Grease for Silca Pista Leather Cup
Bikes: Rockhopper, Azor Oma cruiser
What's the recommended grease for the leather cup to the Silca Pista? Someone mentioned Proofhide, another recommends silicone grease, and another recommends white grease which I assume is Lubriplate.
Like the old Brylcream commercial said: "Just a dab will do ya."
-Bandera
Likes For Bandera:
Quoted: 5787 Post(s)
Liked 2,579 Times
Don't use proofhide. It's designed to penetrate and soften leather, and can lead to the breakdown of the piston.
You don't need anything special, and aren't trying to grease or soften the leather, just provide some lubrication where the leather slides against the cylinder. If you want a specific product, buy waterpump grease (sold in rural areas) which is impervious to water and won't hurt leather or rubber. But you don't need to do that. I add one drop (no more) of olive oil (it's an Italian pump) and pump and spin the piston to spread it around the cylinder wall. That's good for a few years.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 263 Post(s)
Liked 9 Times
Technically the silicone grease would be best. Petroleum based greases break down the leather over time. Even neatsfoot oil damages the leather even though it is the traditional treatment.
But I don't really think it matters. People have been pouring oil in the top of pumps for hundreds of years.
Quoted: 7348 Post(s)
Liked 2,470 Times
@FBinNY once again comes in with advice that's both on-the-money and funny.
I've used leather boot grease .. pump still works, 30 years On.
Ditto the Medai .. for s/v tubes
Quoted: 443 Post(s)
Liked 27 Times
I've been squirting engine oil in my Medai Top Super pump and my Coleman lantern for about forty years.
Pump oil (Jobst Brandt)
Liked 2,470 Times
You don't need anything special, and aren't trying to grease or soften the leather, just provide some lubrication where the leather slides against the cylinder.... I add one drop (no more) of olive oil (it's an Italian pump) and pump and spin the piston to spread it around the cylinder wall. That's good for a few years.
But I spread some regular olive oil from Wallys onto the leather washer for the first time ever since I've first purchased it in 2004. The washer wasn't dried out to begin with but I'll bet with the new application of oil, it'll provide a tad better seal.
I cleaned the old oil and grease out (nearly all of it) of my mid 80's Silca Floor pump leather cup using ajax dish soap with toothbrush. So now that its pretty dry and suede like agian, what would be a good conditioner that will not weaken the leather? MIneral oil? 3 in one oil? Or just use vaseline? I have idea leaving it dry and just lubing outside rim would leave it prone to tearing apart when in use?
Likes For RGMN:
Quoted: 4205 Post(s)
Liked 3,863 Times
This is much like the "what chain lube is best" threads that we all dread. That some sort of oil like substance is used and the washer is revisited periodically will be so much better then the majority of pump washers lives. I use whatever grease/oil is handy, often Park or Phil as they live on my bench. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
I've read somewhere not to use any petroleum based lubes in/on pumps. I bought my Silca floor pump in the early 80s. I've used it at least once a week. I use Neatsfoot oil on the cup and I don't ever remember replacing it. I know I had to clean out the check valve once.
Liked 3,863 Times
AndrewRStewart
AndrewRStewart
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
check Valve? Wheres that located. I to have a Silca from the 80s. Thanks KB
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
The piston , being the leather cup ?? Or down in the tube, I'm trying to visualise. I'll take a look. Than you for the help. KB
Edit:I see a large nut, on the brass fitting, that the pressure gauge is attached, I'm I getting close ? KB
Liked 3,863 Times
At the base of the cylinder. Between the interior and the hose connection. Without a functioning check valve and when attaching to a SV the air in the tube would try to push the pump piston/handle up, no added pressured air would stay in the tube. Andy
AndrewRStewart
AndrewRStewart
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
Thanks Andy, now I see it. I remove the brass fitting that the hose is attached, Now, what or how do I clean it ? Thanks. KB
Liked 3,863 Times
If the check valve is clean then Bob's your uncle. If dirty with grime clean off with grime cutter (solvent?) If rusty try removing the rust, fine steel wool perhaps. Some will have a ball "bearing" on a spring and this spring can break or otherwise become non functioning. Some can be a molded bit of plastic and the back pressure of the tire closes it against it's seat.
Is there a problem with your pump? Or are you trying to just understand it? Andy
AndrewRStewart
AndrewRStewart
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
So, should I just leave it alone ? Than You. KB
Liked 3,863 Times
As others say "don't fix a running bike". I say leave the check valve alone if there's no problem. Andy
AndrewRStewart
AndrewRStewart
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
