Chasing Your Tail
Quoted: 139 Post(s)
Liked 43 Times
Chasing Your Tail
This will be of no practical value to anyone but I am curious. I have a route that includes several small and tight traffic circles usually empty of traffic. They are tight radius and I am trying to figure out the fastest way around.
Not being vested with mathematical prowess I have tried trial and error, going around wide enough that I can pedal continuously, going around tight as possible and not pedaling at all since I have to stand on the outside pedal, and mixing it up by entering tight and going out half way through to pedal a little and going tight again.
Having no computer to help I am going by feel and cannot tell which is faster. Going around multiple times gets even more interesting.
Any ideas?
Any ideas?
Quoted: 1217 Post(s)
Liked 187 Times
When track racers compete in the Flying 200 they start at the outside of the track, build up speed and move down as close as possible to the inside about halfway through. Velodromes aren’t a circle but, something to think about.
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
Depends on how much of the "circle" you have to go through. Fastest line will almost always be the biggest radius through any corner.
This translates roughly to start wide, head to the inside and exit wide. Look up racing line and apex for more info, but much of that relates to auto racing.
Likes For mvnsnd:
Quoted: 1814 Post(s)
Liked 923 Times
Often, you can pedal at greater lean than you think you can.
IME, taking the most inside line, which is the shortest, is faster.
This shows up riding with a group- around a sweeping turn, taking the center line vs the fog line
can put you 3 or 5 bike lengths ahead for the same effort.
The dynamics on a tight roundabout are somewhat different, but the inside line is still much shorter.
Try counting it off "one one thousand..." and see.
Quoted: 389 Post(s)
Liked 255 Times
Liked 923 Times
If that were the case for cycling, you'd see it at the velodrome- swing wide, head to the inside, exit wide- on every turn,
but you don't.
A rough calculation of 11m inside circle, and 30m outside; traveling 3/4 around so say 60%; shortest line vs wide approach & exit equals approximately the distance of a middle line.
The wide approach/exit travels ~9m further, about 30%. Since the entry speed is the same, the exit speed would have to very different to overcome 5+bike lengths.
[end techno rant]
Quoted: 389 Post(s)
Liked 255 Times
but you don't.
[end techno rant]
but you don't.
[end techno rant]
Likes For mvnsnd:
Quoted: 5224 Post(s)
Liked 3,584 Times
realistically how much time are you looking to save? I would just stick with road rules & be where drivers expect you to be. what is it about ppl that make them want to take rotaries or traffic circles as fast as possible? got any pics, vids or coordinates so we would know more about what your asking about?
Non omnino gravis
Bikes don't have to apex every corner in a velodrome because they're simply not going fast enough to overcome available grip. Motorcycles and cars are absolutely going fast enough. If they had unlimited grip, they would drive the shortest inside line because it covers less overall distance.
I have a roughly square lap I ride inside the parking lots at our defunct airport. Because mine is square, I am apexing every corner, but choosing the entrance and exit angles is where the fun is. I've tried sticking to the inside as close as possible, but I can feel and see the speed losses due to wheel scrub from taking the corners too sharply. If I enter or exit a corner too wide, I can feel the extra time required to cover the added distance. Getting it just right feels amazing.
So going in a circle, you want the tightest line on which you can pedal continually, without scrubbing speed off of the tires.
Likes For DrIsotope:
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Bunny hop the parts of the road furniture that you can, that's the obvious answer!
https://www.youtube.com/results?sear...hop+roundabout
Likes For burnthesheep:
bikes don't have to apex every corner in a velodrome because they're simply not going fast enough to overcome available grip. motorcycles and cars are absolutely going fast enough. If they had unlimited grip, they would drive the shortest inside line because it covers less overall distance.
I have a roughly square lap i ride inside the parking lots at our defunct airport. Because mine is square, i am apexing every corner, but choosing the entrance and exit angles is where the fun is. I've tried sticking to the inside as close as possible, but i can feel and see the speed losses due to wheel scrub from taking the corners too sharply. If i enter or exit a corner too wide, i can feel the extra time required to cover the added distance. Getting it just right feels amazing.
