Shimano HG-50 7 speed discontinued?
I've been always buying this cassette because it's very solid and lasts long but this year I can't find it anywhere and on some websites it says that it's been discontinued, anybody has got information is that really so? I think this is really terrible because it means only very poor quality 7 speed cassettes will be available, this was the only one that was well made, I guess they decided that people on 7 speeds don't ride much and will be satisfied with models that last 2 months.
Quoted: 1088 Post(s)
Liked 1,024 Times
Can always buy an 8 speed and just run 7 of the gears if you have an 8/9/10 speed wheel.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
Used ones on Ebay but not cheap. One new one, black 13/26 for $30.99. They do have Hg-41 7 speed for $17.95.
SE Wis
Quoted: 2747 Post(s)
Liked 3,394 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Shimano will probably keep making the wide-range HG41/HG200 variants, but they probably didn't see enough profit from the Japanese ones to bother anymore. If you see any in the gearing you like for less than $35 or so, now's the time to snap up a few!
Quoted: 4560 Post(s)
Liked 2,802 Times
Some SunRace 7-speed cassettes are very good, maybe better shifting than Shimano. Not sure about long term durability but, for me, so far, so good after 2-3 years on SunRace freewheels and cassettes.
A month ago I switched from a Shimano 7-speed 13-28 cassette to a SunRace CSM63 11-28 cassette,. As with the SunRace chromed freewheels, this runs quieter and shifts more crisply than the Shimano. There's a minor difference in gear spacing that I notice only occasionally. It's in my sweet spot for most of the terrain I ride.
And on my hybrid I switched from the Shimano 7-speed 13-28 to MicroShift 8-speed 11-32, when I also switched from Shimano's indexed 7-speed thumb shifters to 8-speed bar end shifters. The MicroShift cassette has also been fine. Besides putting in a couple thousand miles it's also routinely hauled up to 50 lbs of stuff on errands, including climbs. No problems.
Liked 1,024 Times
The spacing between 7 and 8 is the exact same. It's the reason road bikes went from 126mm to 130mm; it accommodated the extra the gear. If it's a newer wheel then it already had a spacer to remove slop in fitting a 7sp cassette. Toss the spacer in the parts drawer, put an 8 speed cassette on with the low cog the next size bigger and enjoy having the same 7 gears. Shouldn't even need adjustment. If it's a 7 speed wheel many of the 8 speed cassettes are screwed together to make the block, buy one that is, toss the screws and the last cog and spacer and enjoy a 7 speed cassette. No friction shifting needed.
My hub will only accept 7 speed and only 12t so it's bad for me and I think many people that have those older hubs. I heard mixed opinions on sunrace so not sure, HG-50 was made in japan, very durable I found it to be able to last 15000 miles and that is manhandling it with downtubes, upshifting 4 gears at once, etc. The black one HD200 is 12t but that's low end cassette, HG-41 looks ok but they only make only 11t…
Liked 2,568 Times
It’s not that I’m a fan of the tiny cogs, but it should be possible to make them work as choices dwindle...
Nope it doesn't have provision for 11 it is from way before there were compact cranksets it's 1055 7 speed. I can't put spacer, chain would be rubbing on the frame and if I put spacer on the axle then I'd have to pull spokes on the right so much they'd snap and left would be way too loose. Well anyway it doesn't matter, I think HG-41 is gonna get discontinued as well soon.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Likes For Wilfred Laurier:
Liked 1,024 Times
I currently have 2 bikes running this setup and have set up dozens of bikes this way. If there is a spacing difference it is so minuscule as to not matter and the bikes shift perfectly.
Liked 1,024 Times
Mmkay but what about this, I have the "non compact body" https://www.sheldonbrown.com/k7.html#hyperdrivec And I have one of these spacers beneath the cassette already, it was always provided with 7sp hg 50 https://static.evanscycles.com/produ...571-9999-1.jpg
This is the hub I got and it did come with screw on uniglide orignally but you can also install hyperglide like I did.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
I've been always buying this cassette because it's very solid and lasts long but this year I can't find it anywhere and on some websites it says that it's been discontinued, anybody has got information is that really so? I think this is really terrible because it means only very poor quality 7 speed cassettes will be available, this was the only one that was well made, I guess they decided that people on 7 speeds don't ride much and will be sTatisfied with models that last 2 months.
https://www.sjscycles.co.uk/cassette...sette/?geoc=US
Liked 1,024 Times
Your link specifically says that your non-compact cassette body can take an 11 tooth and that if you use the 11 tooth on it you will just need the spacer that you already use which should have no effect on your current derailleur adjustment which is already set with that spacer in place.
Liked 2,568 Times
I'd actually like to have 11T, but I was always led to believe that 12 is all I can get with this hub. I'd be much obliged if someone who's got spare 11t cog tried it because I don't want to waste money on cassette that I'll have to throw away because it won't fit. Also can anybody tell durability HG50 vs HG41 because I read some reviews on the internet that HG41 only lasts 1200 miles that would make it 10x worse than HG50…
Quoted: 523 Post(s)
Liked 229 Times
It took me about 30 seconds to find an eBay seller for the chain you mentioned in the opening post. $9.99 postpaid https://www.ebay.com/itm/Shimano-CN-...kAAOSwotFbSBUA
Shimano CN-HG50 6-7-8 Speed Hyperglide Bicycle Chain 106 Links Includes Pin New!
In any event, the spacing on a 7-speed Shimano cassette is not the same as on an 8 speed. Measure it and you'll see.
Quoted: 427 Post(s)
Liked 699 Times
Guess I should be glad kept all my old 7 spd mtn bike components that I upped to 8 spd, when the orig frame was replaced and I put together what is my current mtn bike. I've entertained the idea of picking up a frame to put them on, to use as a hybrid, tho I'm in no rush and haven't come across a frame yet (haven't looked all that hard). If I ever do decide to part with them, I'll put them on here, as occasionally I see someone looking for them. Wish ya the best of luck-had no idea they were becoming scarce!
I think HB 1055 is 6-speed compatible and the spacer was included so you can use 7 speed cassette, this would mean that 11t should fit? Still not sure about HG 41 are they as durable as HG 50?
Liked 2,568 Times
Here's a shot of an IG60 (Interactive Glide) 11-28 cassette on my 1055 hub. No issues getting all the cogs on and torqued together into a solid unit. (Freehub body is stock, FWIW.)
I don't have any HG 11-28 cassettes on hand, but I think this shows that it should work.
Personally, I doubt that HG41 cassettes are any less durable. Usually the difference is entirely in the finish. Black or brown for lower-level cassettes, matte nickel finish for upper-level cassettes.
And I like SRAM PC-850 chains. They're inexpensive and long-lasting. 5000+ miles before stretching to the 1/16" mark. That helps any freewheel or cassette last longer.
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
ThermionicScott Thank You for this, and did You use spacer provided with the cassette or some different one?
Confusing as to why would there be wrong information on Sheldon's page, perhaps it was true about some other hubs then. HG-50 and CN-71 lasts me about 12.000 miles, this chain doesn't stretch at all, CN-40 on the other hand is junk, that's why I'm weary because I know that the numbers are denoting quality levels. It's not just finish when it comes to those chains, could be same with cassettes, although there are exceptions… I guess I'd have to try it myself, I'm tempted by that 11t cog, it would be useful to me on the hills around here.
btw I found out that there was similar thread here about HG70 https://www.bikeforums.net/bicycle-m...hole-cogs.html that one would have been perfect for me it was strong as HG50 and had 11t, damn shimano keeps discontinuing good stuff hg50/70 were made in Japan, while HG-41 is from Singapore, I'm always partial to stuff made in Japan…
