Late 80s Puch Mistral Leader
Quoted: 767 Post(s)
Liked 1,898 Times
I hesitated to create a thread for this bike as it's not really all that special. It's a mid-range model for sure. But, I have only seen two others like it online, and I did score it new in box. This is a Piaggio-built Puch, made from Columbus Cromor with "Quattro" branded components. Here's the breakdown:
· Frame/Fork: Columbus Cromor, 55cm ST, 55cm TT, 40cm chain stay, 105cm wheelbase, Gipiemme forkends and dropouts.
· Headset: Ofmega Master
· Crankset: Ofmega “Quattro” 52/42
· Bottom Bracket: Ofmega
· Pedals: Ofmega Master Pista w/Ale clips & white leather straps
· Derailleurs: Suntour “Quattro”(Cyclone 7000)
· Freewheel: Suntour 7 speed 13-26, w/ Suntour chain
· Shifters: Suntour Accushift downtube
· Rims: Ambrosio Extra Elite Durex 19 36h
· Hubs: Quattro (Ofmega?)
· Brakes: Modolo “Quattro” (Mach 1?)
· Handlebar: Puch 39cm (ITM?)
· Stem: Puch branded ITM, 80mm
· Seat Post: ITM fluted, 27.2
· Saddle: Iscaselle, white
· Wrap: Bike ribbon, white
There are also the following identifying characteristics:
S/N: 2698 9 - L
Markings on the box: PD937 Leader 55cm Pearl wt. PH29xx27523 BUS
"The Sports Authority" (red and black rectangular sticker)
From what I've been able to gather, this seems like a near exact match to a 1989 Bianchi Campione D'Italia. The pearl white paint is really nice! Ride-wise, it is an absolute joy! At 55cm, it is as small as I can comfortably go. The bike is stable at speed, and corners really well. With 253 miles on it, I am really happy with it and will hopefully enjoy it for many, many years. I may switch to a longer stem at some point. We'll see. I have posted photos of it elsewhere in this forum, but here it is again.
Just after initial assembly
Trying to capture the paint
During a ride on 8/12.
S/N: 2698 9 - L
Likes For BFisher:
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
New in the box? Cool. Yeah some later ‘80s Puchs were built by Bianchi so the probably the same as the CdI except color and decals.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Quoted: 5888 Post(s)
Liked 3,471 Times
This bike looks great. The parts group is good and those are quality rims. Enjoy your new old bike!
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
How delightful! Kudos.
Quoted: 1088 Post(s)
Liked 1,205 Times
As someone said about one of my bike frames recently -- for nothing special, that's pretty special! Very nice!
Likes For noobinsf:
Quoted: 767 Post(s)
Liked 1,898 Times
Thank you all kindly.
As far as the rims, as a wheel set they ride really well. I like them a lot for that. But, their reputation for tire mounting difficulty is well deserved. The bike came with wire-bead Michelin Select Sport 700x20 tires. My initial plan was to swap them for some new, kevlar-bead lightweight Panaracers. The Panaracers would not go on the rims without severe struggle. No way was I gonna get stranded with a flat on tires I couldn't mount. So, I put the original tires back on and have been riding them. Surprisingly, those NOS tires ride really, really well. They shocked me, and are holding up well so far. On these rims they actually measure 22mm wide.
Quoted: 767 Post(s)
Liked 1,898 Times
Here are the instructions and 3 year guarantee that came in the box. It appeared that the little green and white label was a sticker that had been attached to the seat tube, but the glue has since dried up and it fell off at some point.
Bikes: '68 Raleigh Suberbe, '92 (German) Centurion Equipe, '85 Schwinn Peloton, 1983ish Zunow Road Racer project, '69 Squanch Super Tourer, 1980 Bianchi Super Corsa, '82 Austro-Daimler Vent Noir, '89 Miyata 914 project, 1982ish Bianchi Rallye
Quoted: 294 Post(s)
Liked 9 Times
Pretty! Those Mistrals always have sharp paint schemes.
I've got an early 80s 56cm 531 Puch and enjoy its ride.
Quoted: 767 Post(s)
Liked 1,898 Times
I made some changes to the Puch recently.
I changed the 80mm ITM stem for a 100mm Nitto Dynamic.
It's a beautiful stem, and I really could use a bit more reach on this bike.
The other change was to the brakes. I swapped out the Modolo "Quattro" (Mach 1)
for Ultegra 6500 calipers w/BL-R400 levers.
I do not have a positive opinion of the Modolo levers or calipers that came with this bike.
There is no comparison to the new setup. Braking is excellent now.
Likes For BFisher:
Quoted: 767 Post(s)
Liked 1,898 Times
I don't have any pics of the packaging. It came in a standard bike box - brown cardboard with green lettering, I believe. Small parts were in bags and a small white box.
On the outside of the carton there was a "Sports Authority" sticker. I assume that's where it was bought way back when.
Tire width
Hello I actually just got my hands on the exact same bike. Not in as nice shape as this one but want to make it more modern. So I was wondering how wide of a tire would fit on this frame.
Thank you.
Thank you.
Quoted: 767 Post(s)
Liked 1,898 Times
Just took a check and it looks like there'd be 3 or 4 millimeters of clearance at the chainstays with a 28mm tire. Of course, tire widths often vary from stated size, and rim width plays a role too. If I wanted to go wide on this bike, I'd try 28's. Personally, I have no desire to go wider than 25 on it.
Thank you BF. I have some nasty roads to get through on my way to work so that’s why I’m asking. I’ve got some conti ride tour 32’s that are really only 28’s when installed so that sounds like it should work. Now I have to see if I can also get some fender/ mudguards on as well. I’ll post some pic’s when it finally comes together. Thank you so much for your help.
Quoted: 767 Post(s)
Liked 1,898 Times
Mastrofrancesco , Did you ever get it together?
Well, I continued on with the upgrades and decided to go with a triple/ 9 speed setup. The inspiration for the triple came from the Box O' Crap by way of an Ultegra 6503 front derailleur, so many thanks to the person who put that in the box. Got the 6500 triple crankset, and long cage derailleur to match, Ultegra 12-27 cassette, KMC X9.93 chain, and Dura Ace 7700 downtube shifters. Wheels are Mavic Open Pro laced to 105 R7000 hubs from Velomine. DA SL-7700 with Ultegra 6500 works excellent! I had a very nice 25-mile shakedown ride today. Smooth, fast, quiet - a better bike than the rider, and prettier too!
Likes For BFisher:
BF,
Wow that Italian Puch looks great. Once I have enough posts I can post some pics. I got myself a parts bike that had Tiagra 9 speed triple and I’m hoping to put that on but with brifters. When I get the chance I’ll get it together. Seeing the work you did is a real inspiration so thank you.!
Quoted: 767 Post(s)
Liked 1,898 Times
BF,
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,061 Times
Re that sticker that was left off or fell off your bike @BFisher, here's a pic of a Puch Mistral I own (and it's for sale, folks, check out the "for sale sub-forum") with same exact sticker. As I noted in another Puch thread there was a Bianchi importer headquartered in South City (as we in the Bay Area call So.S.F.). Back in the day (late 1980s early '90s) a Design firm I worked for made a pitch to them to try to get some work...after pitching to Specialized in Mountain View and striking out! We did a company group photo shoot of all employees in our best cycling gear posed with our best bikes...to show how cycling-centered we were. Neither firm bought it, and we went back to designing beer, food packaging and corporate ID graphics. Nothing with wheels.
Likes For unworthy1:
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times
Likes For 2cam16:
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
I bought a NOS lugged, made in Italy frameset. HiTen. 8 lb frame and fork. Handles well, sure is pretty.
Quoted: 838 Post(s)
Liked 1,080 Times
Just here to say that if these are your not that special bikes you should post more of them 😂
In fact, I just changed around many of the vintage bicycle accounts I was following on Instagram in order to be able to see more mid range builds and restorations as I started to realize I was mostly only seeing one exotic italian racer after another. Hell, it’s nice to even see some nice UO-8 or similar restorations every once in awhile. It doesn’t really get old to me when it’s pretty and done well.
Quoted: 767 Post(s)
Liked 1,898 Times
In fact, I just changed around many of the vintage bicycle accounts I was following on Instagram in order to be able to see more mid range builds and restorations as I started to realize I was mostly only seeing one exotic italian racer after another. Hell, it’s nice to even see some nice UO-8 or similar restorations everyone once in awhile. It doesn’t really get old to me when it’s pretty and done well.
It is nice to appreciate the full spectrum of the bike world. The members here post some incredible builds and collections, from low end to high. It really is amazing. Something for everybody, really. And while this Puch was not a high end bike in its day, and therefore not all that special to many, there sure is something special going on when this rider takes it for a spin. It's a keeper for sure.
Likes For BFisher:
