Mystery bike with cracked head tube
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
I noticed this for sale locally and, while some of the parts seem nice, I couldn't get past the cracked head tube.
Now, looking a bit closer, I'm curious about the bike manufacturer. Specifically, the drilled out head lugs is probably a give away to the well-informed, but I don't recognize it.
It looks relatively upscale with the lack of braze-ons and sloped fork crown, chrome socks, etc. The rear dropout appears stamped, so I'd not call this a top tier frame.
The seat-stay wrap around the seat lug screams English builder to me, but doesn't quite look like Falcon to me. Maybe something from Nishiki?
I haven't bothered to contact seller and don't really have any plans to, so all the info is what I can glean from the ad photos (link). I've cropped and enlarged the frame details from those pics.
Any thoughts?
Any thoughts?
Quoted: 970 Post(s)
Liked 1,632 Times
I would think its value is only in its components. The frame is worth nothing till fixed.
Likes For zandoval:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
That'll buff out.
Likes For gugie:
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
I'd get it for the parts if it was cheap. Big fan of stems like that. Nice 26mm ones are kinda rare and a big fit improvement for many people/bikes. Preferable to a technomic imo.
Likes For Soody:
Quoted: 3814 Post(s)
Liked 3,345 Times
dropouts are Campag 1060 so that rules out Nishiki
agree that combination of crown and seat stay treatment suggests Britain
this can sometimes also indicate another anglophone land
domed stay ends are also suggestive of Britain
chainstay stop detail may help one of our detectives
Bob Jackson is one of several Brit marques who made fairly extensive use of these frame ends
they are also the proprietors of the JRJ and Merlin (steel) marques
lug pattern is a longpoint version of the Prugnat 62/d, the lower head lug may be a 62/d which has been lengthened
date appears clearly mid to late sixties
unfortunately we have no view of shell
MauriceMoss is sure to see much more upon the occasion of his next drop-in
Likes For juvela:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
With that countersunk pattern in the lugs and the location of the crack, what about the possibility of it being a novice framebuilder's custom frame? It would explain the crack; they may have cooked the top headlug in the process.
It's obvious there was some tension in the frame seeing as the top of the tube pulled back too. Perhaps the mitering was slightly off and the builder forced the HT into position and brazed it in under tension?
-Kurt
-Kurt
Likes For cudak888:
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
When I see a ruined frame, I just value at the two best parts on the bike. So if it is priced at that level or below, I'm in. Higher than that, I let someone else buy it. I already have enough parts.
Likes For wrk101:
Quoted: 3241 Post(s)
Liked 2,512 Times
Could be a stuck stem gone bad. Heat applied to the head tube and the stem wouldn't budge. Look at the black crud on both headset ends. Might be burned grease/lube. That's a shame.
Liked 2,512 Times
Cant make out the word on the front brake caliper. SRAX, STAX, SPAX? There is a brake caliper listed on Velobase as Astra.
Liked 3,345 Times
interesting idea there!
another possible cause for the presence of the black crud could be that the assembler lubricated the head cups when pressing them it and this is just a bit of grease which has collected dirt in the time since the assembly.
[have no horse in the race]
Liked 5,803 Times
It's possible some idjit tried this, but highly doubtful compared to other explanations.
Likes For gugie:
Quoted: 878 Post(s)
Liked 2,296 Times
I'm a parts guy with a build usually in process so I look for deals on stuff like this . If reasonable, I would consider it for parts .
Likes For Kabuki12:
Quoted: 4722 Post(s)
Liked 3,039 Times
Likes For T-Mar:
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
FD looks to be Campy NR? Not sure about the shifters.
Regardless, I wasn't trying to ID based on the parts since who knows what's original (if anything).
Thanks for the comments so far, but it looks like we're still far from an identity. No matter, as it's just an idle exercise of curiosity for me.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
There were a couple West Coast custom builders who used the drilling of holes in similar fashion to these headlugs ( I recall that early Bruce Gordons sometimes had them, see a couple examples below) but nothing else here looks like it's of the same high-zoot quality as BG's work or someone "in that league".
I suspect it's the work of an amateur who mimicked BG's style but also probably over-heated the head tube....too bad!
Likes For unworthy1:
Liked 2,512 Times
What about the rear chainstay shifter cable guides? Is that a ferrel and a hump it sits on or something brazed on as a cable stop?
Edit: It appears to be a loop, a ferrel and some kind of stop the ferrel fits in.
Bianchi Goddess
Quoted: 2938 Post(s)
Liked 2,934 Times
I never really understood the Technomic stem. I have several of these and while they can be a PIA to get on the bars they give me a very comfy riding position
Sugar "Kane" Kowalczyk
Liked 3,345 Times
frame will exhibit one other braze-on: a no-slide pibb on the downtube
Likes For juvela:
Liked 3,345 Times
Likes For juvela:
Liked 5,803 Times
Frame could be fixed. Honestly!
@scarlson might want to chime in, but hack out the head tube, file it nicely and fillet braze in a new one, it’d be a bilaminate construction.
Not worth paying someone to do it, but it could be done.
Likes For gugie:
Liked 4,396 Times
-Kurt
Quoted: 964 Post(s)
Liked 1,451 Times
I don't know if we can say that for sure. The bike was likely ridden with the crack, and I'm assuming the headset was adjusted right for the headtube before it broke. The fork would want to move front to back and side to side during riding. The two halves of the head tube would be getting wedged all over as the balls try to climb out of their races in response to bike and rider's weight, brakes, bumps, etc. In my view we are lucky they are still as aligned as they appear to be.
