Light Bicycle Wheels
#1251
Quoted: 338 Post(s)
Liked 408 Times
My thoughts exactly - the recommendations are a bit on the low side, but it is good they cleared any confusion on the maximum pressures.
I run their R45 discs (brilliant wheelset, by the way) with 23mm GP5000 in front and 25mm in rear, latex tubes, and I use about 100 psi / 7 bar in both , give or take a bit, depending on the quality of the road and so on, at 72kg / 158 lbs.Their suggested pressure for a 23 seems unusually low; I've actually ridden it mine at 80 psi, and while it really is super comfortable and works better over really horrible roads, it's not something I'd run on a reasonable road.
#1253
MUP World Champ
I received my AR36 wheelset and got some 25mm GP5000 TLs mounted. The mounting was a fair challenge but I got it done. I hope the OS does its job as on the road repair is not likely. I have dynaplugs for backup. I am now wondering how much easier 28mm would be to work with but I'm thinking they would be a bit large for the AR36.
#1254
Bikes: 2014 Focus Mares AX 2.0, 2019 Cube Litening C:62 Race Disc Teamline
Quoted: 121 Post(s)
Liked 140 Times
#1255
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,532 Times
https://www.lightbicycle.com/newslet...th-Charts.html
Likes For Sy Reene:
#1256
MUP World Champ
have you seen this page at lightbicycle?
#1257
Quoted: 4717 Post(s)
Liked 1,882 Times
to be honest, I never struggle installing tires, but I still can say when one is harder than the other.
#1258
MUP World Champ
OK. I'll be watching for your report. I mount most tires fairly easily but the 5000s made me think a little. I'm not real comfortable riding on tires that I can't repair roadside. Hopefully I won't have to try it.
#1259
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
I recently started to carry the Lezyn plugs with me, haven't had to use them yet though
#1260
I originally mounted mine and seated the bead without sealant (before riding), when I noticed one was mounted backwards. When I dis- and re-mounted it a couple days later, it was much easier. I can only imagine that now that they have been on and inflated for a month+ through some temp cycles, that they would be manageable in the event a roadside repair was necessary.
#1261
MUP World Champ
It was a bit challenging to get brand new, fresh out of the box GP5000 TLs mounted, but they were noticeably easier to get over the hook in the rim after they had been on the rim, inflated for a bit.
#1262
Got an e-mail this morning from Koko at LB, following up on an inquiry from before I bought my AR56 wheelset, that the new AR55 Pro rims (in standard and flyweight) are beginning production now. Pricing for the rim only is $259 and $271 respectively. Not on the site yet, that I could find, but if anyone is interested, might be worth an e-mail. No specs were provided in terms of width (int/ext) or weight.
#1263
Liked 1,882 Times
Both tires inflated with a floor pump.
One of the Schwalbe tires had 3 tiny holes in the sidewall that prevented the tire from holding any pressure. We'll see what Merlin Cycles has to say about it. Luckily I always buy 3 tires at a time.
#1264
With the taller carbon rims, higher end spokes, and bigger/softer tires, you flat out don't need a lot of spokes. The higher end spoke alone will give you about 4x more durability and 2x the strength on a plain gauge stock spoke - https://dcrwheels.co.uk/custom-wheel...spokes-advice/ .
If you haven't ordered or they aren't in work yet, ask for the 'satin' finish after checkout. It looks nicer than the gloss or matte IMO.
Likes For jfranci3:
#1265
I did not know satin finish was a option, I went with matte as I didn't want the gloss. I may email them and ask if it's to late to change that.
#1266
MUP World Champ
I was able to mount a tubeless 28mm GP5000 without using a lever, but the owner of the wheelset needed to use a lever. The 28mm Schwalbe Pro 1 addix went on without using a lever.
#1267
I'm also not a gloss person, went matte, and then thought the matte was to dull/generic. Satin is a nice finish and not too showy.
Likes For noodle soup:
#1269
My experience
Thought I would update this thread with my experience. I am a large rider and wanted to get a set of carbon wheels that would handle my weight and riding. Nothing off the shelf seemed like it would work. Discovered Light Bicycle on this forum and read the entire thing. They were able to pretty do whatever I wanted in the way of spoke count and hubs. I had them build a set of wheels with the WR50 rims. They are 32/28 spoke count with Hope Hubs. The entire experience with Light Bicycle was positive. I asked many questions and they always got right back to me.
Order was placed on 7/21, shipped on 8/23 and I received wheels on the US east coast on 9/24. I knew from the start it would take this long as they had to source the hubs. Forgive picture sizes. Not sure how to resize.
Likes For Sasquatch16:
#1270
Liked 1,882 Times
#1272
Thanks. How many miles on your Domane? Here all the horror stories about BB90 after I bought bike. Yea the curves of the headtube make it not look so monstrous for a 62. My other bike looks much larger with all straight tubing.
In case anyone was interested 32c Continental GP5000 Tl's measure 34mm on these rims.
#1273
Liked 1,882 Times
I bought mine in 2018(it was a practically unused shop demo), and have over 30k miles on it. The bearings are due for a replacement, but still feel smooth, and theres no creaking.
#1274
FIXED GEAR
Bikes: 2019 tarmac pro disc 2020 allez sprint track
Quoted: 14 Post(s)
Liked 36 Times
So I ordered ar56 28h rims, then I had wheelbuilder in Azusa ca build them for me.
so far been very impressed with them. Would definitely use LB again should the need arise.
ar56 28h
philwood track hubs high flange single fixed
sapim cx ray spokes and brass nipples
gp5000 tubeless setup
yes they were a son of a ***** to mount
thank you BF and WW for the extensive knowledge about these rims its what helped me pull the trigger.
#1275
Advocatus Diaboli
Liked 1,532 Times
ar56 28h
