What's a good Tire Pressure for a Road Bike for sport riding?
#52
Quoted: 4420 Post(s)
Liked 4,873 Times
It's not complicated, it's just dumb. Making the simple too complicated is the problem.
I tried the SRAM calculator above. What a joke. It recommended 60 lbs in my 700 x 32 tires for road riding. That's gravel tire pressure. It's more like 70-80 for my tires on the road.
Never ceases to amaze how people want to make the simple so complicated.
What tyres are you running out of interest?
Likes For PeteHski:
#53
Quoted: 4806 Post(s)
Liked 3,933 Times
#54
Expired Member
Quoted: 3683 Post(s)
Liked 5,448 Times
#55
Quoted: 3515 Post(s)
Liked 2,929 Times
#56
Quoted: 2976 Post(s)
Liked 1,182 Times
I also have some Conti Terra Speeds 700 x 40 that will fit on the bike. I will run those at 50-60 for gravel riding.
#57
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
#58
Liked 1,182 Times
According to me and where and how I'm riding. It's called "ideal" tire pressure and not "correct" tire pressure.
Ideal pressure is about finding a balance between reducing rolling resistance and increasing comfort. And that's different for everyone. Real world road conditions, make up of tire (higher or lower TPI), rider weight, normal riding position, tubed or tubeless etc. and not some silly mathematical formula or chart, will dictate what the tire pressure needs to be...And that is determined by experimentation.
#59
Enthusiast
The calculator gave me 63.4 psi front and 67.4 psi rear for road riding. I have 700c x 28 tires on a Canyon Ultimate CF SL 8. I have been running them between 70 and 80 psi. Maybe I will try the lower pressure, or at least the differential of 4 psi between the front and rear.
#60
Quoted: 3958 Post(s)
Liked 7,312 Times
That's impressive, considering the measured rolling resistance of a 32 mm GP5000 differs by about 1 W at 60 psi versus 80 psi (at 18 mph.)
Likes For tomato coupe:
#61
Expired Member
Liked 5,448 Times
Likes For shelbyfv:
#62
Liked 4,873 Times
#63
Liked 7,312 Times
The Zipp/SRAM guide doesn't claim to give you a "correct" pressure. It's a guide based on the relevant parameters and their experience. The variables you just listed are exactly those included in the calculator to give the user a more educated starting point, especially when moving to a different tyre or rim width.
⚠ Disclaimer - This pressure guide is a starting point recommendation and further refinements are encouraged to find the right pressure for any given setup.
#64
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
I'm running the 700x37 tires on my gravel bike at 40psi. 50+ was a bit too harsh for my taste.
Likes For Eric F:
#65
Bikes: Aurelia*Bianchi*Cannondale*Colnago*Dahon*Giant*Haro*Lynsky*Monkey Faction*Origin8*Panasonic*Paramont*Peugeot*Ross*Schwinn*SE*Specialized*Trek
Quoted: 58 Post(s)
Liked 26 Times
I was thinking of my car tires LMFAO! The highest PSI for a road bike is 130-160 ……….. there are no 200 PSI as of yet that I’m aware of on the market.
#66
Quoted: 4227 Post(s)
Liked 2,488 Times
Tire inflation is one of the most simple things about cycling, there is no need for any expert advice. Every tire I ever purchased already has minimum and maximum inflation pressures printed on the sidewall. Some of my pumps have a pressure gauge and some don't but I don't even look at it anymore, I just go by feel according to the terrain that I am riding in.
#67
Bikes: Trek Madone 5.2 SL 2007, Look KG386, R022 Re-framed Azzurri Primo, Felt Z5, Trek F7.3 FX
Quoted: 404 Post(s)
Liked 85 Times
Rock Hard
The roads are smooth here (often as smooth as a track) and I find that the higher the pressure the fewer (none in the past year) flats I get because glass gets pinged away as opposed to having the time to bed into a softer tyre, so I go to pressure on the side-wall which is 110 psi on the tyres I now use (Wiggle's Lifeline Road). I hate flats.
I used to go to about 140 PSI, which was limited by my ability to pump, in my TUFO tubulars because flats were even more of a pain (despite all the goo I tried). I did find that the palms of my hands did not like 140psi but I put extra, 100 yen shop shoe sole silicon padding (like this) in my gloves so even then, the high pressure was not a problem, except for the road resistance, so they say.
#68
Habitual User
Liked 8,100 Times
Likes For Eric F:
#69
Liked 4,873 Times
Do you just guess the tyre pressures on your car/motorbike as well, based on “feel”?
Likes For PeteHski:
#70
Liked 4,873 Times
#71
Liked 2,929 Times
#72
Liked 2,488 Times
Your bike vs car analogy is comparing apples to oranges....Underinflation or overinflation on a vehicle can be a serious safety risk and kill somebody if that tire blows off the rim while driving at a freeway at the high rate of speed and in case of underinflation you will get poor fuel economy....On a bicycle the worst that can happen with underinflation would be a pinch flat and higher rolling resistance..... Overinflating a bicycle tire to a point of it blowing off the rim would be difficult especially with a mini pump and only an idiot who lacks common sense would be able to do it, and you'll get a very uncomfortable ride which most normal people would not put up with.
#73
Liked 2,488 Times
How can you say that ?....when large majority of cyclists on this forum and out in the real world don't use any online calculators and never seem to have any serious issues related to tire pressure.
#74
Liked 4,873 Times
#75
Liked 2,488 Times
Likes For wolfchild:
