cold fingers & toes
Quoted: 80 Post(s)
Liked 39 Times
cold fingers & toes
We ride a tandem every morning, except when it is raining or below freezing. We live in a moderate climate, so it is rarely below freezing. This morning, it was 33 degrees and windy. We wore silk long johns upper and lower with a lot of layers on top, a gaiter on our necks, and a knit cap over our heads and ears. That worked fine. The only things that really got uncomfortably cold were our finger tips and toe. We wore silk glove liners with heavier gloves on top. We wore silk socks with heavier socks on top. Our shoes are black sneakers (don't show chain grease or dirt). What do others do to keep their finger tips and toes warm on cold mornings? Thanks.
Quoted: 1074 Post(s)
Liked 295 Times
Bar Mitts/Pogies are great for keeping hands warm.
Feet, I use electrically heated insoles. I’ve got reduced circulation, and there isn’t a boot in existence that will keep my toes warm unassisted.
+1000 on Lobster gloves. I have never found warmer gloves for riding. Get ones with liners.
For the feet, I can't say enough good things about Gator tip toe neoprene toe covers. https://www.aerotechdesigns.com/netiptoeco.html
These are thin and go over your socks before you put your shoes on. You will easily get 10 to 20 degrees colder comfort range before you would want to go further with insulated boots or booties. Seriously, these things are amazing.
You can also put those air activated stick on foot warmer pads on top of your foot right under the gator and you will be fine. It's amazing how adding a little heat at your extremities will keep them warm.
Quoted: 680 Post(s)
Liked 948 Times
Quoted: 12 Post(s)
Bar Mitts for the hands. I used to commute into the low 20's with Bar Mitts and lighter gloves and my fingers were fine. I used Neoprene shoe covers and wool socks to keep my feet warm.
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
Avoid any shoe covers that are tight though! Similar to wearing two pairs of socks, they defeat (defeet!) the goal of warmer feet by restricting blood flow and making your feet cold! I ride with thin Gore-Tex shoe covers and I'm simply amazed had how warm my feet stay over my old, thin nominal leather road shoes. They completely eliminate the wind from cooling the feet off. Most shoes are designed with ventilation in mind, which is good under most preferred cycling conditions. But when the weather turns really cold, that ventilation proves to be a major problem. Even the thinnest booties can eliminate much of the problem. That's my experience anyway.
And gloves? I never found full finger gloves to be much of an improvement. Individual fingers simply get cold in the wind. What I've found works really well are, again, thin Gore-Tex glove mitten covers. They're simply waterproof covers to go over any glove. They're designed for skiing but work for anything. I put them over long or short finger cycling gloves and my hands are perfectly happy! However, one caveat is that the design restricts individual finger dexterity and control. Some riders my find these gloves a no-go for cycling, so YMMV.
And to conclude, I have to add that I'm not cycling in sub-zero or even freezing temps, so take that into consideration as well.
