Undersizing
Undersizing
I'm six foot but I ride a 56cm frame. Recently I've been thinking about 54cm frames.
Reason is because I feel like I have a short upper body and a long lower body, thus my torso length is more in line with a shorter person and my height is a result of my leg length. When I rode a 58cm frame I always felt like I was reaching too far to get to the handlebars. 56cm does feel a lot better.
Anyways, is it common for the recommendations to be off due to different body types?
Ramzilla & his older brother are both 6'-1" tall. But, Ramzilla has a 30" inseam and Brother has a 34" inseam. Ramzilla likes 56cm bikes with long reach handlebars & stems. Brother goes for 60cm frames with normal reach handlebars. Brother can easily outrun Ramzilla. Ramzilla can easily crush brother. Be good. Have fun.
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,823 Times
6'1" 58cm - 62.
58X57 is (generally) about as small as i'm comfortable - especially at speed
62cm = soooo nice in the drops
Likes For Wildwood:
Quoted: 1743 Post(s)
Liked 1,279 Times
5'9" + or - with 84.5 cm inseam. Frame size range = 54 - 56 although I can ride up to a 58. What is know as a "square" 55 is perfection. (FWIW age 72 in that pic)
You are looking at this the wrong way. These days, frame size numbers are meaningless. Look at stack and reach. I have long legs and a short torso and I do ride a small frame that has a stack height of 527mm, with a 15mm headset bearing top, no spacers and a -17 (horizontal) stem. I can do this because I can tolerate a large 10cm saddle to bar drop. My saddle height is 73cm. If you can't tolerate a large saddle to bar drop, a frame with a shorter stack makes no sense.
If I could only tolerate an 8cm drop, a -6 degree stem would be an easy fix. If I needed a 6cm drop, 20mm of spacer would be needed and some might say I bought a frame that was too small.
Reach can be minimized with 75-80mm reach bars or increased with bars having up to 100mm. Stem length changes can further increase reach over a large range,
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Watch out for too much toe overlap (toe hitting front wheel when turning at low speed) on smaller frame! Especially with wide tires.
Quoted: 645 Post(s)
Liked 797 Times
you don’t want to mess with seat position to fix reach issues. Seat position wrt BB, crank length, cleat position are a set of parameters that are collectively governed by leg length, regardless of torso length/flexibility or arm length, which govern reach. Get the optimal seat position, then leave it alone while you use TT length, bar reach and stem length/angle to optimize reach
Likes For Litespud:
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
As mentioned above, without knowing some other details it is not possible to know what is a suitable frame size. On a traditional level top tube road bike, 54cm would be absurdly small for someone 6' tall. On a sloping top tube bike (Many modern road bikes and most gravel bikes), 54 might be a M/L size in some brands.
Without knowing what bike you are talking about, there is no way to correctly answer the question.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
It's probably worth noting that a lot of pros ride what look like pretty small frames, with great success. World champion Peter Sagan is 6 feet tall also, and his frame can't be much bigger than 54-55 cm. You can't argue with the success he's had.
There are advantages of having a smaller frame underneath you, I think it's referred to as "flick-ability". Good for climbing and sprinting, where you are throwing the bike around a lot. Lighter too, but that's not the main reason.
There's no trick to making a too-small frame fit, just get longer stems and seat posts. I like my frames on the larger side of the range I can ride, but there are lots of advantage of going small, and no reason someone that wants to can't make it work for them.
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
If you feel too stretched out and your saddle is in the right position, first look into a shorter stem. Otherwise if you want to new bike look for one with a shorter reach.
As mentioned earlier in this thread, look at the actual frame stack and reach numbers of the bikes, not the stated frame size in cm.
I'm 6'0" and use a 54cm frame with a normal 100mm stem. I like to sit way back on my saddle, so I like a short reach, or I feel really stretched out. I feel like superman on a 56. The ridiculous looking saddle to handle drop is offset by the shorter reach allowing the arms to be more underneath the chest, propping the body upward into a less aero race position (more comfortable). Sitting back activates the glute muscles and takes pressure off the hands.
WALSTIB
You've got some sweet rides. By your bike list looks like no room for a car in a 2 car garage
Quoted: 18397 Post(s)
Liked 15,486 Times
Go custom or go home.
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
I test rode my CAAD10 in 56 and 54cm sizes. I would normally ride a 55ish. What actually sold me on the 54 was that my thighs were rubbing on the top-tube of the 56.
My steel bikes have more conventional top tube diameters, so I don't have that issue on 55cm sizes.
Liked 1,279 Times
Quoted: 344 Post(s)
Liked 297 Times
You can presumably get down below 6.8 kgs with any modern pro-level carbon frameset currently on the market, even in the 60cm size and up. I think it's much more likely that aerodynamics, position on the bike, and handlnig play a much bigger role in the decision.
Veteran, Pacifist
Liked 4,823 Times
For the riding I do this is a good group, no wallhangers. Most others would want a more diverse collection.
Veteran, Pacifist
Liked 4,823 Times
The picture of Sagan just shows that he has legs that are average for his height. The saddle to bar drop looks normal for a pro rider. There is no large amount of post showing.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Get a "fit" and pick a frame that works.
I did and the Trek Madone (2011) have the best fit compared to a Specialized or Cannondale.
I'm 5'11" and ride a 56cm.
