Noisy fixie drivetrain
Hello, I'm a complete newbie to single speed and fixed gear bikes. I recently got a fixie with a flip-flop hub and have been riding single speed with the freewheel for the past couple weeks. Today I flipped it around to fixed for the first time and it's quite noisy. The freewheel side was a perfectly quiet, smooth ride. I don't know if this is normal for fixed gears but it's pretty annoying because it sounds like there's something wrong. I tried different chain tensions but there was no difference. To my untrained eye, the chainline appears to be straight, but maybe slightly off. What else could be causing this? I also have two videos:
Quoted: 336 Post(s)
Liked 309 Times
I would check the rear hub bearings, cones, and races. I don’t think that there is anything wrong with chainline, chain, or gears.
Also check that there are no loose spokes.
Quoted: 99 Post(s)
Liked 115 Times
If it doesn't make that noise in single speed, but does in fixed, then it's something at the back end. So that means not the chainring, and the chain alone is not the issue.
It's not the chain line, and the chain looks well lubricated.
I wonder, is your chain the right width for your fixed cog? If it is a size too narrow (say 3/16 instead of 1/4) that may be the issue.
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 404 Times
I'm with Mikefule. I think the chain is not seating properly with the teeth of the fixed cog. It's (chain) probably been mated to the freewheel over the miles.
How old is the bike?
Likes For Speedway2:
Ups!
Fixed Gear is a completely noise-free operation. You can only hear one breath and a heartbeat.
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
Liked 137 Times
https://youtu.be/ZT4F6wD_IOs
https://youtu.be/v_Gdd_AzQJ8
Ups!
Rinse in a closed polyethylene bottle with gasoline or kerosene twice, dry. Lubricate with bike chain silicone lubricant. Clear the stars.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Also, go ahead and measure your chainline. You might need to mount the chainring on the inside of the spider arms.
Bikes: 3.5
Liked 13 Times
I'm with Rolla here.
Is it possible that you just put a new chain on a cog/ring you've been riding already? The chain will need to wear in to fit the worn (even if only a little bit) teeth. In bikes with gears, you generally change your cassette when you change your chain so everything wears evenly. That way your chain isn't wearing out your cassette, or your cassette isn't wearing out your chain.
Best of luck
Best of luck
Ups!
Make sure everything is clean first. And only then carefully measure and examine the wear of all components. As an option: throw all this household into the trash and buy a new one.
Guest
Liked 3,270 Times
Thanks - I re-read your post and deleted mine just before you posted this.
Yeah, I don't know if it has anything to do with the square aspect, but something's up with the chain/cog/chainring interface.
Likes For Rolla:
I believe it is a new chain being used with a worn cog. I did this once and the noise was incredible! It was worse when under power. I only rode a couple hundred yards and turned around to put the old chain back on. Install a new rear cog and you should be quiet.
Sources of sound can be many many thing.
-Your pedals bearing loose, its crazy but its true for me, try remove pedals and spin it, for me its gone. So I end up buy quality pedals to replace it.
-Too tight chain
-New chain (most new chain need some sitting before its quiet down)
-Out of chainline, freewheel and fixed flip-flop often not have the same chainline, you may get fine line freewheel, when filpped to fixed, you are out.
-Too tight chain
Likes For Scrodzilla:
Quoted: 358 Post(s)
Liked 136 Times
I had the same problem with my Fixed Gear. I've tried everything. What made it run better is some good lube. I'm using Finish Line right now and that seems work fine.
Ups!
Likes For y0x8:
Quoted: 586 Post(s)
Liked 612 Times
On a serious note, in the rare event I am biking near pedestrians I always have to announce my presence. If I don't, they never hear the bike coming and are startled as I pass by.
Quoted: 823 Post(s)
Liked 1,395 Times
Experienced the exact same thing. The noise was unreal. Replaced with dura ace and its buttery quiet.
