Tubeless or Clincher
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
As mentioned, just depends on your needs. GP5000s and latex tubes are working great for me, zero flats for the last 10,000+ miles. But if I lived somewhere with goatheads or similar hazards, then I'd prob want tubeless.
Quoted: 3952 Post(s)
Liked 7,298 Times
A big tailwind isn't necessary. A 1 mph tailwind instead of a 1 mph headwind would be enough to get you from 49 mph to 51 mph.
Quoted: 20810 Post(s)
Liked 9,456 Times
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
Getting two punctures immediately after one another is not as unlikely as you think. It depends what you run, where you ride, and what is on the ground. A bike with tubes and perhaps a tyre liner is also very unlikely to get two punctures immediately after one another. It is usually because something is still in the tyre, causing the second puncture. Or you have a frigged up rim tape situation.
I have had two punctures after another both on a motorcycle and in a car - both tubeless. Both caused by debris. Not fun, but that doesn't mean it is because they were tubeless and that I have now switched to tubed tyres on cars or motorcycles. I have also had a complete loss of air on a tubeless tyre all of a sudden - the tyre had a manufacturing defect. Should those things mean I should switch to tubed tyres?
Quoted: 6194 Post(s)
Liked 4,810 Times
Hmmm, one flat and done. More to consider. With clinchers I can count on flats coming in three's. One right after the other in quick succession, then none for several years. There was another thread on tubular where the op had only flatted twice in quick succession. https://www.bikeforums.net/road-cycl...e-what-do.html
This is making tubeless more and more a plus if the superstition of bad stuff happening in threes doesn't apply to them.
As for two punctures or more..... who cares if the sealant does what it's supposed to do for the tire. Which is not flat when punctured.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12774 Post(s)
Liked 7,692 Times
Likes For LesterOfPuppets:
Liked 9,456 Times
Quoted: 356 Post(s)
Liked 323 Times
Motorcycles and cars? I'm going to assume that you've got no relevant experience to share and move along, but suffice it to say that consecutive flats - as opposed to punctures - with properly set up and maintained road tubeless tires would be exceptionally rare, much more so than with a tubed set-up.
Liked 9,456 Times
Quoted: 356 Post(s)
Liked 323 Times
Sure. You don't understand even simple concepts or analogies such as "throwing out the baby with the bath water". I guess getting two flats and use that as reason to abandon tubed (or tubeless) tyres entirely is not over the top in your world. I knew there was a reason I had put you on ignore. You truly are a gem.
Liked 9,456 Times
Quoted: 356 Post(s)
Liked 323 Times
The only thing that "smacks of ignorance" are your constant attempts to start a fight based on your own ignorance. Two words: Dunning. Kruger.
Quoted: 643 Post(s)
Liked 1,526 Times
If you had tubeless and were happy, why not get tubeless carbon wheels and run tubeless GP5000's? They are great tires.
Liked 7,298 Times
Even if tubeless tires are immune to the "Law of Threes", they would still be subject to Murphy's Law which, in this case, would be "Anything immune to the Law of Threes will suffer from the "Corollary of Quatro."
Likes For tomato coupe:
Liked 9,456 Times
Now I remember you - you're they guy that kept harping on the shortcomings of the Varia when it was plain that you'd never touched one. Now you're harping about the shortcomings of something else with which you clearly have no practical experience! Given that, it's hilariously meta that you're calling others ignorant and invoking the Dunning-Kruger effect. Kudos!
edited to add: since you have nothing of substance to add, I'll take my leave, now. Ta ta.
Quoted: 356 Post(s)
Liked 323 Times
Haha, you're still trying hard to show just how little you are able to grasp. Well done, you. I will see you the next time you try to start a fight by finding something you can attach your ignorance to, believing you're somehow making some profound point.
Quoted: 338 Post(s)
Liked 408 Times
GP5000s with latex tubes work really really well for me and puncture extremely rarely. That said, after installing tubeless Vittoria Corsa Speeds on my wife's TT bike which was surprisingly easy, I'm tempted to make the switch when my stack of GP5000s get worn down if no problems crop up with those.
The biggest reason I'm considering switching is that it is bloody hard to mount GP5000s on my rims and often when replacing the tube it gets pinched despite my best efforts.
Personally I always rode clinchers with tubes. If you invest in a good tubed clincher, I dont really see the point of tubeless with the sealant and headache of changing them. Now on the other hand, the mountain bike i purchased came with True Tubeless wheels and tires, and they ride great. Although I have not had to change them yet, soooo, Im dreading doing that. But the giant tires on this bikes makes me think I wont be changing for a long long time. Bottom line, I think if your rims come tubeless, go for it.
I have returned to straight clinchers after 3 years and have no intentions of returning tubeless since I can again change a tire in 10 minutes along side of the road and go again rather than messing about for an hour and ending up with goo all over me.
As for the Continental GP5000TL's, they have marvelous traction, so good that your bike will wander around the road with changes in road traction. They corner like nothing else I've used. But they are expensive and they wear out rapidly because of that great traction. If you are racing by all means use them, but unless you have a well paying job I would avoid them. Continental 4 Seasons is a good training tire, they are more flat resistant than the Gatorskin and they wear very well. But they too cost an utter fortune. I have been using Vittoria Corsa G+ or 2.0 clinchers and am happy with the wear and directional stability. But I am sort of a special case. I have had a severe concussion and have no sense of balance so I have to rely on the bike to balance itself. Directional stability is a large plus for me.
Yes, but I've ridden the same descent with a big tail wind and that's how I got to 49. We can always depend on your nitpicking.
Quoted: 356 Post(s)
Liked 323 Times
Liked 7,298 Times
At those speeds, rolling resistance is a small fraction of aerodynamic drag. Tubeless tires, even if they had zero rolling resistance, aren't going to give you a bigger benefit than a strong tailwind.
