There's a mouse in my derailleur
Old 03-09-14, 11:26 AM
dweenk
dweenk's Avatar
Quoted: 577 Post(s)
Liked 12 Times in 10 Posts
I went for a 15 mile ride this morning. On the way home the RD began making a high pitched squeaking noise. I think it is coming from either the jockey or guide wheel. The noise is not constant, and it is most prevalent when I'm on the small chain ring and the next-to-largest rear cog. I'm running a six-speed cluster with Shimano derailer from the late 1980's.
Naturally, the noise goes away if I'm not pedaling. Anyone have a tip on isolating the noise?
Sorry about the spelling in the title.
dweenk is offline
Old 03-09-14, 11:34 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1198 Post(s)
Liked 54 Times in 41 Posts
If it was my bike I'd spray a little silicone lubricant on the derailleur pulleys and see of that fixes it.
Retro Grouch is offline
Old 03-09-14, 11:41 AM
lopek77
Bikes: With round 700c & 26" wheels
Or try WD40 first to clean it. I wasn't a big fan of WD40, but I found it very useful all around cleaner with "greasing" capabilities.
lopek77 is offline
Old 03-10-14, 06:00 AM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 558 Post(s)
Liked 75 Times in 64 Posts
Tsk.
The design of RD pulleys is calculated to minimise the lube being washed out of them, so just spraying them with some crap is more likely to just make a mess, I reckon.
Overhauling them is pretty simple. Derail the chain off the chainring, and just undo the bolts retaining the pulleys.
Unless you have fancy BB ones (which you obviously don't), there are four parts - a dustcap/thrust bearing each side of a metal bush through the plastic pulley. On Shimano derailers (and some others) the upper pulley has a metal sleeve in it and the pulley is slighty narrower than the bush to allow some slight lateral movement.
Clean, grease or oil, and reassemble.
Kimmo is offline
Old 03-10-14, 07:10 AM
Phil_gretz
Journeyman Bike Commuter
Phil_gretz's Avatar
Bikes: '71 Jeunet 630, '79 Peugeot PXN10LE, '88 Fuji Saratoga, '13 Motobecane Fantom29 HT, '16 Motobecane Turino Pro Disc, '16 Motobecane Gran Premio Elite, '18 Velobuild VB-R-022
Quoted: 626 Post(s)
Liked 132 Times in 80 Posts
^^agree. Remove rear wheel. Break chain. Unbolt derailleur cable anchor. Remove rear derailleur. Disassemble pulley cage assembly. Clean entire derailleur. Grease pulley sleeves. Reassemble derailleur. Lube all pivot points on derailleur, all threaded parts. Exercise. Wipe off excess.
Degrease and lubricate chain while it's off the bike.
Reassemble bike.
This is good to do every year of riding, or so, anyway.
Phil_gretz is offline
Old 03-10-14, 07:19 AM
cny-bikeman
Mechanic/Tourist
Bikes: 2008 Novara Randonee - love it. Previous bikes:Motobecane Mirage, 1972 Moto Grand Jubilee (my fave), Jackson Rake 16, 1983 C'dale ST500.
Quoted: 477 Post(s)
If the rhythm is uneven, and especially if the rhythm per crank rev is different on different chainrings then it's the chain. If it's a more even rhythm or constant it's the pulleys. Some lubes are not good at keeping out water, and the chain can squeak even if it appears to be lubricated. I don't know about the current formulation, but many years ago Triflow was well-known for that behavior. If you determine the noise is in the chain and lubrication does not resolve it you need to either remove and totally clean it in solvent, or if unable to do so spray it with WD-40 and then re-lube.
There's no such thing as a routine repair.
Don't tell me what "should" be - either it is, it isn't, or do something about it.
If you think I'm being blunt take it as a compliment - if I thought you were too weak to handle the truth or a strong opinion I would not bother.
Please respect others by taking the time to post clearly so we can answer quickly. All lowercase and multiple typos makes for a hard read. Thanks!
cny-bikeman is offline
Old 03-11-14, 02:31 AM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 558 Post(s)
No need to break the chain; it's free as soon as you remove a pulley and loosen the bolt on the other one.
No need pull the wheel and RD off either, unless you get into a cleaning frenzy. The chain only cares about the rings, cogs, pulleys and inside of FD and RD cage plates.
You might prefer to remove the wheel rather than derail the chain off the ring to give some chain slack though, or you could just master the technique of replacing the pulleys with the chain in place; not real tricky.
Screw the upper pulley on, leaving the bolt loose enough for the inner cage plate to swing. Rotate it so the tab allows the chain through, then place the lower pulley against the chain and push it into position, while sandwiching it between the cage plates and holding the outer plate forwards with your other hand. It should be pretty easy to line up the holes so the bolt can go in; you can let go when you get it started in the thread.
All this in small/small, of course.
Kimmo is offline
Old 03-11-14, 04:37 AM
Phil_gretz
Phil_gretz's Avatar
Quoted: 626 Post(s)
Kimmo,
Of course, your right. This approach would be fine for you or me, where we'd want to go to the cause, get it corrected, and get that bike done to move to the next one. But for the OP, I thought that it would be instructive for him to view the parts as independent parts of the whole. He likely hasn't done a careful inspection and cleaning of the chain, and disassembling / repairing a derailleur in situ can be difficult while fighting against chain tension and the pulley cage. My advice was to break things down to their constituent parts, to inspect, to learn, and to re-integrate, thereby helping the OP to diagnose and correct his issue(s).
I'll now dismount my soapbox, and break it up for firewood. It's cold and lonely here in thoroughville.
Phil
Old 03-11-14, 01:06 PM
DMF
Elitist Troglodyte
DMF's Avatar
Bikes: 03 Raleigh Professional (steel)
I've heard this type of noise when the CHAIN needs lubing. Done it recently?
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
DMF is offline
Quijibo187
Classic & Vintage
10
06-04-10 09:39 AM
Vern
Singlespeed & Fixed Gear
74
11-04-08 04:04 PM
b_young
Commuting
24
09-20-07 02:23 PM
