Which handlebar type gives the best leverage for slowing down a fixed gear?
Old 08-18-19, 07:15 PM
20t
spinner
20t's Avatar
Bikes: Kilo WT
Assuming the bike has no brakes of course... Flats? Drops? Bullhorns? No real difference?
20t is offline
Old 08-18-19, 08:22 PM
AlmostTrick
Tortoise Wins by a Hare!
AlmostTrick's Avatar
Bikes: Wabi Special FG, Raleigh Roper, Nashbar AL-1, Miyata One Hundred, '68 Schwinn Orange Krate, and More!!
Quoted: 1119 Post(s)
Liked 153 Times in 94 Posts
Caliper brake(s) gives the best leverage for slowing down a fixed gear. Handlebars should be chosen based on comfort and application.
AlmostTrick is offline
Likes For AlmostTrick:
Old 08-18-19, 08:25 PM
20t
spinner
20t's Avatar
Bikes: Kilo WT
Answer the question ***** lol!
20t is offline
Old 08-19-19, 11:57 AM
Broctoon
Super-duper Genius
Broctoon's Avatar
Quoted: 273 Post(s)
Liked 10 Times in 7 Posts
Wider bars of any shape give you more leverage than narrow ones for accelerating from a stop or braking with your legs. There's no magic, undefinable quality in play. Leverage is simple geometry. Wider = more. With that said, I happen to prefer a bullhorn bar vs. a flat or riser bar when it's time to put some power to the crank. This has to do with ergonomics/physiology of my hands and wrists, not something mathematical like leverage.
Broctoon is offline
Old 08-19-19, 01:18 PM
phobus
Quoted: 137 Post(s)
Liked 23 Times in 14 Posts
A flat bar is probably easiest to shove between the spokes.
phobus is offline
Likes For phobus:
Old 08-19-19, 07:24 PM
Philasteve
Philasteve's Avatar
Quoted: 5 Post(s)
I never noticed a difference in breaking power between handlebars on a fixed gear bike. I thought it was all legs, no matter if my grip is narrow or more wide I see no benefit, standing or sitting.
Philasteve is offline
Old 08-19-19, 10:20 PM
hardboiled718
Quoted: 69 Post(s)
Liked 10 Times in 9 Posts
Bar type aside, I think body positioning is more important. You can adjust your body to make a stop while using any configuration of bars and you get used to what's most comfortable for you. Choosing bars purely based on leverage for stopping seems silly, since most of the time you're moving. Slowing your cadence will mostly be legs but can be helped by pushing forward on straight bars, or pulling up on drops/horns. Or if you want to initiate a skid it helps to get your weight forward and lessen the weight over the rear wheel.
hardboiled718 is offline
Old 08-20-19, 09:21 AM
daddywaddy
daddywaddy's Avatar
Bikes: fixed - bianchi sprint
bullhorns. Theyre sticking up and out and gives you the most leverage when leaning forward allowing you throw all your weight into the straps
daddywaddy is offline
Old 08-20-19, 09:55 AM
kingston
Jedi Master
kingston's Avatar
Bikes: http://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1173 Post(s)
Liked 58 Times in 46 Posts
bars don't matter when your balls are on the stem laying down a sweet fixie skid
kingston is offline
Old 08-20-19, 10:06 AM
EnzoRWD
enginerd
Bikes: officially too many now...
Quoted: 75 Post(s)
Liked 32 Times in 15 Posts
bullhorns will get your weight forward to unweight the rear tire to make a skid easier. Once the tire has gone from static to sliding contact, coefficient of fraction drops and you don't slow as fast.
I suppose the best bars would keep your weight back and allow your front brake to apply max stopping force.
EnzoRWD is offline
hay
tumbleweed
hay's Avatar
Bikes: stumpy,bianchi,Wabi classic
Quoted: 50 Post(s)
Liked 3 Times in 3 Posts
Ya but you lose all style point with your balls on the stem.
hay is offline
Old 08-20-19, 10:20 AM
kingston
Jedi Master
kingston's Avatar
I thought that's how you got style points!?! I'm old and can't keep up with all the latest trends.
kingston is offline
Old 08-21-19, 10:56 AM
REDMASTA
REDMASTA's Avatar
Location: Traveling through time, will return last week.
Bikes: Bare Rum Sword Knuckle Runner
Quoted: 214 Post(s)
Liked 15 Times in 9 Posts
no brakes you say
REDMASTA is offline
Old 08-21-19, 11:05 AM
REDMASTA
REDMASTA's Avatar
Quoted: 214 Post(s)
wider is better when you want to whip it.
REDMASTA is offline
Likes For REDMASTA:
Old 08-21-19, 02:45 PM
TimothyH
- Soli Deo Gloria -
TimothyH's Avatar
Quoted: 6814 Post(s)
Liked 634 Times in 403 Posts
Someone should make that helmet for bikes.
-Tim-
TimothyH is offline
Old 08-21-19, 03:37 PM
REDMASTA
REDMASTA's Avatar
Quoted: 214 Post(s)
-Tim-
maximum crumple zones, i'd wear it.
REDMASTA is offline
Old 08-21-19, 04:51 PM
Bandera
Quoted: 1109 Post(s)
Liked 144 Times in 93 Posts
"Straps"?
Is it 1983 again?
-Bandera
'74 Raleigh Internat'l. '77 Trek TX900 FG. '90 Vitus 979. '10 Merckx EMX3. '13 Soma Stanyan
Bandera is offline
Old 08-21-19, 06:45 PM
hardboiled718
Quoted: 69 Post(s)
^ Just curious, what's wrong with referring to them as toe straps? Didn't realize that was an outdated term.
Old 08-21-19, 06:56 PM
Rollfast
What happened?
Rollfast's Avatar
Quoted: 1624 Post(s)
Liked 108 Times in 96 Posts
Life is too short for no brakes, and even the coffee shop downtown uses a traffic signal to tell you the restroom is in use.
Old LBS guy, quite a lot of fun.
Marcia Brady rode a ROLLFAST!
Rollfast is offline
Old 08-21-19, 08:14 PM
Lakerat
Quoted: 202 Post(s)
in Not sure about bracing for deceleration on a fixed gear, but my opinion the strongest position on a bike is in the drops. I don't decelerate hard enough on my FG to ever feel like I must brace, unless its a panic stop. Then I'm bracing wherever my hands were when I had to initiate the panic stop.
I learned the difficult way that many handlebar positions is most important on a fixed gear bike, as is an aerodynamic position. Without gears you need to get in the drops in the wind to be able to stay seated without mashing hard enough to strain your knees. If you go slower, you have to stand up in the wind which doesn't work well. I tried buckhorn bars and now only use dropped bars on my fixed gear bikes.
Lakerat is offline
Old 08-22-19, 12:11 PM
EnzoRWD
enginerd
Quoted: 75 Post(s)
Are those bullhorn bars that always lead to an endo?
EnzoRWD is offline
Old 08-28-19, 03:37 PM
BicycleBicycle
BicycleBicycle's Avatar
Quoted: 34 Post(s)
Liked 6 Times in 6 Posts
I noticed a massive difference when going from drops to semi-wide flats. So much so, that I couldn't believe that I was able to control my bike with what was basically just holding onto bars close to the stem.
It's not THAT bad, but you do notice much more stability with wider bars, but you can't get a good tuck without drops which matters a lot when you ride track geo.
Best of both worlds, get really wide drops.
BicycleBicycle is offline
Old 08-31-19, 09:01 PM
veganbikes
Clark W. Griswold
Bikes: Foundry Chilkoot Ti W/Ultegra Di2, Salsa Timberjack Ti, Cinelli Mash Work RandoCross Fun Time Machine, 1x9 XT Parts Hybrid, Co-Motion Cascadia, Specialized Langster, Pink Klein MTB, Phil Wood VeloXS Frame (w/DA 7400), Cilo Road Frame, Proteus frame
Quoted: 1183 Post(s)
Liked 44 Times in 31 Posts
On a track you won't really need to brake and shouldn't and on the road with cars, pedestrians, light changes and various other forms of complete unpredictability having an actual brake could save you and your life someday. Plus you can run nicer tires that give you a better ride quality and won't run through them so much. You can get some really lightweight stuff and some really nice stuff braking wise and on a drop bar you can have a place to put your hands which is handy.
I feel like I haven't said it in a while but if you don't skid your undies why would you skid you bike?
veganbikes is offline
Old 09-01-19, 08:50 PM
Loose Chain
Loose Chain's Avatar
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 252 Post(s)
Liked 47 Times in 37 Posts
A skidding tire has lost traction, a rolling tire apply deceleration to the maximum threshold will stop quicker than a skidding tire.
Loose Chain is offline
Likes For Loose Chain:
Old 09-05-19, 09:11 AM
Philasteve
Philasteve's Avatar
Quoted: 5 Post(s)
Yeah, but I feel like you'll slow down slower too with all of your weight forward on bullhorn's.
