What's a good Tire Pressure for a Road Bike for sport riding?
My tires on my 2016 Giant Defy got softer through the winter and I let them stay that way. It rains out here a lot in the Pacific Northwest and I use a lot of uneven roads and sidewalks and it gives me a factor of safety. When the roads get really bad, I use the Trails. After all its a Giant Defy. So I think they may be at 60 psi now. Of course I use Schwalbe Marathons, the world's heaviest tires, because I don't want to deal with flats. It's spring now and time for service. I'm no speed demon but when I put some air in my other bike's tires, my rides got easier.Where should I be at?
Likes For tFUnK:
Quoted: 427 Post(s)
Liked 700 Times
So many variables that guidelines are just that, similar to trying to get the right size bike from the sizing guidelines from the mfrs. Just don't run your tires at max pressure listed on the sidewall. Maybe start 10-15 lbs. less than max and go down from there until you find the best pressure for your tires, your weight, and road surfaces on which you ride. Of course, don't go so low that you risk pinch flats. And your rear tire carries most of the weight, so it can be a bit higher psi than the front. Experiment, you'll find what is best for you.
Likes For freeranger:
Quoted: 2497 Post(s)
Liked 741 Times
Quoted: 4420 Post(s)
Liked 4,873 Times
Likes For PeteHski:
Quoted: 2333 Post(s)
Liked 2,097 Times
Go by feel. For 32 mm tires, it is a smidgeon (55-60 psi), 28mm tires a dash (70-75 psi), and 25 mm....just a pinch (85-90 psi). The odd thing are the sizes, the actual widths vary considerably compared to the label, so, much like baking, you must adjust
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I run my tires somewhere between the max pressure on the sidewall and what the voices on this forum tell me.
Seriously though, inflation pressure is a dead horse that has been beat to death as long as I've owned bicycles and I'm kinda old. The calculators on the internet range from the simple inputing your weight and tire width to adding so many variables it seems like you are trying to make financial plans for retirement. I suggest trying one of the calculators ( I didn't even look to see which one was recommended earlier a few replies up) and make adjustments from there.
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,846 Times
As always = Depends.
Tire width, rider weight, surface ridden, type of tire. Etcetera.
Likes For Wildwood:
Quoted: 6199 Post(s)
Liked 4,816 Times
It varies by the road surface you are riding on. So just pick a number and start with that. After a few rides change the number up or down. Ride a few more rides and see if you do or don't like that compared to the first number. Adjust accordingly till you find your PSI number.
If you get pinch flats, you've gone way too low for your road conditions regardless of how comfy the ride may have been.
Likes For Iride01:
Quoted: 4227 Post(s)
Liked 2,488 Times
I just go by feel according to the conditions that I am riding in, no need for any fancy calculations.
Likes For wolfchild:
Liked 4,873 Times
The other thing I check is if the tyre manufacturer has a specific pressure guide for their tyres. For example Pirelli road tyres come with specific pressure recommendations for rider weight, rim width, speed/comfort priority and wet/dry conditions. But some manufacturers are not so specific, sometimes only stating maximum pressures.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Even the SRAM calculator states that it is a starting point. Yet in regular internet fashion, someone is going to come along and argue not all calculators factor in this, that and the other thing and without a digital tire gauge accurate to within .01 psi you can't get the correct tire pressure and riding with the wrong inflation will cause your babies to be born naked and without teeth.
Likes For Chuck M:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Yet another option, split the total weight between wheels and find reasonable starting points for front and rear wheels off this chart:
I run 32s on my road bike, total weight is 210 pounds but I figure more even split because I stand a lot. I end up running about 57 front/60 rear.
Otto
Otto
Quoted: 970 Post(s)
Liked 1,632 Times
Gee... I just go at least 1/2 Bar - 7 PSI under the max pressure embossed on the side of the tire.
I guess I should really be paying more attention to using the correct pressure. I am sure if I were carrying a heavy load on a tour it would be critical...
Wonder what his pressure
flickr.com/photos
is?
flickr.com/photos
is?
Liked 741 Times
I did take a look at the calculator. There's like 20 fields?! And maybe I only have to make the calculation(s) each time I change tire brands but am I really supposed to check my tires with a gauge before every ride? Guaranteed the pressure changed since the last one. When did a practiced thumb get kicked to the curb by a digital gauge accurate to 1psi?? I don't know about your gauge but it's really hard not to lose at least 5psi, even 10psi, just getting the pump head to seat properly with mine. Really not sure when the obsession with a particular pressure for x, y and z parameters supplanted the thumb.
Likes For Leisesturm:
Liked 741 Times
Otto
Otto
Expired Member
Quoted: 3683 Post(s)
Liked 5,448 Times
Get a decent pump with a gauge and use it before each ride. Not complicated.
Likes For shelbyfv:
Expired Member
Liked 5,448 Times
Liked 2,488 Times
Liked 4,873 Times
How you set and check that pressure is another story. But at least knowing what pressure you should ideally be running is a good start. If you are running 90-100 psi on 28 mm tyres then you are almost certainly well above the optimum unless you are very heavy. It would only take you a moment to check on that calculator.
Liked 4,873 Times
Likes For PeteHski:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
I did my own static measurements of weight distribution in various riding positions and found that it can be 70% on the front wheel when standing or 60% on the back wheel when back on the saddle.
Trying recommendations from the chart seemed too soft in front so I based tire pressures on the lowest pressures that didn’t cause issues in feel or handling. I’m riding crushed stone so I want the lowest pressures that work well, to improve comfort.
Otto
Veteran, Pacifist
Liked 4,846 Times
One of the main determinants will always be the rider's perception of a 'nice feel'. Some want a cushy cloudlike road ride, others want a very firm tire, others may pump to near tire max for smooth pavement rides.
Likes For Wildwood:
Bikes: Aurelia*Bianchi*Cannondale*Colnago*Dahon*Giant*Haro*Lynsky*Monkey Faction*Origin8*Panasonic*Paramont*Peugeot*Ross*Schwinn*SE*Specialized*Trek
Quoted: 58 Post(s)
Liked 26 Times
I usually go by the pressure on the side of the tire minus a few pounds less.
Likes For 7up:
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 414 Post(s)
Liked 927 Times
The stiffer the sidewall, the more energy is lost in flexing it, so higher pressure is a benefit. Try 90 psi in your Schwalbes and see if they don't roll easier.
