailleurs...carbon and elegant looking
--The tension disk wheel
--Aero Mighty pedals were beautiful.
Most of the cranks emulated Campy but a few deviated...Impel and the Guines, and Qualete guys. I remember the Bicycling magazine ads for those.
Best triple cranksets on the market at the time, IIRC?
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
Sugino Mighty Compe cranks look great and work well until they break. I snapped one across the pedal eye during an out-of-saddle climb (ouch), but it was a 1970 production first-generation model with at least 25K miles on it. I noticed that it had at least 1mm less metal on each side of the pedal eye than the ca. 1974 second-generation specimen I replaced it with. A millimeter doesn't sound like much, but it is a significant fraction of 6mm. Given this observed revision, I am guessing I am not the only one to have experienced pedal eye failure in an early Sugino crank.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Sugino AT cranks are excellent. You will see them Spec’d on a lot of high-end tourers and mountain bikes.
Hmmm,... I bought a Sugino Mighty Comp sometime early in the winter of 1973-1974. I bought it at the now-defunct Stuyvesant Bicycle in lower Manhattan. I still have it.
They never had that lustrous finish Campagnolo had, not even when brand new.
Regarding breaking the crank, I am a pretty big guy with strong legs. I used to routinely ride in very hilly areas. I used to tour on a loaded bike in mountainous areas. I did everything with it except officially "race". It's was perfectly fine back then and it still is. I would not hesitate to use it if I had a need. Mine is a time-proven (reliable) survivor.
Product improvements aside, I wonder if there were latent defects in some of the production units. That would explain why mine was/is fine and yours broke. Campagnolo has had this problem, too.
Quoted: 4802 Post(s)
Liked 3,923 Times
And if your knees like low Q-factors - those old Suginos had straight crank arms. I'll ride any of the Suginos with one piece drive cranks. (I'm guessing it won't be hard to miss those 1st generation ones that John E broke.)
The straight 110-74 BCD triples are the sweet knee savers. Thank you Sugino for making so many of those! I set them up on any old Shimano BB, measure how much clearance I have on the drive and non-drive sides, calculate the minimum spindle length and offset and place an order with Phil Wood. My best bike is now 9-speed with a 50-38-24 and a Q-factor of 139mm. Knees love it. (Actually it is not a Sugino. It's Specialized made by probably SR. Details do not look like Sugino but overall shape, concept, and fit very similar. 110-74 BCD like so many Suginos.)
I have a Sugino AT triple crankset on my Miyata 1000, but I'm considering on switching it out because it rides so nice and hard to find. Might replaced it with a Shimano 600 triple crankset.
Phyllo-buster
Liked 2,054 Times
I've heard of more NR cranks failing than Mighty Comps, all due respect to @John E. There was even an NJS Mighty Comp for track so the quality was generally top shelf. Crap happens though. The only crank I ever broke was an Arabesque, halfway up the arm with a big void in the middle. It hurt me when it snapped but fortunately I didn't fall into rush hour traffic.
Quoted: 355 Post(s)
Liked 345 Times
Italvega and Torpado Enthusiast
Phyllo-buster
Liked 2,054 Times
JJam2112, that LOTUS is a museum piece. Did you get the brakes squared away?
Quoted: 4510 Post(s)
Liked 6,377 Times
Just chiming in here, the "Mighty" Sugino Super/Mighty Competition, easily one of if not the best in the business, looks, strength, brutal toughness, period.
Likes For merziac:
Phyllo-buster
Liked 2,054 Times
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
1985 Trek 620 by Dave The Golden Boy, on Flickr
IMG_1728 by Dave The Golden Boy, on Flickr
FWIW- those two are probably the nicest 110/74 triples ever made. Much prettier and more graceful than the M730 XT cranks.
Commence to jigglin’ huh?!?!
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,390 Times
An apropos thread - I shot this picture at a semi-local co-op recently. Looks like one of the Usual Suspects:
Quoted: 741 Post(s)
Liked 818 Times
I built up this 52/34 compact Sugino GT on my Peugeot PR10. I really like the shiny appearance with the Pug's gold paint. It actually worked pretty well with a 6 speed 26t freewheel, and the old Simplex RD seemed OK with it. I have since replaced the Sugino with a Stronglight drillium 99, in keeping with its Frenchness, but it was a successful experiment.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
From the looks of it, they weren't exactly "open"!
Likes For ThermionicScott:
Liked 4,390 Times
That’s their old location. They’re moving from it - and there’s at least 2000 bicycles in there.
I was busy picking up three of these adorable 650C kids track bikes (lugged diamond frames!) for the local bike advocacy program that I work for, hence why I was in that pitch darkness. They have a fleet of 40 or so (split half and half between 48cm 700C frames and these tiny 650C machines) from the Brian Piccolo Park Velodrome, which used to have a youth program.
Sorry, not a Sugino crankset on these, just a 155mm generic triple.
P.S.: The co-op has had them for a while now and nobody has shown interest, so I decided to stick my neck out for my program and offer to convert three of them into road bikes, even though we really don't have the funds to experiment with these. They were built with road crowns and full-size Columbus road blades cut down to length, so there's no chance of bending blades here if I drill the crown and stick Tektros on them. (I'm open to any donations of 650C tires, singlspeed freewheels and kids-sized North Road handlebars).
-Kurt
-Kurt
Liked 2,568 Times
Liked 4,390 Times
More importantly, the rest of the 650C fleet uses proper track crowns that I won't risk drilling, and the no-budget build means finding 650C forks puts them out of the running. The 700C bikes are probably too big for this type of repurposing, especially given the lack of BB drop.
Geometry is the same on all of them though, so despite the track crowns, they still have clearance - proof that they were built quickly to supply the velodrome's order. They're not by any means badlybuilt, but Confentes they're not.
/thread hijack
-Kurt
