Rim brakes for Team Ineos
Perhaps rim brakes are making a resurgence. Team Ineos, now Team Ineos Grenadier, will ride Pinarello F12 Dogma‘s with rim brakes in this year’s Tour de France. The Team edition bike will be available for purchase to the public in rim or disc.
They are the top team and have not switched over to disc. Obviously they are doing what they feel is best to win, including taking into account that the Mavic universal support vehicles only carry rim brake wheels. Team Jumbo Visma are also using rim brakes. Perhaps more pro teams will do the like.
Likes For hrdknox1:
Saw rather slow on the road wheel changes with through axle disc brake bikes last year..
Likes For fietsbob:
Quoted: 878 Post(s)
Liked 726 Times
They run rim brakes because their bikes are heavy. Same reason JV is going to ride black bikes this year. https://cyclingtips.com/2020/08/what...out-the-grams/
Quoted: 4806 Post(s)
Liked 3,928 Times
Likes For 79pmooney:
Quoted: 878 Post(s)
Liked 726 Times
I bet the faster wheel change and neutral support wheels is a bigger deciding factor despite that article. If you have GC riders ahead of team support, a flat means a getting a neutral wheel that is not changed by the team mechanic. Seconds lost can be many thousands of dollars costly, especially if that GC rider has no teammates on had to pull him back to the lead group. And if that wheel doesn't have a disc that works, that could be a real problem in the mountains! Both Ineos and Jumbo-Visma are GC teams. Discs are simply too high a risk in the GC picture (as long as your riders aren't raised on discs and expect that stopping power going into mountain turns).
Quoted: 528 Post(s)
Liked 230 Times
Likes For hrdknox1:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4390 Post(s)
Liked 3,016 Times
Yeah, I've wondered about that. This is more a mechanical question than a racing one, but why not build disc wheels with QR? I have a bike with such a set up (admittedly not very high end). What obvious thing am I missing?
Liked 3,016 Times
Likes For MinnMan:
Liked 3,016 Times
A related question. Rim brakes with carbon rims and a carbon brake track? What the hell do they do on mountain descents when it rains? Or for that matter, in the peloton? Very dicy, I'd think.
(I just read that the Shimano C24s actually have aluminum brake tracks, but that Ineos uses lightweight (<1000 g!) Meilenstein Obermayers for the mountain stages and those have carbon tracks. I guess if it rains, they swap back to the Shimanos.....)
Likes For csuperbike:
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Bikes: Space Horse Disc, Domane SL5 Disc
Quoted: 64 Post(s)
Liked 29 Times
I'm all in disc for myself, but it looks like Alaphilipe's front wheel locked up or something after he went down during stage 1. The mechanic couldn't even remove the front axle with a drill.
Start at 7:40
Start at 7:40
Likes For hrdknox1:
Resident PIA
Quoted: 212 Post(s)
Liked 356 Times
Kind of a narrow measure isn’t that?
Shad
67'er
Shad
67'er
Quoted: 878 Post(s)
Liked 726 Times
If we're going to point out how brakes led to crashes in stage 1, how about JV's George Bennett losing contol on a straight section of a descent trying fruitlessly to scrub speed off before a bend with his rim brakes. On the FloBikes post-race show, Alex Stieda was convinced it was because his brakes wouldn't bite on carbon rims. Tony Martin also went down. Not surprising that they'd want to negotiate a truce on the final descent in order to reach the finish line in one piece.
Of course the conditions were horrible for everyone, and many riders crashed. But did anyone besides Ineos' Sivakov crash TWICE?
Liked 3,016 Times
Likes For MinnMan:
That seems more like a freak occurrence, or a result of a crash rather than the reason. Plenty of crashes lead to bikes being mangled to the point of needing a full swap.
Likes For aclinjury:
Quoted: 3952 Post(s)
Liked 7,297 Times
Twice as many teams are on disc brakes this year, as there were last year. So, sure ... rim brakes are making a resurgence.
Likes For tomato coupe:
Quoted: 528 Post(s)
Liked 230 Times
This is really ignorant.
What does 'work' mean? How well? How well compared to alternatives? Have they worked on carbon rims for 100 years? Were they working in the same environment (i.e. did they do the same courses, the same speeds) as now?
$1000 bikes work and yet pros don't use them.
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
The braking is fine with either and no TDF pro needs the 28mm+ tires you can use with a disc. They are still winning on 23-25mm tires.
The need to swap parts among GC teams is obvious.
The car is not always there and having 7 teammates that can give you their wheels (quickly) vs 1-2 that are setup your size to give you a bike should also be obvious.
Then there is less rotating weight, less fork weight and less cable/fluid weight. So even at equal mass the climbers would sometimes prefer to add lead to the frame than mass on the wheel, fork and cockpit (brake fluid reservoirs).
I have some 7-10 disc braked wheels and some 15-20 rim braked ones. Some of the disc brakes are not as good as some of the carbon rim brakes and visa versa.
Likes For Doge:
