co2 inflaters
co2 inflaters
Old 04-20-12, 06:49 AM
skycomag
skycomag's Avatar
Bikes: Nashbar trekking bike
Quoted: 10 Post(s)
co2 inflaters
i thinking of getting a co2 inflater. i do carry a mini pump.
since my tire required pressure of 70-80 psi.
i thought if i need to repair a tire i would pump with the mini to about 20 psi then top of with the co2.
2 question:
1) how much psi does the co2 inflater inflate to?
2) which is a good one to get ?
thanks for your input in advance,
mitch
skycomag is offline
Old 04-20-12, 06:55 AM
HillRider
Bikes: '''96 Litespeed Catalyst, '05 Litespeed Firenze, '06 Litespeed Tuscany, '12 Surly Pacer, All are 3x8,9 or 10. It is hilly around here!
Quoted: 1187 Post(s)
Liked 46 Times in 41 Posts
The pressure a CO2 cylinder produces depends on the size of the tire and the size of the cyclinder. A 12 gm cylinder will get a 700x23 to near 100 psi, A 16 gm cylinder will produce about 130 psi in the same tire. Larger tires (MTB and larger road) will obviously get to lower pressure. Innovation makes good inflators.
HillRider is offline
Old 04-20-12, 07:35 AM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 2239 Post(s)
Liked 76 Times in 43 Posts
That's a little higher than I've seen. But it also depends on how much air is in the tube when you pull the trigger. Skyco wants to start with 20 psi already in the tube so he's going to see a lot higher. Usually people who think they want to do this think the pressure won't be high enough with just the CO2 cart and once they see it's fine they skip the pump. It does help to have a little air just to give the tube some shape before you install it, and you do have to make sure the tube's in there just right before you inflate and a pump can help with that. But once you've done a few you realize you can just skip the pump and everything's fine.
His 70-80 psi and his avatar make me think he's got 700x32 tires or similar so 16g carts would be the way to go.
DiabloScott is offline
Old 04-20-12, 07:52 AM
HillRider
I do the same thing. I use my mini-pump to get 20-30 psi in the replacement tube to be sure it's seated properly and the tube itself is good before using the CO2 (12 gm and 700-23 in my case) to bring it up to full pressure. I've seen a couple of damaged tubes and/or improperly seated tire beads in the heat of a roadside flat repair that I want to be sure everything is good before committing to the CO2.
BTW, 12 gm unthreaded cartridges can be very cheap as they are used in paint ball and "BB" guns. You can buy boxes of 15 or 25 at $.50 each or less at any X-Mart. 16 gm and any threaded cartridge are much more expensive.
Old 04-20-12, 08:31 AM
cycle_maven
Collector of Useless Info
Here's what I know:
1) A 12-gram cartridge filling a 700x23 tire brings it to 90 PSI. I measured this.
2) PV=nRT, where P is pressure, V is volume, n is the number of gas molecules, R is a constant and T is temperature.
3) From 1 and 2, and that the temperature is nearly constant, we can calculate the increase in pressure any tire will have after any Co2 cartridge:
a) 12 gram into 700x32 will add 46 pounds.
b) 12 gram into 700x20 will add 119 pounds.
c) 16 gram into 700x35 will add 52 pounds.
d) 12 gram into 700x26 will add 70 pounds.
and so on...
What I do is carry a combo Co2/mini pump, 2 12-gram cartridges and pump the tire up some before shooting a cart into the tire. Not ideal or accurate, but it gets me home...
cycle_maven is offline
Old 04-20-12, 09:01 AM
rydabent
Quoted: 1345 Post(s)
Liked 39 Times in 25 Posts
I have had mini pumps fail me in multiple ways, two of them just flat broke when I tried to use them. I carry one for emergencies, but I carry CO2 cartridges and use them first.
rydabent is offline
Old 04-20-12, 09:19 AM
JTGraphics
JTGraphics's Avatar
I have been using a Innovation 2nd wind its a CO2 and hand pump in 1 so no need to carry around 2 pumps.
Works great on the road for what you are talking about.
2nd Wind Road - Carbon Mini
It may not be fancy but it gets me were I need to go.
http://www.jtgraphics.net/cyclist_bicycles.htm
JTGraphics is offline
Old 04-20-12, 10:35 AM
digibud
digibud's Avatar
Bikes: Spec Roubaix, three Fisher Montare, two Pugs
Quoted: 37 Post(s)
C02 rules
As an aside I'd mention the other day when I swapped tires from my studded mtn tires to my 1.5" street tires and failed to inflate enough to properly seat the bead. A few miles down the road I realized both tires were going thunk-thunk. My hand pump would have been really hard to use to get the pressure high enough to seat the bead but it took two seconds on each tire with my C02. I use one 16gram cartridge on a 25c tire and it's enough to allow me to continue riding without fighting with a hand pump (which I also carry in case of a serious problem).
digibud is offline
Old 04-20-12, 10:48 AM
AltheCyclist
AltheCyclist's Avatar
Bikes: Many
Quoted: 5 Post(s)
I actually do the opposite - use the inflator to get started (say, up to 20 PSI) and then use pump to get to 60-80 PSI, depending on bike.
Probably doesn't matter, I've found the inflators are just a convenience to save that 1/3 of pump time. In winter when it's really cold out, the inflators are a little bit wasteful; I've had them fully discharge on me when installing the valve, likely because the metal was so cold.
AltheCyclist is offline
Old 04-20-12, 11:01 AM
skycomag
skycomag's Avatar
Quoted: 10 Post(s)
DIABLOSCOTT
"His 70-80 psi and his avatar make me think he's got 700x32 tires or similar so 16g carts would be the way to go." good eye actually there 700cx35. the original tire on the bike had psi of 35-65. my new tires are forte metro k they take 80-90 (stated on the tire) psi but keep them at 60. lots of speed bumps(tree roots) on our bike paths
skycomag is offline
Old 04-20-12, 11:30 AM
deacon mark
Bikes: Habanero Titanium Team Nuevo
Quoted: 197 Post(s)
Liked 10 Times in 7 Posts
Not to steal the thread but how many times have you goofed up and the co2 discharged. I am the dummy for sure. 1st flat I tried it on I never thought about doing a practice run and the learning curve is not bad bit I let it all out. Now I carry 2 cartridges with me right? Well I messed up again and lucky still carry a mini pump. After that i went home and practiced after this. Well one other time I tried to get it all perfect and sure enough it was cold and ops.
Moral is a small mini pump I can get to 80 that gets you going.
deacon mark is offline
Old 04-20-12, 11:37 AM
RaleighSport
Hogosha Sekai
RaleighSport's Avatar
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 65 Post(s)
Liked 3 Times in 3 Posts
I almost went that route myself, but I've got a mini pump and a genuine ultraflate, I love that I can throw any cartridge in it and that it actually has a casing grip around the co2 cartridge itself.
Your inflator doesn't have a lock to prevent puncturing ahead of time?
Progress not perfection.
RaleighSport is offline
Old 04-20-12, 11:42 AM
deacon mark
Quoted: 197 Post(s)
Oh it does I just got fumbling hands. You would think years of jazz guitar and repairing expensive guitars I could hold the thing correct.
Old 04-20-12, 12:13 PM
WickedThump
WickedThump's Avatar
Bikes: Kona JTS Frankenbike
I recently got an Innovation Ultraflate. In addition to inflating tires, it shoos away wasps really well.
WickedThump is offline
Old 04-20-12, 05:56 PM
HillRider
I've had a couple of mini-pumps fail too and the cause was water that got into the pump and rusted the ball checks to the point they wouldn't seal. The problem with mini-pums is they are used so rarely and subject to really abusive conditions routinely so they aren't tested often and are in bad shape when you really need them. Moral: see if your mini-pump works with some regularity. Get the bad news when it doesn't count.
Old 04-20-12, 06:22 PM
DMF
Elitist Troglodyte
DMF's Avatar
Bikes: 03 Raleigh Professional (steel)
Here's an odd question: If I mount a mini-pump to the seat tube, would it be better to mount it upside down? Rationale being that water can't get into the shaft from above. (If that doesn't make sense, by all means say so.)
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
DMF is offline
Old 04-20-12, 06:26 PM
HillRider
That should help but wheel spray can get water in them no matter how they are oriented. Some of mine have a rubber boot that covers the valve hole but that isn't perfect either. I expect the only real way to protect one of these things is to carry it in a rack pack or inside an under-saddle pack. Or, never ride in the rain.
Old 04-20-12, 06:29 PM
DMF
Elitist Troglodyte
DMF's Avatar
Heck, rain is my favorite riding buddy! Keeps all the other a**holes away.
- Will Rogers
DMF is offline
Old 04-20-12, 06:54 PM
catonec
catonec's Avatar
It takes alittle practice but this works well for me. I also carry a lezyne pressure drive backup
http://www.genuineinnovations.com/bicycle/road-tri-athlete/air-chuck-elite.html
File Type: jpg
2010 Kestrel RT900SL, 800k carbon, chorus/record, speedplay, zonda
1997 Trek ZX6000, 6061w/manitou spyder, xt/xtr, time atac
catonec is offline
Old 04-20-12, 07:01 PM
2manybikes
Dog is my co-pilot
2manybikes's Avatar
Bikes: 2 many
Quoted: 1026 Post(s)
Liked 28 Times in 20 Posts
Inovations has a tire size - cartridge size - pressure chart on their web pages.
It's about right. But temperature and slightly different size tires from different makers all marked the same size, change things a little.
2manybikes is offline
Old 04-21-12, 08:58 AM
gforeman
gforeman's Avatar
Bikes: Specialized Crux Elite X1, Specialized Roubaix SL4 Expert, Specialized Crux Disc
I really like this one: Portland Design Works Shiny Object CO2 Inflator
http://www.amazon.com/Portland-Desig.../dp/B003M2PNGY
Gary F.
2019 Specialized Crux Elite X1
2015 Specialized Roubaix SL4 Expert
My bike page: http://www.gwfweb.com/bicycles
Build a bike stand! http://www.gwfweb.com/bicycles/stands.html
gforeman is offline
Old 04-21-12, 09:25 AM
skycomag
skycomag's Avatar
Quoted: 10 Post(s)
aftervchecking varies site, decided on this one because of the features: Genuine Innovations Ultraflate Plus.
thanks to everyone for your imput,
mitch
http://www.genuineinnovations.com/bi...s-clone-2.html
skycomag is offline
Old 04-21-12, 11:03 AM
WickedThump
The chart on Innovations site explains a lot. I bought an ultraflate because it can use the inexpensive CO2. Now I see why I might want to carry extras.
Old 04-21-12, 06:36 PM
2manybikes
Dog is my co-pilot
2manybikes's Avatar
Bikes: 2 many
Me too, except an older version. I buy the 12 gram threaded cartridges at Walmart for 50 cents each. A box full at one time, maybe 24 in a box, I forget.
They are also used in air guns/bb guns, I carry three cartridges. I usually just use one for a 23mm tire. I don't need the highest pressure in that tire. If I want higher pressure, I put in 10-20 lbs with my mini pump, first. It's much easier to pump first at low pressure.
The temperature of the ambient air changes the pressure too. They don't work well at 20F. One needs to warm them up under your coat first..
Edit: oops, I mean unthreaded
Old 04-21-12, 06:49 PM
mmmdonuts
Gluteus Enormus
mmmdonuts's Avatar
Bikes: Yes
mitch
Good choice. That's about as versatile as they come.
mmmdonuts is offline
