What tire width will yield least rolling resistance on a tandem road bike?
Quoted: 30 Post(s)
Liked 12 Times
Currently I have 27 x 1.25 tires. I may want to go wider if they will fit and if they will be faster. Also what brand of tire do you like. Thanks
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
A tire that is too big to fit into your current bike is always the solution. This leads you to become dissatisfied with what you were perfectly happy with up until the moment you read advertising about large tires. As intended, this soon becomes a compulsion to buy a new “gravel”, or “all-road” bike, not just new tires.
That’s pretty much it unless you are being paid to race. No tire, or any piece or equipment, will attenuate the effects of age and corpulence.
Likes For conspiratemus1:
We used 27 x 1 & 3/8” tires on our 1st Gen Duet (like yours) in the early 90’s and I remember having plenty of clearance. Choices in 27” tires are pretty limited these days, so that may dictate what you buy as much as anything else.
Quoted: 13 Post(s)
Rolling resistence
Read Jan Heine's blogs at Rene Herse, subscribe to Bicycle Quarterly, or read his recent All-road bike revolution book. He has LOTS of information on this based on testing.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
If the goal is to go fast, you have to factor in aerodynamics along with rolling resistance.
Most aero wheels these days are optimized for 25mm tires. Admittedly there’s not a lot of tandem specific data. That said, my bet is the fastest overall option is a 25-28 mm tire on a rim optimized for that size tire.
Depending on your rims and how fast you ride, I think going wider than 1 1/4”, (32mm) is very unlikely to make you faster.
You could get lost and die.
You could hit a tree and die.
Quoted: 2495 Post(s)
Liked 738 Times
Exactamente. When I bought a C&V road racer (pristine Raleigh Team USA) from 1984 it was your typical 27" x 1-1/4" clincher deal. When I was looking for something sportier (27 x 1-1/8) about all there was was Continental and Kenda. The Kenda's were something like 22TPI and so I went for the Continentals. I had to boot the front tire on the first ride I took on them. I had never booted a tire in 45 years of riding bikes. I had to boot the rear tire a couple of rides later. I GAVE the bike away this year because it was a Garage Queen that I never got around to converting to 700C. Rather than worry about what 27" tire has the lowest rolling resistance (they are all awful) I'd be thinking hard about a 700C conversion. In 27" there are only three sizes that survive into the 21st Century and none of them are made with the kind of quality or technologies that lead to a low rolling resistance.
https://www.cycleschinook.com/tire-optimizer/
Once you've got the size, you'll want a supple, high quality tire like Rene Herse tires, Panaracer Gravelking (slick), Continental GP5000, Schwalbe E-One, or Schwalbe G-One Speed.
Quoted: 30 Post(s)
Liked 12 Times
This tire optimizer will tell you the fastest size for your weight and terrain.
what a great tool! Thanks
pan y agua
Liked 727 Times
That calculator says we should use 33 mm wide tires for road riding.
We’ve raced our tandem a fair amount, including state and national championships. We use 23mm wide tires to Time Trial because the Zipp wheels we have are optimized aerodynamically for 23 mm tires ( some new aero rims would work with 25mm) and otherwise run 25 mm. I’ve never seen anyone TT with wider than 28 mm tires, and most are on 23-25mm.
The aerodynamic disadvantage of 33mm wide tires would overwhelm any theoretical rolling resistance advantage at anything approaching racing speed.
Liked 738 Times
Post #12 beat me to it. Darn this 3 hour time difference. I see that calculator as a sales gimmick. Nothing more. In any case, I don't see any mention of 27" tires. Or much mention of 26" tires. Like it or not, a lot of teams are rolling on 26" wheels/tires. IMO, unless you are actually racing, the 'fastest' tire is the one you don't have to stop and fix flats for! We have 700C x 28mm Schwalbe Marathons on our drop bar conversion Raleigh Coupe. This is a thoroughly modern (2005) road bike with disc brakes and all the rest of it. We find ourselves coasting in sections where all the teams around us are pumping to keep speed so I don't think we give much away in rolling resistance.
For a team that never leaves pavement, a tire wider than 28mm is unnecessary for performance reasons. We 'might' consider 32mm this year for some additional comfort and I doubt we will take much of a speed hit. Wider tires than 32mm simply will not fit under fenders and fenders are a must have in Portland, OR. The Domane's and Diverge's have full fenders here. My road racer came with 23's, it might take 25's but I have fenders on it so 23's it has to be. A lot more goes into speed than tire size. We keep the Marathons at 100psi. We have another tandem with 26" x 2" x 50psi for daily urban commuting, shopping and errands. We can hit 25mph to catch a stale green, if we want, on these "comfort tires".
In my experience the optimum rolling resistance with a schwalbe marathon comes with a 37-622 tyre, It rises once u go to 40-622. Pressure is 5 to 6bars.
But if u lower the pressure for more comfort the larger diameter the tyre has the less rolling resistance.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Why are the OP and most posters measuring tire sizes in inches? What rims is this tandem running? What make and year of tandem? Because if this is an old tandem running hookless rims, then the answer will be totally different. There are no modern 27" wheels, only 700c or 622mm, and thus no modern tires.
If they're 700c, then the answer is certainly Conti 5000 32mm tires. If they're 27" than, as above, change the rims out to modern hooked rims, and run the Contis. Check with your bike shop to be sure that your brakes can be adjusted to suit the new rims. We've been running Conti tires in 32mm size, both 4000Iis and 5000 and like them very much. Quite flat-resistant which may be a bit counter-intuitive, but they are. I think it's the rubber compound more than anything.
Results matter
Results matter
Bikes: Comotion Primera
Quoted: 5 Post(s)
Rim Width Study - Bicycle Rolling Resistance
Just Released
Real rolling resistance data on different rim and tire widths, different pressures has just been posted on the Bicycle Rolling Resistance website. Well done!
Bikes: N+1
Quoted: 229 Post(s)
Liked 652 Times
Although there are few 27" tire options, the tried and true Panaracer Pasela is available in 27 x 1/18 and 1 1/4 and is a pretty good tire with fairly low rolling resistance. Swift tire markets essentially the same tire made by Panaracer in 27 x 1/3/8. If the OP has an older tandem those are perfectly decent tires.
Bikes: N+1
Quoted: 229 Post(s)
Liked 652 Times
I wouldn’t put much stock in that calculator. There’s nowhere on the site that explains the methodology of the calculator. And I’m pretty sure it doesn’t consider aerodynamics.
The OP did ask about faster tires, but also said they're on a tandem with 27" wheels, so are likely not racing, and certainly do not have Zipp carbon wheels. Context is pretty important. A fairly light team racing or training on smooth roads might find 23-35c tires to be well suited to them and their intended purpose. A large team on poor roads would be ill-advised to go that narrow -- if they are touring such narrow tires would be a disaster. I have no idea where the OP falls in the range of size and use, but "fast" is only fast if you're not denting rims and flatting a lot, so that's why I say context matters.
pan y agua
Liked 727 Times
My point, which I used our personal example to illustrate, is that the calculator is way over simplistic and appears to ignore aerodynamics. I stand by my assertion that that particular calculator is over simplistic to the point of about being useless, and appears to basically be a marketing tool for that site.
I would take its results with a very big grain of salt. And as you suggest, make my tire choice on what’s best for my team’s wheels, intended use, weight, and budget, not what that calculator says.
