Totally Tubular
#1876
Quoted: 1947 Post(s)
Liked 2,010 Times
Vittoria's site doesn't show them. Maybe someone found a misplaced container?
#1878
Liked 2,010 Times
#1879
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,831 Times
#1881
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
5-10% less than the recommended 110 psi? It would certainly make a difference on the chipseal.
#1884
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
what width of tire? how heavy are you? how heavily do you ride (do you break components)? how hard do you corner?
myself as an example:
I ride 28s. I run about 70psi, but I can drop it down to 65psi. I'm a lightweight rider at only 140lbs. I raised the pressure just a touch because my steering went vague on a hard corner.
Somewhere, a village is missing its idiot.
#1885
smelling the roses
Liked 901 Times
#1886
Some Weirdo
Quoted: 223 Post(s)
Liked 141 Times
With tubulars, 90-95psi. Why did you decide on narrow tires? 25s or 28s would help immensely.
#1887
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
Yeah, narrow tires on lightweight rims were a racer thing from the 80's and before; that's why Brits call them "sprints". The magical ride quality we talk about in this thread comes from lower pressure and more volume.
#1888
smelling the roses
Liked 901 Times
I bought them from Yellow Jersey. Cheap. I didn't want to go all in in case I didn't like it. My spare is a Challenge Elite and is wider. My thought was to start out conservative and proceed into better tires after learning the ropes some.
Now I know what to look for down the road.
Likes For seedsbelize:
#1889
smelling the roses
Liked 901 Times
Tubulars is something I never thought I would do. Touring either. In the last couple years I've done both, because why not? I never thought I would do Campagnolo, but have Record hubs on these wheels. And Campy pedals. Considering going full Campy on one bike. Time passes and things change. We live and we learn.
#1890
smelling the roses
Liked 901 Times
What are some modern tubular rims? Mine are Mavic Monthlery. The easiest wheels I've ever built.
#1891
Bikes: many
Quoted: 1444 Post(s)
Liked 1,390 Times
In addition to personal preference and availability, I will add... I haven't started working on it yet, but the Univega Super Speciale frame I just got has pretty short chainstays, maybe 16.25" (I'll have to double check). I think most of my other bikes have somewhat longer stays, maybe 16.75"? I suspect that might limit tire size.
#1892
Liked 2,010 Times
5-10% less than same size clinchers. For example: 90psi in my 25mm Sprinter Gatorskins vs. 100 in my 25mm Gatorskins.
#1893
Liked 2,010 Times
Likes For Classtime:
#1895
smelling the roses
Liked 901 Times
Having terrible google fu, I'll ask here. Were I to swap my spare into a rider and a rider into a spare, would I want to add glue to the spare before mounting? It has two coats currently..I assume I'd need to glue the rim and the spare. Please advise. Thanks
#1896
Liked 2,010 Times
If you recently put those two coats on, I'd say no. Maybe a thin coat on the rim if some of the glue came up with the tire you removed. When I have flatted soon after mounting a new tire, it is very difficult to remove my spare when I get around to patching and putting the rider back on.
#1897
It's MY mountain
Liked 2,980 Times
No, do not even bring glue on your rides. Your spare should have a coat of glue on it - typically from previous use. And you should get it on straight and pump it up to high pressure to hold it on - and just to be sure, you should minimize braking on that wheel and take the turns gingerly until you can replace it properly... but you'll probably be surprised at how hard it is to get off when you do.
Likes For DiabloScott:
#1898
smelling the roses
Liked 901 Times
#1900
Quoted: 2337 Post(s)
Liked 2,821 Times
sshhhhhhssssh...... this is the big secret: they really are not that hard and from what I read in the mechanics section a ton less difficult than tubeless (i have no tubeless hands on experience) need to keep the mystique of tubies to the cognoscenti
Likes For squirtdad:
